Bad Fuel Pump? - TCCoA Forums
post #1 of 48 (permalink) Old 01-09-2011, 04:07 PM Thread Starter
CougarChaserXR7's Avatar
Unhappy Bad Fuel Pump?
Well today when I was leaving work, started the car up. Started fine, went to put the car in gear went in gear fine. Pulled out and the car just about stalled on me.
I went to auto zone and used their fuel pressure tester, and saw i was getting 10 psi, but i am not 100% sure if I did it correctly when I tested it, as it was my first time and I had to rush to get it done.
Any help would be greatly appreciated.
1995 Cougar Xr7 4.6
The never ending debate:
http://forums.tccoa.com/showthread.php?t=132847
CougarChaserXR7 is offline
post #2 of 48 (permalink) Old 01-09-2011, 04:18 PM
Fuel filter under the car on the passenger side.
Then, check fuel pressure INTO the fuel filter, and if it's low, drop the tank and replace the pump and strainer with new (or the whole float assembly - quicker and easier, but costs more.)
Hint: If you change out the whole float assembly, go Ford only - Airtex sometimes works, sometimes leaks like a sieve. QC seems to be hit and miss.
Considering your other posts, if it's not the fuel filter plugged, I'd take it to a competent mechanic.
RalphP is offline
post #3 of 48 (permalink) Old 01-09-2011, 04:21 PM Thread Starter
Thanks!
Thats what I plan on doing this tuesday...
1995 Cougar Xr7 4.6
post #4 of 48 (permalink) Old 01-09-2011, 04:24 PM
Yah, when I got around to swapping the fuel filter on the wife's Cougar, it was on backwards (!!) and what I drained out was nasty brown (!!!!)
Never stumbled or failed but that's just good PM IMAO.
RalphP is offline
post #5 of 48 (permalink) Old 01-09-2011, 04:36 PM Thread Starter
I have no idea how to change it, so i am going to have to see if I can get it done for about $300 for labor, without purchase of the fuel pump.
1995 Cougar Xr7 4.6
post #6 of 48 (permalink) Old 01-09-2011, 04:40 PM
Change the fuel filter first.
Drive the car up on ramps.
Get under the passenger side.
There's two bolts (8 MM IIRC) that hold a plate on, that you can see a hose clamp in.
Release the two bolts.
Use the fuel line quick-connect release tool, release the fuel line (note: If you haven't vented pressure, it'll spew when you release the first line. If it's plugged, it'll spew on both.)
Open the hose clamp.
Pull the filter out.
Slip new filter in.
Tighten hose clamp.
Slip hoses on filter until the quick-connects CLICK.
Put the bolts back in.
Start car up. It stalls. Cuss, start it again, it runs
Back off of ramps.
Check fuel pressure at this time. If it's back proper, it's the fuel filter.
A new one is not that much at O'Reilly's - but I had to pick up a 1990 SC filter to fit the car, the one they list won't fit the filter shield (too big around).
RalphP is offline
post #7 of 48 (permalink) Old 01-09-2011, 04:48 PM
It is nice
You can unscrew the gas cap also before you remove the filter
91CougarLS is offline
post #8 of 48 (permalink) Old 01-09-2011, 04:48 PM Thread Starter
I changed the filter about 3 months ago..
1995 Cougar Xr7 4.6
post #9 of 48 (permalink) Old 01-09-2011, 05:21 PM
Odds are it's not the fuel filter - but I'd check it anyway in case you sucked some crap up and it's plugged the filter.
That's a LOT easier to check than the pump/strainer, so I'd always check it first.
RalphP is offline
post #10 of 48 (permalink) Old 01-09-2011, 06:15 PM Thread Starter
Dont you just take it out, blow through it and see if you can?
1995 Cougar Xr7 4.6
post #11 of 48 (permalink) Old 01-09-2011, 09:25 PM
Moderator & Teksid Whore
guitar maestro's Avatar
so let me get this straight, you want to put your piehole on a fuel filter recently removed from a vehicle?? Where are you learning this crap or are you coming up with this moronic non-sense yourself?
guitar maestro is offline
post #12 of 48 (permalink) Old 01-09-2011, 09:31 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
Thats what I do. If it does flow through and gets progressively harder to blow through I consider it partially clogged. Sometimes it just doesnt blow through and the air you blew in will push back into your mouth when you stop blowing, so be careful. Gas in the mouth doesnt taste good.
The easiest way to determine if you have a fuel delivery problem is to hook up a fuel gauge with a pressure release valve. First you check the pressure key on engine off. Then you crank the car and check the pressure, if its close to specifications, get a container and measure how much gas it puts out. One of my own personal standards, since most manufacturers dont specify fuel volume specifications, is to see if the car can pump out ~16 oz in 30 seconds, if it can, the fuel delivery is sufficient. If the pressure drops and the car dies when you open the pressure release valve to take the measurement, there is certainly not enough fuel coming to the fuel rail and that can be caused by a restriction or leak in the fuel system or a weak fuel pump.
