Which electronic sensors are most likely to fail? - TCCoA Forums
post #1 of 8 (permalink) Old 01-27-2011, 07:01 PM Thread Starter
TBird94's Avatar
I just had the MAF sensor replaced.
Instead of waiting for other sensors to fail, I would like to replace all/most sensors that are likely to fail.
Thanks!
Vehicle info:
1994 Thunderbird LX, 4.6L, with 88K miles
TBird94 is offline
post #2 of 8 (permalink) Old 01-27-2011, 07:59 PM
The MLPS and original DPFE sensor (aluminum box) are the only sensors likely to fail. Oxygen sensors have a lifespan of around 100k miles, so they "wear" out. Otherwise, everything that fails is just chance, age, and/or neglect.
post #3 of 8 (permalink) Old 01-28-2011, 07:49 AM
Not a sensor, but.....
..... on my 95, the EGR tube got plugged at the orifice between two little DPFE tubes (signal and reference I believe they are called).
I've also had to replace:
ECM - twice
DPFE
MAF
Charcoal canister flow valve (or flow sensor - don't remember which one)
Plugs and Plug Wires
Air filter
Fuel filter
Thermostat, ECT Sensor, Water Pump, Radiator, Electric Fan, Accessory Belt, Relay Module, and missing Air Dam (when I was having an overheating problem in the hot Florida summers)
Oil filter adapter gasket (infamous on ALL 4.6L engines)
Valve guide seals (infamous on pre-F5 4.6L heads)
PCV valve & PCV valve grommet
misc. vacuum lines
Trigger wheel and Crank Position Sensor
Battery
Odometer gear in dash (another infamous thing in these cars)
Hinge pins
Sway bar links
Control arm bushings
Headlight assemblies
Upgraded a bunch of stuff that wasn't necessarily NEEDED
I'm sure there were other things I'm just not remembering at this moment.
~Rick
TCCoA Sig
post #4 of 8 (permalink) Old 01-28-2011, 08:07 AM
bowez's Avatar
On a 89-93 SC ICM.
Though the must common is going to be O2.
The oil pressure sending unit is a common one too
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #5 of 8 (permalink) Old 01-28-2011, 08:10 AM
Roadrunnner's Avatar
Crank position sensor should be on the list.
Will
Roadrunnner is offline
post #6 of 8 (permalink) Old 01-28-2011, 08:15 AM
Oh yeh, I did have to replace the CPS on mine. Of course, I also shattered the trigger wheel which broke the sensor, otherwise I'm sure it would still be good (it's not a wear item).
Of course, when I installed the UDP's on my car, I'm pretty sure that's the reason I had the trigger wheel/crank position sensor problem. If I had not disturbed anything down there (and torqued the damper properly), I wouldn't have had that issue.
~Rick
TCCoA Sig
post #7 of 8 (permalink) Old 01-28-2011, 08:22 AM
Ive done them on 4 times on 3 different birds. I guess one doesnt count, as I had a bad sensor and had to redo it
Will
post #8 of 8 (permalink) Old 01-31-2011, 01:21 AM Thread Starter
TBird94's Avatar
Thanks guys!!!
TBird94 is offline
