new hinge vs. rebuild - TCCoA Forums
post #1 of 43 (permalink) Old 01-17-2011, 06:58 PM Thread Starter
Earl's Avatar
My drivers side lower door hinge is in serious need of replacement. I have been weighing the pros and cons of the rebuild kit, or just purchasing a new hinge from ford. The added cost does not concern me too much, I am more concerned with making this fix as easy as possible. So, is it any less labor intensive to just change out the whole hinge with an entirely new unit?
Thanx
Earl is offline
post #2 of 43 (permalink) Old 01-17-2011, 07:41 PM
sousa632's Avatar
Changing the hinge pin is simple, so long as the holes havent egged out. With a hinge you would have to do a LOT of realigning......
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #3 of 43 (permalink) Old 01-17-2011, 07:44 PM
Traveler's Avatar
And replacing the hinge requires removing your dash. I got an estimate from a Ford dealer for that (I was getting an estimate on some body work anyway).. he quoted me 500.00 to replace the hinges on the drivers side door alone. Naturally I was shocked and said why so much and he said he had to remove the entire dash to get to the bolts holding the hinges in. The next guy (a local independant body shop) laughed and said he could do it for 50 bucks.. just replace the hinge pins.. guess who got the job.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 43 (permalink) Old 01-17-2011, 08:05 PM Thread Starter
Earl's Avatar
I thought only the upper hinge required dash removal, not the lower hinge?
Earl is offline
post #5 of 43 (permalink) Old 01-17-2011, 08:13 PM
Traveler's Avatar
Thats probably true. But if you're going to take the time and trouble to repair/replace one hinge, take the time to do the other one as well. With the door moving up and down due to the lower hinge, the upper one can't be far behind.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 43 (permalink) Old 01-17-2011, 09:20 PM
rbrown's Avatar
I replaced the pin in the lower only. P I B
I will buy a new hinge next time and do it right.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #7 of 43 (permalink) Old 01-17-2011, 09:43 PM Thread Starter
Earl's Avatar
So, replacing the entire lower hinge would be a better easier option?
Earl is offline
post #8 of 43 (permalink) Old 01-17-2011, 11:08 PM
V8ThunderCat's Avatar
Even the lower hinge is a pain to replace. I did just that and it was hard to get my fingers onto the bolts. It really wasn't worth the trouble because it didn't fix the problem that I had. Now I have a maroon lower hinge on a green car.
-Randy-
V8ThunderCat is offline
post #9 of 43 (permalink) Old 01-18-2011, 07:13 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
Oh snap! I had a maroon lower hinge on my teal green 94 after I painted it orange. It is fairly easy to change the lower hinge. With a friend, you shouldnt have any problems getting the door lined up. If you do them both at the same time, lining up the door is a freaking nightmare, even with reference marks. I never got the LH door totally correct on my 94 when I installed a new upper hinge/ rebuilt lower hinge.
-Rob
Rob is offline
post #10 of 43 (permalink) Old 01-18-2011, 09:31 AM
T6Rocket's Avatar
Where do you get the hinge rebuild kits?
So, the door doesn't have to come off?
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #11 of 43 (permalink) Old 01-18-2011, 09:36 AM
Al
supercoupeperformance.com Has the kits, and no the door does not have to come off
http://www.youtube.com/watch?v=SVVozUkfDO4
post #12 of 43 (permalink) Old 01-18-2011, 09:44 AM
I have done it both ways and will never change an entire hinge again. I prefer the aftermarket pin kit. I bought my stuff at rockauto.
post #13 of 43 (permalink) Old 01-18-2011, 10:47 AM
got my pin/rebuild kit at NAPA for 4.75. easy to do. took less than an hour and i didnt have to lay under the dash to remove the hinge bolts. IMO the most productive way to do it. works as good as new
My Lug Nuts Require More Torque Than Your Honda Makes
Tbird64 is offline
post #14 of 43 (permalink) Old 01-18-2011, 02:57 PM Thread Starter
Earl's Avatar
so the rebuild kit is NOT an SCP only item? is the NAPA rebuild kit specific to the bird? I'm gooooooooogleing right now....
Earl is offline
post #15 of 43 (permalink) Old 01-18-2011, 05:29 PM
I bought my replacement pins from Advanced..... The Help/Dorman brand have them.
Part #38438
http://www.dormanproducts.com/p-2758...ymmeid=5033992
~Rick
TCCoA Sig
post #16 of 43 (permalink) Old 01-18-2011, 07:06 PM
sousa632's Avatar
I got my pin kit at Advance Auto Parts
John
1996 TBird LX 4.6
sousa632 is offline
post #17 of 43 (permalink) Old 01-18-2011, 08:54 PM
Rob
Rob's Avatar
I used 38410, like the tech article suggests. I think I had to drill the hinge out to use them. What are 38438?
