Q: What's this red module box sitting under my A/C Blower? - TCCoA Forums
post #1 of 19 (permalink) Old 03-06-2011, 07:44 PM Thread Starter
S4gunn's Avatar
In a bid to remove as much weight off this car as possible, I cut away at a chunk of my dash and have been digging into it.
One box that I have yet to identify is this red module that is mounted horizontally underneath my heater/ac blower unit.
Can one of you tbird experts identify it for me? I tried looking through my service manual but haven't gotten any promising matches (I've already identified and removed the airbag diagnostic module aka the vertical blue box since I've already removed the airbags.
Thanks in advance,
-g
PS. Don't forget that I have plenty more bits of stuff from my tbird to sell. If you need it, I'll cut you a good price as every penny will help support my 24 Hours of Lemons effort.
S4gunn is offline
post #2 of 19 (permalink) Old 03-06-2011, 07:50 PM
Chime module?
That's about where mine is, anyway, in the 1991.
RalphP is online now
post #3 of 19 (permalink) Old 03-06-2011, 08:02 PM
Wrong! Cruise control amplifier
post #4 of 19 (permalink) Old 03-06-2011, 09:11 PM Thread Starter
S4gunn's Avatar
Excellent. I don't need cruise control. More weight savings!
-g
S4gunn is offline
post #5 of 19 (permalink) Old 03-06-2011, 09:47 PM Thread Starter
S4gunn's Avatar
BTW, looking at the manual about the cruise control system makes me believe that I can also remove the cruise control servo from under the driver's side front fender.
If I do remove this module, all I need to do is block off the two vacuum hoses on the engine, right (according to my manual, one goes to the intake manifold and the other to a distribution block of vacuum points between the engine and the firewall.
Q: Am I correct in this reasoning (removal of the cruise control servo will NOT affect the normal driving of the car since it's a manual linkage)?
Q: Do you guys have any suggestions on the best way to plug a vacuum line? A quick search online suggests vacuum caps (cost money), screws with silicone, and just rerouting the hose.
Is there any reason why I can't just cut the hose and run one opening and connect it to the other (vacuum to vacuum)? if not, I'll just use the screw + silicone method (it's free).
Thanks in advance,
-g
S4gunn is offline
post #6 of 19 (permalink) Old 03-06-2011, 09:48 PM
I would probably use a small bolt or screw threaded into the end.
post #7 of 19 (permalink) Old 03-06-2011, 10:41 PM Thread Starter
S4gunn's Avatar
So, I'm a bit OCD so I couldn't resist going down into my garage.
I have a 1995 Ford Thunderbird LX and the 1995 Ford brand service manual.
From what I understand from the manual, the servo control should have the following connections:
* electrical connector (goes to the front near the radiator support)
* Throttle cable (goes to the throttle)
* One vacuum connection that goes to the engine bay
* One vacuum connection that goes into the firewall (presumably according to the manual to connect to the speed control dump valve at the top of the brake pedal).
On page 10-03-18, the vacuum hoses on the 3.8L engine go to some kind of vacuum junction box from the "speed control actuator" and the line from the servo presumably goes to the intake manifold.
Well, when I looked at my car, I found all the same connections (vacuum line to firewall, throttle cable line, electrical harness line) EXCEPT the vacuum line that goes into the engine bay plugs straight into the brake booster.
Q: Are such discrepencies between the car/service manual normal?
Was there some kind of mid-year change or something that would account for a missing vacuum junction box looking thing that sits between the engine and the firewall + a different vacuum routing?
Thanks in advance for your replies.
Either way, it's another mini-project for me (cruise control removal). The servo looks like it weighs a few pounds.
S4gunn is offline
post #8 of 19 (permalink) Old 03-07-2011, 08:33 AM
Roadrunnner's Avatar
So whens the race? Post some progress pics?
Will
Roadrunnner is offline
post #9 of 19 (permalink) Old 03-07-2011, 09:12 AM Thread Starter
S4gunn's Avatar
It's not very impressive just yet compared to some of the builds here but here's the highlight reel:
The guy in the pic is one of my team members digging into the front wheel for the n-th time
http://www.gunn.com/lemons_bestofthebuild
S4gunn is offline
post #10 of 19 (permalink) Old 03-07-2011, 09:40 AM
Looks like you have nice old stang to.
Will
post #11 of 19 (permalink) Old 03-07-2011, 11:54 PM Thread Starter
S4gunn's Avatar
That rust bucket is another team members. I honestly think the paintjob is what's holding that thing together.
I originally tried to get him to consider selling that car to me for Lemons but for some reason he claims it has sentimental value.
-g
S4gunn is offline
post #12 of 19 (permalink) Old 03-08-2011, 08:40 AM
Well the pics make it look nice.
Will
post #13 of 19 (permalink) Old 03-09-2011, 03:33 PM
90coug's Avatar
That's so Big Brother can watch your every move.
'95 SC
90coug is offline
post #14 of 19 (permalink) Old 03-09-2011, 07:06 PM
Big Brother doesn't need a box to watch you! Ever used Google Earth? If that's available to us "civilians", think what Big Brother has access to!
I'm just saying. Just because you're paranoid doesn't mean they aren't really watching you!
~Rick
TCCoA Sig
post #15 of 19 (permalink) Old 03-09-2011, 07:17 PM
Here's something slightly on yet slightly off topic.
The other day I was fixing the recirc door and I came across this connector. What's it for?
post #16 of 19 (permalink) Old 03-10-2011, 08:34 AM
Maybe that's the plug that disables the speed limiter, lol.
Grog6 is online now
post #17 of 19 (permalink) Old 03-10-2011, 09:49 AM
POL PKG plug?
post #18 of 19 (permalink) Old 03-10-2011, 11:37 AM
BoppinVinnieB's Avatar
1995 Ford Thunderbird LX - Bought in '06 with only 20k on the clock!
BoppinVinnieB is offline
post #19 of 19 (permalink) Old 03-10-2011, 12:02 PM
POL PKG plug?
Gee guys, I never would have thought!
I was thinking either EVO or airbag related being that all the modules are over there?
