Broken Bolt Removal - TCCoA Forums
post #1 of 11 (permalink) Old 02-16-2011, 09:59 AM Thread Starter
Broken Bolt Removal
Ok, so a month ago, while doing my front end rebuild, motor mount replacement, sway bar installation, etc. I broke off one of the motor mount bolts flush with the aluminum block.
Just today, I had my welder buddy come out and TIG weld onto the remains in an attempt to get the bolt out. NO LUCK!!
He said the bolt just keeps breaking off. He has done this a lot and is very familiar with what needs to be done. He heated the block, but he said probably not hot enough since all I had was a small propane torch.
I have NEVER had any luck with an easy out and I'm not comfortable drilling and tapping at those weird angles...
So I’m open to suggestions as I REALLY don’t want to pull the engine!!!
(But if I do, I’ll rebuild it, pop the Cobra intake on it and bolt it to the T-45)
69 F100 LWB w/460 Engine
post #2 of 11 (permalink) Old 02-16-2011, 11:07 AM
Dan Nelson's Avatar
Weld a nut to it with stick rod, Lincoln Excalibur 11018, then spray it with pb blaster let it cool and slowly work it back and forth intel it breaks free. if its to short to weld the nut on then carefully build it up with stainless rod intel you can get to it, i use this method at work all the time, on the larger bolts i drill all the way threw them then weld the hole back up and it shrinks the bolt, then weld the nut to it and they usually come right out.
Dan Nelson is offline
post #3 of 11 (permalink) Old 02-16-2011, 01:38 PM
dDUBb's Avatar
2 out of 3 bolts aint bad .. no just kidding. I hate broken bolts.
Heat + Parafin wax ( not candle ) .. works wonders on Pipe thread bolts in the engine block .. you let it suck up the wax and the bolt usually threads out without tools.
Easy out ( They are never easy ) ... heres a couple tips if you do this route. Use a nice center punch to get a good start. Start drilling 90 degrees Directly to the Angle the bolt broke off on, and work your way slowly in until you get it straight with the bolt angle. Drill SLOWLY, no fast drilling .. use motor oil for cutting. .. Use the proper size Drill bit for the EZ out you are using. If possible, use a Brand NEW EZ out, or drill bits ... last thing you want is a Broken EZ out or a drill bit broken off inside the bolt you are trying to remove.
.. hope this helps.
dDUBb is offline
post #4 of 11 (permalink) Old 02-16-2011, 01:58 PM Thread Starter
Yep that will work... Oh wait, that is what I'm going to do...
After a long discussion with my welder buddy, we decided to plug weld the motor mount to the bolt.
He said that bolt is either going to take the treads with it, or crack the boss, or crack the boss AND take the threads with it. Either way, the hole would be ruined and require more work...
Hopefully that will hold until I are more ready to actually pull the engine. I'm sure when I do, I'll break off bolts in the heads (exhaust manifolds), and who knows what else.
post #5 of 11 (permalink) Old 02-16-2011, 02:10 PM
1996Project-bird's Avatar
I broke one bolt on my exhaust with a breaker bar, and for the rest of my time I took apart my engine, I used an electric impact gun and didn't break another one and I am up in the rust belt. So if you are going to give it another shot by welding a nut onto it then try an impact. Unless you already have, in which case disregard my rant here.
1996Project-bird is offline
post #6 of 11 (permalink) Old 02-16-2011, 02:13 PM Thread Starter
Yeah, he left a nut welded on, so I'm going to try heat, PB Blaster, electric impact (which is a POS for an impact wrench, but might be perfect for this), heat, treat, wrench, etc. until the nut snaps off or the bolt comes out.
Crossing fingers!!!
post #7 of 11 (permalink) Old 02-16-2011, 02:23 PM
Crossing fingers!!!
Just use short bursts at first. try to finesse that SOB out of there. Good luck. Hope it comes out.
post #8 of 11 (permalink) Old 02-16-2011, 06:34 PM
Moderator & Teksid Whore
guitar maestro's Avatar
Repairing it is the easy part. On one of my blocks with a stuck bolt, I couldn't extract the bolt because I messed up the center hole for the bolt-extractor. So I ended up drilling it all out, messed up the threads, so I tapped it for two autozone fix-a-thread inserts, and its stout now.
guitar maestro is offline
post #9 of 11 (permalink) Old 02-16-2011, 07:49 PM
Banned
Send a message via Yahoo to ThunderRoad
Cool If Your Drill With A Reverse Drill Bit
THE TWIST IS REVERSE A GOOD HARDWARE STORE SHOULD HAVE A SET..... WITH A REVERSE DRILL MOTOR .....START SMALL AND WORK YOUR WAY UP USING RUST CUTTING SPRAY OR DW-40 PLENTY OF IT
ThunderRoad is offline
post #10 of 11 (permalink) Old 02-16-2011, 09:49 PM
mercury267's Avatar
I don't know about anyone else, but I've gotten out of this in the past by drilling.
Get a metal punch on the broken bolt to start a mark for a drill bit. Use a good sharp bit on a low speed drill and oil it while drilling. The vibration will also help work the oil into the threads.
Once this hole is drilled, make it larger with the correct bit for the "bolt extractor" bit needed for that size bolt - make sure you are down good and deep into the bolt.
Heat the snot out of that bad boy and hit it with oil and then tap with a hammer to work the oil in. Do this about a half dozen times and then use the bolt extractor lowly to ensure good bite.
This should get that bolt out like it ain't even stuck. Good luck.
"Behold, I am coming quickly..." Rev. 22:12-13NKJV
- Jesus Christ
My 95 LX project car
mercury267 is offline
post #11 of 11 (permalink) Old 02-16-2011, 11:28 PM
Drilling and a bolt extractor has always freed me from these situations. If the threads come with the bolt oh well, slide the drill bit in, tape around the bit as a depth mark, weld the fubar'd hole, drill it again slightly undersized, cut/tap new threads, chase new threads, lubricate new hardware, enjoy.
