E3 Spark Plugs? - TCCoA Forums
post #1 of 25 (permalink) Old 01-27-2011, 03:26 PM Thread Starter
E3 Spark Plugs?
Has anyone tried these plugs out yet? are they even worth buying or should i just stick with the regular autolite plugs?
Any info on these would be great
newkid510 is offline
post #2 of 25 (permalink) Old 01-27-2011, 03:37 PM
chris g's Avatar
Send a message via Yahoo to chris g
I'm wondering the same thing...
COLD AIR INTAKE, MN12 PERFORMANCE FRONT SUSPENSION KIT, SILVER PAINTED AVS WINDOW GUARDS, SILVER PAINTED DASH PANELS, 28% MIRROR TINTED WINDOWS, SUSPENSION TECHNIQUES 2'' DROP, TRUE BENDS CUSTOM 2.5'' TRUE DUAL EXHAUST. 2nd generation SC wheels.
chris g is offline
post #3 of 25 (permalink) Old 01-27-2011, 03:49 PM
Mgino96tbird46's Avatar
Don't waste your money. Get Autolite or OEM Motorcraft. As another, much more experienced member here once told me, unless you have a blower, nitrous, or some serious tuning, debating spark plugs on a stock 4.6 is futile. Personally, I use Autolite AR764's. I check them every 10,000 miles. See this thread.
Mgino96tbird46 is offline
post #4 of 25 (permalink) Old 01-27-2011, 03:50 PM
chris g's Avatar
I'm runnin motorcraft platinums right now..
chris g is offline
post #5 of 25 (permalink) Old 01-27-2011, 03:53 PM
Unless you have over 35-50,000 miles on them, I'd leave them alone.
post #6 of 25 (permalink) Old 01-27-2011, 04:20 PM
Waste of money. Double plats or copper are the way to go.
post #7 of 25 (permalink) Old 01-27-2011, 04:31 PM
sousa632's Avatar
I'm running Autolite Coppers. Anything more, unless you have some power adders as said before, is pointless and a waste of money.
John
1996 TBird LX 4.6
2001 Sable Wagon 3.0 Duratec
sousa632 is offline
post #8 of 25 (permalink) Old 01-27-2011, 09:03 PM
They work good in the lawn mower!
post #9 of 25 (permalink) Old 01-27-2011, 09:11 PM
steamer471's Avatar
Yeah my chainsaw starts the first pull.
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #10 of 25 (permalink) Old 01-27-2011, 10:17 PM
Moderator & Teksid Whore
guitar maestro's Avatar
guitar maestro is offline
post #11 of 25 (permalink) Old 01-28-2011, 01:00 AM
V8ThunderCat's Avatar
I use those Autolites too!
-Randy-
V8ThunderCat is offline
post #12 of 25 (permalink) Old 01-28-2011, 01:11 AM
They are pretty good so far. Little to no electrode wear so far after 10,000 miles. They are just white. They are lasting longer than I thought they would. I thought coppers were done by 15,000 miles. Hell, I had to open the gap by a thousandth or two on a few. While we're on the subject, anyone else's plugs coming out frosted white while running on 87 unleaded with the 10% ethanol mix? I'm pulling over 21 inHg of vacuum, so I couldn't imagine there being a vacuum leak somewhere. Besides, I replaced all of the under hood rubber tubes a little while back. MAF is clean, no codes at all. I wish I had a scanner so I can see the LTFT's and STFT's.
post #13 of 25 (permalink) Old 01-28-2011, 03:16 AM
mh68's Avatar
I agree, don't waste your money. I had them and didn't notice any different than the stock plugs, power or gas wise. I even had to replace one because it went bad after 2 months.
Mike
mh68 is offline
post #14 of 25 (permalink) Old 01-28-2011, 07:21 AM
My plugs are like that, too. I always thought maybe new O2's might change that, but the Bird runs great and gets good mileage so I leave stuff like that alone. You got a pic of your plugs? I'm running Autolite plats in mine and I'll get a pic of my plugs - they've been in over a year and a half now with about 15K miles.
~Rick
TCCoA Sig
post #15 of 25 (permalink) Old 01-28-2011, 09:23 AM
Yes, I actually do in this post. I did replace my original O2's about 2,000 miles before that picture was taken. My dad, an experienced mechanic, says it's because of the ethanol, which is causing me to run a little leaner than usual.
post #16 of 25 (permalink) Old 01-28-2011, 11:40 AM Thread Starter
haha thanks guys saved me money ill stick with the regular plugs when i go to tune her up in a week
post #17 of 25 (permalink) Old 01-28-2011, 02:15 PM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Those look normal for any fuel injected engine that's running properly.
JL
Fuelly
Johnny Langton is offline
post #18 of 25 (permalink) Old 01-28-2011, 03:20 PM
JL
Even with a frosted white electrode like that? Guitar Maestro said it looks like it's running too lean like I have a vacuum leak. So maybe it's nothing to worry about for now? Either way, I'm swapping in a PI intake manifold!
post #19 of 25 (permalink) Old 01-28-2011, 03:28 PM
My plugs have had that coloring every time I've pulled them.