-Rob
Rob is offline
post #13 of 48 (permalink) Old 01-09-2011, 09:36 PM
That's my main point. Sure one could do that, but once you've narrowed it down to a fuel delivery issue, I think the filter should just be changed anyways just before going to the fuel pump.
post #14 of 48 (permalink) Old 01-10-2011, 12:10 AM
V8ThunderCat's Avatar
Considering how cheap and easy replacing the fuel filter is there's no reason to just go ahead and change it whenever the fuel delivery is in question. Even if a fuel filter has been changed recently there's always the chance that some sort of residue or blackage has moved from the tank and is now inside the filter causing these problems.
In other words that's what GM is trying to say, I think.
-Randy-
V8ThunderCat is offline
post #15 of 48 (permalink) Old 01-10-2011, 08:29 AM
I always let fuel pour out of the tank line into a glass container, so I can see what's coming out of the tank.
If it's full of crap, a tank flush is in your future.
PLease don't pour gas on yourself, and set it on fire while doing this; I realize it's unlikely, but I feel I should mention it.
post #16 of 48 (permalink) Old 01-10-2011, 12:37 PM
Rob
Rob's Avatar
Very good advice, also do not drink the gas. I hear it is poisonous!
-Rob
Rob is offline
post #17 of 48 (permalink) Old 01-10-2011, 02:42 PM
Did the car start back up?
What are the odds the fuel pump pressure was correctly checked? (vac line off reg, at idle)
I've taken a few gas baths in the past, some of which i have drank, I don't think it's affected me at... wait what are we talking about?
coolhandzep is offline
post #18 of 48 (permalink) Old 01-10-2011, 03:09 PM Thread Starter
The car started up just fine. I didnt do the test 100% right im sure of it, because I only cranked it over once, when i know now that you have to crank it a couple of times to have the pressure go all the way up.
I didnt have anyway to look up that information as I was in the autozone parking lot.
I have noticed that under loads the rpms will stay at a constant, but if I try to give it gas the rpms drop down to 1k. Mind you I am usually at 1.5k
1995 Cougar Xr7 4.6
post #19 of 48 (permalink) Old 01-10-2011, 03:22 PM
I think you are jumping to conclusions in terms of thinking it is the fuel pump at fault.
post #20 of 48 (permalink) Old 01-10-2011, 03:41 PM
The car started up just fine. I didnt do the test 100% right im sure of it, because I only cranked it over once, when i know now that you have to crank it a couple of times to have the pressure go all the way up.I didnt have anyway to look up that information as I was in the autozone parking lot.
wait, is your car carbed? with a mechanical fuel pump?
post #21 of 48 (permalink) Old 01-10-2011, 03:46 PM Thread Starter
No its a 95, but I relieved all the fuel pressure out of the system. one turn to the ON position will not give the 100% full pressure.
I should add that my car doesnt do this when its cold. Only when hot.
1995 Cougar Xr7 4.6
post #22 of 48 (permalink) Old 01-10-2011, 06:09 PM
Fuel Filter
FWIW, my engine was running a bit rough. I checked the fuel pressure and it was like 35 lbs. I pulled the fuel filter out and tried to blow through it and it was flat out plugged up. I don't understand how I was getting good fuel pressure when I couldn't even blow through it!!! A new, clean filter is VERY easy to blow through.
With the new fuel filter in place, the car went back to running normal.
~Rick
TCCoA Sig
post #23 of 48 (permalink) Old 01-10-2011, 06:54 PM
Are ya friggin' kidding me?
Bring your car up to NC. I'll change your fuel filter, J-mod your car and buy you lunch and dinner for $300.
post #24 of 48 (permalink) Old 01-10-2011, 07:05 PM
I think he's talking about his fuel pump Ron. But for the $300 he should buy you breakfast also!
post #25 of 48 (permalink) Old 01-10-2011, 10:20 PM Thread Starter
yes i ment the fuel pump. I changed the fuel filter myself
1995 Cougar Xr7 4.6
post #26 of 48 (permalink) Old 01-11-2011, 07:59 AM
Roadrunnner's Avatar
Any differenc?e
Will
Roadrunnner is offline
post #27 of 48 (permalink) Old 01-11-2011, 01:20 PM Thread Starter
I was referring to this.
1995 Cougar Xr7 4.6
post #28 of 48 (permalink) Old 01-11-2011, 01:33 PM
Have you done anything that has been suggested?
-Randy-
post #29 of 48 (permalink) Old 01-11-2011, 05:06 PM Thread Starter
its like 20* out today, no doing anything on my car today :/
1995 Cougar Xr7 4.6
post #30 of 48 (permalink) Old 01-11-2011, 06:50 PM
Woodman's Avatar
24 here... nice warm day for Northern Minnesota.
Bundle up!
Woodman is offline
