97 mark VIII - TCCoA Forums
post #1 of 7 (permalink) Old 01-22-2011, 09:20 PM Thread Starter
Question 97 mark VIII
On The 1997 Mark Viiii I Have The 1450 Code That Wont Go Away After Clearing
From My Research Looks To Be The Purge Solenoid Would Anyone Agree? Or Are There Other Things To Look At? I Have No Cel Just The One Code P1450 That Wont Erase. Also Where Exactly Is This Part Located I Gather Passengers Wheel Well ? Thanks
Just Got Car Yesterday All New To Me As It Aint No Supercoupe!!!!
Probably Let The Wife Drive It , I Still Prefer My 95 Supercoupe For Some Reason..
Anlo is offline
post #2 of 7 (permalink) Old 01-23-2011, 06:13 AM
Well, after I did a search here's what I came up with:
Possible causes:
EVAP canister purge outlet tube (EVAP canister purge valve to EVAP canister) blockages or kinks.
EVAP canister tube (fuel tank to EVAP canister) blockages or kinks.
Fuel vapor elbow on EVAP canister contaminated.
Restricted EVAP canister.
Canister vent (CV) solenoid stuck closed (partially or fully).
Plugged or contaminated CV solenoid filter.
EVAP canister purge valve stuck open.
Fuel filler cap stuck closed (no vacuum relief).
VREF circuit open in fuel tank pressure (FTP) sensor.
Damaged FTP sensor.
The purge canister seemed to be the culprit in most cases, but not all. It is located on the passenger side wheel well.
Go for it!
post #3 of 7 (permalink) Old 01-23-2011, 10:30 PM Thread Starter
Red face thanks joe one more ?
what is this vacuum line for? just noticed today[IMG][/IMG]
Anlo is offline
post #4 of 7 (permalink) Old 01-23-2011, 10:32 PM Thread Starter
another pic
Anlo is offline
post #5 of 7 (permalink) Old 01-26-2011, 04:52 PM Thread Starter
any ideas on the vacuum hose ?
Anlo is offline
post #6 of 7 (permalink) Old 01-26-2011, 05:11 PM
1996Project-bird's Avatar
EGR tubes. Not sure where they go on a mark, but on a bird they go to the passenger side under the coil pack.
1996Project-bird is offline
post #7 of 7 (permalink) Old 01-26-2011, 05:12 PM
That diagram on the fender will tell you where it goes.
