Rebuild of Wiper Transmission - TCCoA Forums
post #1 of 1 (permalink) Old 03-06-2011, 07:29 PM Thread Starter
Here's a quickie from my replacing the bushings on the wiper transmission on my 1991 Cougar XR7.
I haven't found the original replacement bushings, so I started with a universal bushing set from the HELP! family, so I'd have an assortment:
Turns out the ones I used, which the set had three of, were this one:
But they didn't fit as picked up. So I had to modify all three like this:
(Notice I cut two ears off, opposite each other.)
One ball had a post on it, so I had to drill out one of the caps to clear:
After the build, I checked the Dorman products site, and located these bushings by themselves:
Jeep Wiper Bushings
Well a trio you can use, and a trio you can toss, anyway.
No pictures of the work - I was too busy making it work
However, I used a big screwdriver to pop the arms off, and use a moly lithium blend to lubricate the bushings.
Now my wiper blades work like they're supposed to, and stop in the exact same place every time.
The one I drilled, I drilled with a 7/64" bit to make sure there was some extra clearance.
I don't THINK that'll be a problem, but if it binds up later, I assume no responsibility for it I thought it might be instructive to see what others are doing.
RalphP is online now
