87 5.0 tbird fuel pump wont shut off. - TCCoA Forums
post #1 of 2 (permalink) Old 02-01-2011, 03:56 PM Thread Starter
A buddy of mine just got a 87 5.0 thunderbird. It runs and starts just fine. But it drains the batter fast. We got looking for a humming noise it was making and found out the fuel pump was not shutting off. I have read that is could be a stuck or bad relay. But we cant find where it is located. Can any one tell me where it is or if there is any thing else that could be causing this problem.
91 SC 5 Speed: 3" drop springs, 10% OD blower pulley, 3.5" cold air intake, C&L 85mm MAF, MP 85mm TB, KW double IC, Walbro 255 lph fuel pump, #42 injectors, Mach One hood, saleen mustang wing, Solid Rubber Motor & TransmissionMounts, Autodown Windows, Auto open moonroof, March underdrive pullies Plug and play key less entry module.
91 Car Domain: http://www.cardomain.com/ride/390762...super-coupe-2d
00 Explorer Sport: Wife's Daily Driver
00 Car Domain: http://www.cardomain.com/ride/392408...ort-utility-2d
R1dd1cK is offline
post #2 of 2 (permalink) Old 02-01-2011, 05:10 PM
1987 Mustang Fuel Pump Relay Location
EDIT: Oops, I screwed the pooch on that one. You asked for a 1987 THUNDERBIRD.
On a 2.3 turbo thunderbird, and the most i know is there is a "pink, black" wire that is the main power, to find that, you access the trunk and bolted behind the seat is 2 metal boxes, undo those and you should be able to find the wire and follow it to the relay
The relay should be under the driver seat on the floor its a little black box with a plug on one end.
(copied from Answers.com)
~Rick
TCCoA Sig
