Q: Do I need my fender liners on a Tbird Track car? - TCCoA Forums
post #1 of 23 (permalink) Old 01-09-2011, 11:19 AM Thread Starter
S4gunn's Avatar
In a 95 Ford Thunderbird LX that will be a dedicated track car, is there any reason to keep the fender lines?
Looking at the shop manual, I don't see that the fender liners are protecting much.
Q: Please let me know if I've missed something and the liners are needed to protect some electrical wires or something I actually NEED in a track car.
It's not much of a weight savings but I'll take any pound I can shave off of this beast. Thanks in advance for your reply.
Regards,
-g
PS. Anyone need fender liners? If so PM me. I'm just trying to lower my 24 Hours of Lemons $500 budget here.
S4gunn is offline
post #2 of 23 (permalink) Old 01-09-2011, 12:59 PM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
You live near SF, East Bay? I could use a passenger side fender liner. When my lower ball joint popped out, the tired rubbed the hell out of mine, haha. PM sent.
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #3 of 23 (permalink) Old 01-09-2011, 01:24 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
You have the cruise control and ABS on the LH side and on the RH side you have the charcoal canister and vacuum reservoir and the associated lines along with the air silencer. I would expect increased chances of sucking up water with the fender liners out. You may have already changed the induction system though.
-Rob
Rob is offline
post #4 of 23 (permalink) Old 01-09-2011, 02:07 PM
On a track-only car, no you do not need them.
post #5 of 23 (permalink) Old 01-09-2011, 03:58 PM
No need at all.
post #6 of 23 (permalink) Old 01-09-2011, 04:09 PM Thread Starter
S4gunn's Avatar
This is exactly what I wanted to know.
I appreciate it.
-g
S4gunn is offline
post #7 of 23 (permalink) Old 01-09-2011, 08:42 PM Thread Starter
S4gunn's Avatar
I pulled them off late this afternoon and in addition to losing 3.3Lbs per fender liner removed, I also found over a pound of dirt behind that spongy material that separates the wheel well from the door gap.
Thanks, guys!
-g
S4gunn is offline
post #8 of 23 (permalink) Old 01-09-2011, 09:40 PM
tbirdtess's Avatar
front bumper
Hi
Loose the piece under the front bumper cover.
The headlight header is a good piece to sell.
Get a power steer cooler if you don't have one.
Also cover pump opening with a rag over the cap.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #9 of 23 (permalink) Old 01-10-2011, 09:17 AM Thread Starter
S4gunn's Avatar
Originally Posted by tbirdtess View Post
Hi
* I check to see if we need the stuff under the front bumper cover. I assume it's some styrofoam bit and there's an underlying metal bumper as well, right?
* I've already ordered a PS cooler and it's install is on the TO DO list.
* "opening in the PS pump" I'll have to check that out. You mean so when it blows it doesn't spray everywhere right?
* What's the headlight header? I went through the shop manual and the only thing that sounds close to what you've mentioned is the "photocell / amplifier" that seems to control the Daytime running lights. I'm not sure this car even has that but can you clarify things here?
-g
S4gunn is offline
post #10 of 23 (permalink) Old 01-10-2011, 09:23 AM
for a track only car, depending on how much time you have, and the tools you can use, there is a ton of weight to be removed off these cars.
you just have to think outside the box a little,.
post #11 of 23 (permalink) Old 01-10-2011, 12:02 PM
tbirdtess's Avatar
Hi
He will have to keep much of the front body structure. For support of the structure.
So he can't loose too much.
The head light header. You don't need head lights correct?
Yes, over the vent hole of the pump cap.
Some Thunderbird's came with power steer coolers. You could get it in without cost.
That's were mine came from.
351W 2bbl.
C-4 Auto
3.90 open rear
post #12 of 23 (permalink) Old 01-10-2011, 01:38 PM Thread Starter
S4gunn's Avatar
Hi
Thanks.
1) Ahh, so you mean the harness and whatnot. Headlights are needed if we do the 24 hour race vs. the two 12 hour sessions. I don't know the schedule of the Lemons race we are entering yet (Targeting Infineon in Oct) but the possibility remains there.
