Rubber ducting under front bumper - TCCoA Forums
post #1 of 18 (permalink) Old 04-15-2011, 02:06 PM Thread Starter
Andy625UK's Avatar
I took the rubber ducting under the front bumper off of my car to get to the bottom radiator hose clip last week. Its the bit that goes between the two strut rod fixings, attaches around the stabiliser bar in one place, and also attaches to the rear edge of the front bumper with plastic rivets. It was a bit torn and not particularly well fixed in place, but could be used again.
Just wondered if the rest of you guys still have it fitted to your cars, or if you've taken it off??
"...put me on a highway, show me a sign, and take it to the limit one more time"
The Eagles
1975
http://www.cardomain.com/ride/2149821
RIP Dutch T-Bird (Robert Hendriks) 1970-2012 No doubt looking down on us from his low-riding T-Bird in the sky.
Andy625UK is offline
post #2 of 18 (permalink) Old 04-15-2011, 02:18 PM
I got rid of mine once I realized it didn't effect cooling whatsoever or keep moisture out of the engine bay. Just make sure you keep the spoiler part of it, that does effect cooling.
post #3 of 18 (permalink) Old 04-15-2011, 02:53 PM
Earl's Avatar
I remember that darn thing falling down and dragging on my first bird ten years ago...took it off...took the same thing off my old 95 bird...amd that piece was long gone on my current bird by the time I got it...
Earl is offline
post #4 of 18 (permalink) Old 04-15-2011, 04:33 PM Thread Starter
Andy625UK's Avatar
OK Sounds like I don't need to worry about it "disrupting the airflow" or anything then. Glad to hear it!
The Eagles
1975
post #5 of 18 (permalink) Old 04-15-2011, 05:56 PM
I kept mine on, I tend to not take things off of the car unless I have to.
275hpsctbird is offline
post #6 of 18 (permalink) Old 04-15-2011, 09:31 PM
1996Project-bird's Avatar
Ha. Mine fell off on the way home from the beach one day. Made an awful rattling that I couldn't find then poof. It was gone.
1996Project-bird is offline
post #7 of 18 (permalink) Old 04-17-2011, 03:35 PM Thread Starter
Andy625UK's Avatar
I changed my oil yesterday and decided that as the ducting was all in one piece and I still had all the fixings, I might as well refit it. When I had a closer look the metalwork around the radiator (that wasn't visible until I'd removed the ducting) I found that it was quite rusty or had flaky paint, so I gave it a rub down primered and painted it before putting everything back.
One thing I did think as that is seemed like the front valance should be attached to the flexible rubber duct under the radiator. It's all firmly fixed but it almost seems like there should be something linking the two pieces together?
The Eagles
1975
post #8 of 18 (permalink) Old 04-21-2011, 04:57 AM Thread Starter
Andy625UK's Avatar
Forgot to ask last weekend, but while I had the front valance lower cover off, I noticed a spare lead coming out of the wiring loom with a two way connector on the end of it, next to the washer bottle pump loom. Its not the washer pump connector - thats already connected up. Just wondered what else it could be? Fog lights or something??
The Eagles
1975
post #9 of 18 (permalink) Old 04-21-2011, 09:03 AM
Combatspace's Avatar
I would think that based on the placement you described, it would be for fogs, but I can't say I've seen a 'bird with factory fogs...
Combatspace is offline
post #10 of 18 (permalink) Old 04-21-2011, 09:11 AM Thread Starter
Andy625UK's Avatar
I thought at first I'd pulled the wires off of the washer pump, but the connector clearly hadn't been fitted to anything for a long time, judging by the dirt in it. Also, the washers still work with it just tucked back under the valance as it was before.
The Eagles
1975
post #11 of 18 (permalink) Old 04-21-2011, 09:23 AM
That's for the coolant level sensor for the 3.8 reservoir.
post #12 of 18 (permalink) Old 04-21-2011, 09:31 AM Thread Starter
Andy625UK's Avatar
Aha! That solves that then! Thanks.
The Eagles
1975
post #13 of 18 (permalink) Old 04-21-2011, 04:30 PM
Mgino96tbird46's Avatar
Mine is still sitting in the garage. I've never gotten around to putting it back on after scraping off the retaining clips from hitting a dip too fast.
Mgino96tbird46 is offline
post #14 of 18 (permalink) Old 04-21-2011, 06:07 PM Thread Starter
Andy625UK's Avatar
Those retaining clips aren't the best invention in the world, but you may as well refit it, if its in one piece.
The Eagles
1975
post #15 of 18 (permalink) Old 04-21-2011, 09:54 PM
It does make a difference; on my daily drive, the car runs cooler with it on. (interstate, 70+)
There's a slight trend in the gas mileage, but it's barely over 2 sigma; not much diff if any.
Grog6 is online now
post #16 of 18 (permalink) Old 04-21-2011, 10:09 PM
I've been running without that rubber flap on my XR7 since I put the car together back in '05. No issues here.
post #17 of 18 (permalink) Old 04-21-2011, 10:34 PM
I left mine off because with it on, oil changes can be kinda frustrating when it's digging into your forearm.
post #18 of 18 (permalink) Old 04-22-2011, 04:18 AM Thread Starter
Andy625UK's Avatar
My car runs a lot cooler now that I've changed out the ancient water/antifreeze. I put a new thermostat in at the same tim (195F - same as the old one), and the gauge will sit at about 1/3 warm unless I hit a jam, when it then rises to 1/2 way. It always used to sit 1/2 way all the time.
Initially I thought that it was running cooler because I'd left the ducting off, however now that its back on, I can't say that I've noticed it making any difference. Obviously clean water = runs cooler.
Another thing I like about having the ducting on, is that it gives a liTtle protection to the power steering pipe that runs along the front under the radiator.
The Eagles
1975
