Ignition switch? - TCCoA Forums
post #1 of 4 (permalink) Old 04-03-2011, 04:24 PM Thread Starter
ROLLINTHUNDER's Avatar
Ignition switch?
Started my bird to move it today. Turned it off and went to start it shortly after and it wont turn over. Battery is charged and everything is in order but a couple times before I would have to hold the key all the way over like you are going to start it and wait a few seconds befroe it actually would start cranking. Sound like the ignition switch or key and tumbler set? Thanks guys!
ROLLINTHUNDER is offline
post #2 of 4 (permalink) Old 04-03-2011, 05:04 PM
On a 95? Search for threads on the linkage coming loose or breaking in the steering column also, but it's that or the switch.
RalphP is offline
post #3 of 4 (permalink) Old 04-04-2011, 09:02 AM
Paddycake's Avatar
hey before you tear apart the collumn. check the 2 large wires running to the starter. I had this issue and the wires were grounded out on the engine K member(subframe), they were also corroded inside the insulation and had a lot of resistance.
keep in mind the starter takes more juice to spin than anything else your car has. One last thing to try if the car sat more than a few days the solenoid may be gummed up a little tap the bugger with a long broom handle(no need to jack car up) used like a pool cue.
No matter how good she looks. No matter how cool she is about your "stuff". No matter how great she is in bed, someone somewhere is sick of her crap.
1995 850R with 18T, 3" downpipe, R.I.P. kit, ported intake,42lb injectors, N/A cams, 960 throttlebody, Rica tune(15psi in first and second 17psi in third and fourth). Bilsteins all around, V70R caliper and rotor upgrade, total lack of traction. IPD STB, Ultra Racing lower braces and RSTB.
Paddycake is offline
post #4 of 4 (permalink) Old 05-28-2011, 07:42 AM
jjmitch87's Avatar
Send a message via AIM to jjmitch87 Send a message via MSN to jjmitch87 Send a message via Skype™ to jjmitch87
this happened to me once so far. im gonna go with the switch/tumblers in the column as being the culprit.
you kno when you turn the car off and take the key out n then open drivers door and if you left your lights on it dings? mine dings even when the lights are off! and if i wiggle the key inside a certain way i get it to stop for half a second
97 green, 4.6L sport package. k&n cold air from an 01gt. so far my best at the strip was 15.808 @ 89mph at new england dragway.
jjmitch87 is offline
