Keyless Entry Remote Programming - TCCoA Forums
post #1 of 16 (permalink) Old 03-31-2011, 09:50 PM Thread Starter
Banned
not sure how to program it. picked one up brand new from the Mercury/Lincoln dealer by my job. the parts manager said i have to turn the key 5-8 times, then doors will lock and then push lock on one remote then the other.
i did that process and did not work.
any advice?
94soupecoupe is offline
post #2 of 16 (permalink) Old 03-31-2011, 09:52 PM
Turn the key to on. Open the trunk, pull the carpet out on the left side slightly and look for a small two pin connector on the side of a box. Short out the two pins on the connector and listen for the locks to cycle. Press a button on the remote and it should cycle the locks again to indicate successful association of the fob. Repeat for all fobs being programmed. Turn key off and the locks will cycle once more to indicate completion of the programming cycle.
post #3 of 16 (permalink) Old 03-31-2011, 10:01 PM Thread Starter
Banned
okay, gona give it a try tomorrow after the rain stops. any issues will post up.
thanks alot! much appreciated!!
post #4 of 16 (permalink) Old 03-31-2011, 10:42 PM
Earl's Avatar
The programming info the parts guy gave you would be correct for the NEW (as of 98+ or so/PATS) keyless system
Earl is offline
post #5 of 16 (permalink) Old 04-07-2011, 12:01 AM Thread Starter
Banned
i couldnt find the connector. any way someone could get me a picture of it for me?
post #6 of 16 (permalink) Old 04-07-2011, 12:21 AM
Connector
Assuming you have the car in your signature, the connector is located behind the trim in the trunk on the drivers side. It is near the fuel pump shut-off (inertia) switch. As stated it is a two wire connector. The wires should be Gray with yellow stripe and White with yellow stripe. The connector looks like it may be below the bracket that holds the Anti-theft and or Keyless entry module(s). It may have fallen off of the bracket and is laying low in the well area.
5.4LDOHC is offline
post #7 of 16 (permalink) Old 04-07-2011, 10:07 AM
It's attached to the left side of the black holder that holds the theft and door modules.
Search, there are pix.
post #8 of 16 (permalink) Old 04-17-2011, 03:38 PM Thread Starter
Banned
finally have a chance today to look into it. will post of any issues.
post #9 of 16 (permalink) Old 04-17-2011, 04:43 PM
Programming Key FOBs 1995 Thunderbird
Programming - Transmitter
Before any of the RKE features will operate, the RKE module must be programmed to accept signals from the transmitters. The RKE module may be programmed to accept signals from up to four transmitters. The following steps must be performed in order to program or reprogram the RKE module to respond to the selected transmitters:
Put the ignition switch in "RUN" or "ACC" and momentarily jumper the two terminals of the programmer connector (located in the LH side of the trunk, next to the remote/keyless entry module). The system will respond by locking and then unlocking all doors.
Press any button on the transmitter. All doors will lock and then unlock to verify transmitter signal acceptance.
Repeat step 2 to program the RKE module to accept up to four transmitter signals.
Turn the ignition switch to "OFF". All doors will then lock and unlock.
Operate a button on each transmitter to verify that the system has been programmed successfully.
~Rick
TCCoA Sig
post #10 of 16 (permalink) Old 04-19-2011, 12:19 AM Thread Starter
Banned
found the connector with the wires. how do i go about "jumping" the terminals? i dont wanna cause any electriclal issues. had waaayyy to many with my 94 SC
post #11 of 16 (permalink) Old 04-19-2011, 12:26 AM
I always just used a paper clip
post #12 of 16 (permalink) Old 04-19-2011, 11:11 AM
Jumpering terminals
There should be just two terminals/wires in the connector. Just touch them together. If there are more than two terminals, you have the wrong connector.
Once this is done, NetKeym 's procedure should work except that the 95 workshop manual I have says this;
Turn ignition switch to RUN or ACC position and momentarily short the two terminals of the Program Connector (C4) (a two-pin connector is taped to the wire assembly and can be reached by removing the LH luggage compartment trim panel). The connector is attached to the relay mounting panel (14B144) . All front doors should lock then unlock. Remove shorting pin.
Hope this helps.
5.4LDOHC is offline
post #13 of 16 (permalink) Old 04-19-2011, 07:15 PM
Hope this helps.
I took my procedure straight from Alldata which gets it's info from Ford. If it doesn't work, I don't know why because we pay thousands of dollars a month for Alldata and it hasn't been wrong yet.
~Rick
TCCoA Sig
post #14 of 16 (permalink) Old 04-19-2011, 09:43 PM Thread Starter
Banned
raining once again today.... dont wanna mess with electronics in the rain. gonna try this tomorrow hopefully.
i appriciate all the advice guys! maybe this can be a stick post? help out others who need to program their remotes
post #15 of 16 (permalink) Old 04-19-2011, 09:48 PM
I doubt it'll get stickied... there are at least a dozen more threads with this information already in them that can be found by searching for "keyless remote programming".
Something that MIGHT get stickied is a thread that holds links to threads with all the common procedures and whatnot in it. It's hard to judge what the mods deem to be sticky-worthy. There is a sticky similar to that in the newbie forum though.
But like I mentioned, most here say "search" when it comes to common information. Most people look right over the stickies that are there and start new threads anyway....
post #16 of 16 (permalink) Old 04-19-2011, 10:41 PM
Remote programming
No disrespect meant! I've seen errors in both Ford shop manuals and Alldata. Just wanted to add additional info if the first try didn't work.
5.4LDOHC is offline