JL
Fuelly
post #20 of 25 (permalink) Old 01-28-2011, 04:05 PM
stay_unique_91's Avatar
Spark plugs are spark plugs. I use the Motorcraft Platinum in my T-bird. I will however upgrade to Bosch plugs for my PI Teksid once thats finished but I am also going to be running a decent shot of nitrous.
Daily Driver - 2014 Ford Mustang GT 5.0 manual black on black. Stock for now.
Current Project - 1996 T-bird LX 4.6L: PI head swap, factory 3.27 TL, tuned by Don LaSota.
Retired Car - 1995 T-bird LX 4.6L: 4v swap plus Cobra goodies
stay_unique_91 is offline
post #21 of 25 (permalink) Old 01-28-2011, 04:20 PM
ummm, no.
ever heard of different heat ranges?
different reach?
post #22 of 25 (permalink) Old 01-28-2011, 05:27 PM
Bosch = junk. Just use NGK's or Autolites. There's no performance to be had and it really isn't an upgrade.
post #23 of 25 (permalink) Old 01-28-2011, 07:44 PM
When I replaced mine a few months ago only one of them, passenger side closest to firewall, was frosted white and I think it wasn't gapped as far as the rest. When I first installed them I think I used a .60 gap but this time I think I used a .54 gap or vise versa. I'll probably pull them real soon and see how they're doing.
-Randy-
post #24 of 25 (permalink) Old 01-30-2011, 12:47 AM
I had about 5 years and 30k on my current plugs and replaced them along with wires and intake manifold. I ended up having a few that were 'white' pretty much frosted and some normal, and one that seemed oil fouled, but I probably spilled oil on the block and it went into the boot at some point.
Now while I was doing that manifold and chasing a cel for misfire, I could have trouble shot the heck out of the issue and than ordered the plugs and wires, or I could replace them, do no trouble shooting and know I have new parts, 0 aged, and 0 miles on them. I used MC plats and MC wires to replace MC plats and off brand wires.
When I did the job 5 years ago I noticed the plugs were same color coming out as going in. So maybe the previous owner did them recently, or maybe the engine was running better back than and there were less vacuum leak issues and seafoam treatments and no K&N air filter.
Regardless.... $35 that saves debate and gives piece of mind along with knowledge of resetting the clock on your plugs life is worth the $35 imo.
Now if there was no reason to pull the plugs and everything was running fine, yeah I would have kept using them until there was an issue than replaced them, but because I was already being told 'pull them and inspect them for coolant' it was kinda a no brainer to replace them once I had pinpointed the root cause of the problem and fixed it.
They probably still had life in them, but am I going to stake my engines life (and how it runs) on probably? They were most likely damaged from one or more of the issues I mentioned over the years and running a damaged part, especially after I removed it and looked at it in my hand, seems stupid. Especially when the part is cheap, and installation is reversal of removal. It's not like I won't torque down the old part, but would torque down the new part.
So yeah I use MC plats because I hate doing the job twice and I hate inspecting the part to see if it's ok or not.
Also someone mentioned that double plats are the way to go...... idk if it's true but my buddy told me not to do bosch double or quads even before I got here. I will quote him now because it makes sense.
'They claim to give you more spark and burn more fuel thus increasing fuel efficiency and hp, as if a single spark will not ignite the same fuel as much. if a single spark is not igniting your fuel you have a big problem besides debating weather or not to use double or quads. On top of that they pretty much want you to believe that your coil packs and wires are capable of a lot more spark and somehow by giving them more points to release that spark your making more spark..... No. Your taking the same electrical charge to make one spark, dividing it by 4 to make 4 lesser sparks... So yeah those 4 sparks together are probably as strong as your single, only difference is if one goes bad you have 3 more to take over. So yes you will not know you have engine problems as soon as they occur'
Made sense to me, not designed for our cars so why would they improve anything when the amount being put in is constant. Now if you got a tune and someone made sure more electricity was flowing to the plugs maybe they would work.
You could have replaced all your plugs and wires in the time it took to read this dribble :p.
Burner1515 is offline
post #25 of 25 (permalink) Old 02-17-2011, 02:57 AM
Draetech09's Avatar
I have the E3 plugs in my Tbird right now and they have outlasted all the motorcraft(platinum and copper) plugs I have used in the past. They have been in for 2.5 years now with about 10K miles. I was just curious how much better they could be for spark and gas mileage and for the money also and so far I have no complaints. Hell I even have them in my 04 Navigator now and its running great also. Not arguing just sharing my experience with them. Everybody will have there favorite and different needs for them just like motor oil.
If you Fail to plan, then you plan to Fail!
I'll forever bleed Ford Blue
Drae
Draetech09 is offline