2) Yeah, I looked and the 95 cooler is a crappy u shaped tube with NO fins. I found a cheapier U shaped tube WITH fins so the gameplan is to route the PS fluid out of the old cooler and into this one (cooler = better).
-g
S4gunn is offline
post #13 of 23 (permalink) Old 01-10-2011, 01:41 PM Thread Starter
S4gunn's Avatar
While we are discussing weight loss for a track car, is there any reason I may want to keep the underhood heat liner?
If I understand things correctly, the downsides of NO liner are:
* hood will become very hot to touch if I don't get some airflow underneath the hood.
* paint could start to discolor (don't care for me).
The upside is weight loss
I probably won't screw with it until I decide what to do with the hood (cut outs, ghetto cowl hood, or maybe just standoffs) but I just wanted to poll you folks.
-g
S4gunn is offline
post #14 of 23 (permalink) Old 01-10-2011, 02:29 PM
Nope, ditch the hood liner. I get rid of it on street cars even, with no ill effects.
post #15 of 23 (permalink) Old 01-10-2011, 02:33 PM
I havn't had mine in for years, no cooling problems, no discoloration, nothing. It's more there for sound deadening and in the event of a fire, a fire blanket.
It's about as weighty as a sheet of paper though
post #16 of 23 (permalink) Old 01-11-2011, 06:15 PM Thread Starter
S4gunn's Avatar
Hey, if I'm scraping the tar off the bottom of the car and considering disassembly of the A/C compressor, OCD enough to trim "sheets of paper" off the car.
-g
S4gunn is offline
post #17 of 23 (permalink) Old 01-11-2011, 06:46 PM
tbirdtess's Avatar
-g
Hi
Ugh NO!!
I cut my front bumper in half to save weight! You should gut the doors if you can.
at least the inner parts.
Loose as much glass as you can. Glass is heavy!
351W 2bbl.
C-4 Auto
3.90 open rear
post #18 of 23 (permalink) Old 01-12-2011, 08:54 AM
-g
scrape whats on the inside of the car too.....
if you're looking for more ways to lose weight, check out my thread called more weight removal in the general tech section.
post #19 of 23 (permalink) Old 01-12-2011, 10:27 AM
tbirdtess's Avatar
Talk about OCD!! lol
He won't be able do that much! lol
I wish I could!!
351W 2bbl.
C-4 Auto
3.90 open rear
post #20 of 23 (permalink) Old 01-12-2011, 06:21 PM Thread Starter
S4gunn's Avatar
Hi
Ugh NO!!
How much into the doors do you recommend? The door panels are already off and ready to go to a good home (if anyone wants them).
Obviously you want me to ditch the glass, the window motor, and any excess wiring.
Are you also suggesting that I take a sawzall (or any kind of cutter) and take out the inner door frame as well?
-g
S4gunn is offline
post #21 of 23 (permalink) Old 01-12-2011, 06:23 PM Thread Starter
S4gunn's Avatar
Your thread was great (all 17 pages of it). I found it amusing how you started with the tar and then went all nuts into welding the seams like a Lancer Evo
-g
S4gunn is offline
post #22 of 23 (permalink) Old 01-12-2011, 09:26 PM
tbirdtess's Avatar
-g
Hi
Are you adding door bars? role cage?
I have just an outer skin over my door bars.
351W 2bbl.
C-4 Auto
3.90 open rear
post #23 of 23 (permalink) Old 01-13-2011, 04:30 PM Thread Starter
S4gunn's Avatar
Hi
In addition to the full cage, Lemons rules explicitly require 2 horizontal door bars on the driver's side.
Similar bracing is NOT required on the passenger side but we'll probably do it anyway.
I'll have to consider your thoughts on the inner vs. outer skin.
Right now, the car is being stored inside/outside and is street legal. I'll put this tip in my list of tasks to consider as we get closer to the race date (and strip out the glass).
-g
S4gunn is offline
