need underhood 12v switched wire - TCCoA Forums
post #1 of 6 (permalink) Old 01-15-2011, 03:34 PM Thread Starter
paintme205's Avatar
Like the title says, I need to know what wire to splice into underhood that is a 12v power but only comes on when the engine is started. It is for my electric water pump. Any help is appreciated.
paintme205 is offline
post #2 of 6 (permalink) Old 01-15-2011, 03:38 PM
The circuit that feeds the injectors, iac and egr regulator is 12V ignition.
post #3 of 6 (permalink) Old 01-15-2011, 06:46 PM
Icarus's Avatar
I'd run a fused wire/relay to the battery for an electric water pump.
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #4 of 6 (permalink) Old 01-15-2011, 11:31 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I am sure he is looking for a wire to power the coil in the relay. For the switched power, he should definitely have it hooked up to one of the main 12v sources under the hood (battery +, the 175a fuse, alternator + terminal) with a fuse. The amperage draw is very small from the relay coil. I think Matt hit it on the nose as far as a switched 12v source to tap into for the relay coil.
-Rob
Rob is offline
post #5 of 6 (permalink) Old 01-16-2011, 10:49 AM Thread Starter
paintme205's Avatar
Thanks everyone. I used the ignition coil hot wire and I am running it off of a relay.
I also have an led rigged up in the dash to let me know if it stops getting power for some reason. It is a good thing I had it too, since the fuse blew (wrong size) while the car was running. I wouldn't have known it wasn't running otherwise.
post #6 of 6 (permalink) Old 01-18-2011, 07:57 PM
Nonsense...I'm sure you would have found out that it wasn't running before long.
