Speed limiter - TCCoA Forums
post #1 of 17 (permalink) Old 04-01-2011, 08:27 PM Thread Starter
Rodolfo's Avatar
Post Speed limiter
Hi! Is there any speed limiter intalled on my 91 5.0? Something happens after 100 mph...
Rodolfo is offline
post #2 of 17 (permalink) Old 04-01-2011, 08:37 PM
It seems to vary, but yes. Between 105 and 112 is usually where it kicks in. The speed limiter is mostly to protect the drive shaft.
post #3 of 17 (permalink) Old 04-01-2011, 08:56 PM
Not exactly.
Well ... the speed limiter is to protect the DRIVER, any passengers and the general public from driveshaft failure in addition to the speed rating limitations of the stock tires. The last thing you want is for a driveshaft or tire to fail at those speeds.
There are numerous mechanical and safety reasons for the speed limiter.
post #4 of 17 (permalink) Old 04-02-2011, 02:08 AM
Tbird1997's Avatar
lol duh isnt there a speed limiter on all stock factory cars?..
sorry seems like a redundant question..
-Patrick
Tbird1997 is offline
post #5 of 17 (permalink) Old 04-02-2011, 06:46 AM Thread Starter
Rodolfo's Avatar
So... The better way to bypass the limiter ir installing a new chip on the ECU?
Rodolfo is offline
post #6 of 17 (permalink) Old 04-02-2011, 07:25 AM
The question to ask is why do you need to go that fast? Do you take the car to the strip? Have you upgraded anything?
post #7 of 17 (permalink) Old 04-02-2011, 07:33 AM
The speed limiter has absolutely nothing to do with the driveshaft. If the driveshaft fails from high speed, what happens is the crimp joint becomes loose and slips, which mis-aligns the u joints and it causes a bad vibration similar to what a bad u-joint feels like, but it will not fail in such a way that it would cause an accident. It has never happened, and never will, but for some reason this myth has been propagated on this forum since day one. The reason the speed limiter is there is due to the tires, and only the tires. The factory installed S rated tires are only rated to 112mph, so a 105-109mph speed limiter will help insure that you don't overheat the tire and cause a blow out at high speed. That is why the SCs, which have the exact same driveshaft but have H rated tires, which can withstand 130mph, don't have that speed limiter.
post #8 of 17 (permalink) Old 04-02-2011, 08:01 AM
bowez's Avatar
I can attest that some (at least one) 5.0 cars don't have them.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #9 of 17 (permalink) Old 04-02-2011, 08:30 AM
95xbird's Avatar
I ran the stock driveshaft on my car for years with the supercharger,3500 stall and 3.73's. Many runs well into the triple digits not to mention countless launches and track time. Never broke. Just vibrated after 80mph.
I believe the fastest I went on a stock shaft was 120ish mph. That with 3.73 gears over the stock 3.27s was more like 130-135 for the driveshaft. <---thats just a guess seeing after the gears it topped out at 92mph before my tune.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
post #10 of 17 (permalink) Old 04-02-2011, 09:31 AM
I spun a stock driveshaft inside itself. Stock engine, locker rear, entrance ramp in second. I thought it was the clutch shell, lol. Highway driving kills them quick.
I also had another car's DS do the wobble thing mentioned above, and it caused the tranny rear seal to die, the diff to wear really quick, and a strange wear pattern on the rear wheel bearings.
Before driving at high speeds, I'd make sure you have good shocks, the DS is upgraded, the front and rear uca and lca bushings are in good shape (Hell, the whole front suspension), as well as good tires.
post #11 of 17 (permalink) Old 04-12-2011, 06:44 PM Thread Starter
Rodolfo's Avatar
OK, guys. So, do I need to change the DS to a Mark 8 one?
Rodolfo is offline
post #12 of 17 (permalink) Old 04-12-2011, 08:48 PM
tbirdtess's Avatar
shaft
Hi
My shaft came from a Torino. So did the C4 & 351w
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #13 of 17 (permalink) Old 04-12-2011, 09:01 PM
MarkVIII driveshaft won't work because it is a different length. If you want to upgrade your driveshaft to an aluminum one, it will have to be aftermarket as there is no factory installed aluminum driveshaft that is the correct length. However the only real reason to upgrade the driveshaft is if you are getting vibration issues with your stock one.
post #14 of 17 (permalink) Old 05-27-2011, 04:28 AM
jjmitch87's Avatar
Send a message via AIM to jjmitch87 Send a message via MSN to jjmitch87 Send a message via Skype™ to jjmitch87
not all cars have speed limiters from the factory. the car i had before i got my bird this past monday didnt. 93 taurus sho. says it tops out somewhere around 143mph. after 138ish i backed off, close enough.
jjmitch87 is offline
post #15 of 17 (permalink) Old 05-27-2011, 10:46 AM
I forget the pcm code but there are 93 marks without speed limiters.
post #16 of 17 (permalink) Old 05-27-2011, 02:36 PM
Can't you bypass a limiter?
John Fritz is offline
post #17 of 17 (permalink) Old 05-27-2011, 02:53 PM
Rayo's Avatar
Originally Posted by Lonnie
Bypassing the speed limiter
You need to place a mini switch inline of the Vehicle Speed Sensor VVS signal to the Electronic Engine Control EEC. This wire is identified by the connector going into the EEC. Look for the numbers at the one end of the plug 41 21 1. The wire you want is #3. So start at wire 1 and count to 3. The color of the wire should be dark green with a white stripe. Do not just cut the wire and leave it. This signal also controls your Idle Speed Control Solenoid ISC or the air bypass valve, while the car is at a stop at idle or the A/C is on. So it could cause you to stall if in the bypass mode while at a light or stop.
This method only works on 91-93 5.0 Thunderbird and Cougar's
Rayo...
1991 Ford Thunderbird Sport
Rayo is offline
