Rpm Switch - TCCoA Forums
post #1 of 6 (permalink) Old 01-31-2011, 08:06 PM Thread Starter
TRex94's Avatar
Rpm Switch
Hi all, I recently had a 98 Mark VIII engine installed in my 94 Bird 4.6, it has the stock 94 computer and harness, what I need is a RPM switch, I need to know which one works for my application and how it's hooked up. Thanks, Steve
TRex94 is offline
post #2 of 6 (permalink) Old 01-31-2011, 09:20 PM
MSD P/N 8950. Does the '98 run the cable actuated IMRC's or the vacuum operated ones? I can't remember off the top of my head.
post #3 of 6 (permalink) Old 01-31-2011, 09:48 PM
Cable
post #4 of 6 (permalink) Old 02-01-2011, 08:48 AM Thread Starter
TRex94's Avatar
Thanks guys, just 1 question, how does it plug in to intake? is there a sensor on the manifold that it plugs into?
TRex94 is offline
post #5 of 6 (permalink) Old 02-01-2011, 08:59 AM Thread Starter
TRex94's Avatar
went to Jegs found the rpm switch p/n 8950 but it said an RPM Module is required, is this true with my application?
TRex94 is offline
post #6 of 6 (permalink) Old 02-01-2011, 04:20 PM
It will need to be wired in to operate the IMRC controller. With the vacuum operated IMRC's it was as simple as applying/removing -12V (ground) to the vacuum solenoid. I haven't looked into controlling the cable operated ones.
Yes, you'll need the "pill" for the rpm point at which you want the switch to activate. Typically on a stock 4V, anything in the 3200-3400rpm range is a good choice.
