Vents not working!! - TCCoA Forums
post #1 of 5 (permalink) Old 03-01-2011, 08:24 AM Thread Starter
Vettecor's Avatar
Vents not working!!
I have a 1991 Ford T-bird with factory a/c. Nothing is coming thru the vents when I select max a/c, norm a/c, or vent. The a/c is blowing cold air but its coming thru the floor, just like the heat does. Defroster works fine and blows air on the windshield.
Anybody know whats causing this and how to fix?
Larry
Vettecor is offline
post #2 of 5 (permalink) Old 03-01-2011, 08:26 AM
It's a problem with the vacuum motors and blend doors in the dash. One of the vacuum lines may have worked free from one of the motors, one of the motors may have stopped working, or the linkage between one of the motors and the door might have broken.
To fix it you'd need to look around inside the dash to identify the issue. If it's simply a line that worked loose it's as simple as reattaching it. If one of the blend doors is broken that usually entails removing the dash to have it replaced.
post #3 of 5 (permalink) Old 03-01-2011, 09:58 AM
I have the same issue.
I dont want to pull the dash..
1994 Ford Thunderbird LX 4.6L - Junked
1997 Ford Thunderbird LX 4.6L - SOLD
1999 Merc Grand Marquis - DD
2003 Ford Expedition XLT 5.4L - Chicks Tank
2000 Ford Mustang GT 4.6L - Racecar
GT_any is offline
post #4 of 5 (permalink) Old 03-01-2011, 10:07 AM
where are these vacuum motor located in the dash? any tech write ups?
GT_any is offline
post #5 of 5 (permalink) Old 03-01-2011, 01:44 PM
The motor is accessible from the drivers footwell, the motor's right behind the secondary junction box wiring with a yellow vacuum line going to it.
