TPS wiring harness install - TCCoA Forums
post #1 of 13 (permalink) Old 01-07-2011, 07:58 PM Thread Starter
CougarChaserXR7's Avatar
How is this done? As I found a good one on rock auto, but i dont know how to slice the wires and such. Any one done this before?
1995 Cougar Xr7 4.6
The never ending debate:
http://forums.tccoa.com/showthread.php?t=132847
CougarChaserXR7 is offline
post #2 of 13 (permalink) Old 01-07-2011, 10:51 PM
Honestly if you have no concept of how to do that you need to take it to a professional. Cut the wires off. Strip the wires. Properly solder the wires. Heat shrink the new connection to prevent corrosion. You'll get further in life by learning to listen to the advise offered by others. SEARCH!!!!!
post #3 of 13 (permalink) Old 01-07-2011, 10:55 PM
Yes. Many times, in many cities around the world, on many cars, others more intellegent than you have replaced their broken connectors with new ones or good used ones.
Every post you make reminds me of this guy.
Stop with your need to be spoon fed!
post #4 of 13 (permalink) Old 01-07-2011, 10:59 PM
If you have to ask, it can't be done.
post #5 of 13 (permalink) Old 01-08-2011, 01:29 AM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #6 of 13 (permalink) Old 01-08-2011, 08:55 AM
Wow, Chris. I don't know why I bother reading all the stuff on this forum when I could have just watched that video and got all my questions answered! And for under $50, too!
So I got this idea, you could start your own forum, install of "the corral" for the 'Stangs', you could call it "the nest" for the 'Birds'. Huh? Huh? Can I get an Amen?
~Rick
TCCoA Sig
post #7 of 13 (permalink) Old 01-09-2011, 09:43 PM
so why are you changing your TPS wiring? is it damaged? what code is showing up?
post #8 of 13 (permalink) Old 01-10-2011, 12:43 AM
V8ThunderCat's Avatar
Okay, you may not be as bad as the people parodied in that xtranormal video but seriously, you need to use the search feature here at this forum and google before you ask ANY questions!!!! Otherwise you'll be flamed further and only have less respect when you do ask really good questions.
-Randy-
V8ThunderCat is offline
post #9 of 13 (permalink) Old 01-13-2011, 12:07 AM
...ahem....
post #10 of 13 (permalink) Old 01-13-2011, 12:53 AM
Originally Posted by NetKeym View Post
..... Can I get an Amen?
...ahem....
Amen, not ahem
M, M
~Rick
TCCoA Sig
post #11 of 13 (permalink) Old 01-13-2011, 06:20 AM Thread Starter
The connector clip is broken.
1995 Cougar Xr7 4.6
post #12 of 13 (permalink) Old 01-13-2011, 07:45 AM
Roadrunnner's Avatar
So have you done anything anyone has suggested? Any changes? You havnt posted if its fixed, moved, got worse on this or any of your other problems.
Will
Last edited by Roadrunnner; 01-13-2011 at 07:50 AM. Reason: Added a word so my string of nonsense is correct
Roadrunnner is offline
post #13 of 13 (permalink) Old 01-13-2011, 12:49 PM
You know, you can change the plastic connector without cutting, splicing, or soldering a single wire...