-Rob
Rob is offline
post #18 of 43 (permalink) Old 01-18-2011, 09:18 PM Thread Starter
Earl's Avatar
Interesting. I was not aware the repair kit could be purchased from regular parts stores...
Earl is offline
post #19 of 43 (permalink) Old 01-18-2011, 11:04 PM
Part #38410 are listed to fit F Series pick-ups and Broncos. Probably why you had to drill out your hinges (that's interesting to know - because if the hinge holes are "egged-out", 38410 are probably REQUIRED - I dunno ).
Part #38438 are hinge pin kits listed for TBird/Cougar applications.
~Rick
TCCoA Sig
post #20 of 43 (permalink) Old 01-18-2011, 11:52 PM
If the holes are egg shaped I use the larger ones, if they are not the stock ones are fine. I have used both.
post #21 of 43 (permalink) Old 01-19-2011, 12:30 AM
Rob
Rob's Avatar
Well looks like I will be using 38438 on the 96. I dont think the holes are hogged out too bad. Thanks for the great info. This will make the pins even easier this time!
-Rob
Rob is offline
post #22 of 43 (permalink) Old 01-19-2011, 12:31 AM
thunderclaw's Avatar
you guys are gonna hate for this. i used washers as shims to re-aligned the striker w/ the lacht. mine wasn,t worn out but misaligned which causes most of the damage.
its sweet to hear how effortlessly they latch
thunderclaw is offline
post #23 of 43 (permalink) Old 01-19-2011, 07:40 AM
Yeh, mine latches easy too. However, if you pick up the end of the door with it open (it's pretty heavy), my door moves like an inch (the hinge hole is really worn). I bought the repair kit, I just haven't installed it yet. It's relatively easy to change (I have done them before). I just use a side grinder, cut the old one in half to pull top half out the top, bottom out the bottom. Then just drop the new one in, put the clip on.
~Rick
TCCoA Sig
post #24 of 43 (permalink) Old 01-19-2011, 10:17 PM
If you use shims as a band-aid be prepared for egged out holes if you wait too long to replace the pins.
Yeah, I used washers to align my drivers side door but the door was messed up not because of the pins. The door had caught the elevated corner of the front yard when I was pushing the car backwards into the driveway.
The passenger side on the other hand desperately needs new pins but for now I just avoid having to open that door.
-Randy-
post #25 of 43 (permalink) Old 04-10-2011, 05:19 PM
steamer471's Avatar
ok thread revive- I bought the dorman 38438. My holes are not "egged out" why are the bushings so much larger than the holes? Do I need to drill?
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #26 of 43 (permalink) Old 04-10-2011, 05:41 PM
Rob
Rob's Avatar
Yup, I just did this a few days ago. I used a drill bit 2 sizes down from the 1/2" bit. I cant remember if it was 15/32" or what. You want a bit just a hair smaller than the bushing or almost right at the OD size of the bushing to install them. The dimensions are on the back of the box, but I threw them away already. Hope this helps.
EDIT: I just thought I would also mention, these pins in the 38438 kit are the perfect length and do not interfere with the bolts like the 38410 truck kits I used on previous cars would.
-Rob
Rob is offline
post #27 of 43 (permalink) Old 04-10-2011, 06:52 PM
steamer471's Avatar
Thanks Rob I'll try the 15/32 then the 31/64 bit sizes thanks again.
1997 Mark 8 LSC
Former owner:
post #28 of 43 (permalink) Old 09-03-2011, 02:40 PM
mine were not damaged just slightly off. i agree if they are damaged change them
post #29 of 43 (permalink) Old 09-12-2011, 08:44 PM
Found this info....not sure about pin length....but bushings are the same size... .350" ID x .480" OD.
Dorman 38438 is the "HELP" on a card.
Dorman 703-270 is in a box. About half to 1/4 the price if you google it!
Again, not sure about pin length, but the parts helper says it fits the 96.....
As for drilling the hinge, I suspect that these new bushings are over size..... I have some new bushings at home, will dig one out and measure it!
fm
fastmerc is offline
post #30 of 43 (permalink) Old 09-12-2011, 08:56 PM
Pedal Faster
Josh_Keady's Avatar
I installed 38438 on my SC and had to drill out the hinges just slightly. Honestly, the new bushings can be tapped in sans drilling, but they are too tight and the pins aren't free to spin in them. BUT when I drilled the hinge to the size recommended on the package, the bushing was -I thought- too loose in the hole. I ended up going a 64th smaller and things seemed to work well.
One thing I can say: wish I hadn't waited so long to do that job. It wasn't fun but it could have been a lot worse and the doors close great now.
Josh Keady
Josh_Keady is offline
