Jumpering fuel pump - TCCoA Forums
post #1 of 10 (permalink) Old 05-10-2011, 03:30 PM Thread Starter
paintme205's Avatar
Jumpering fuel pump
Does anyone have some directions or a wiring diagram for the fuel pump and relay so that I can turn the key to run but keep the fuel pump on. I am working on a way to drain the tank without dropping it. Thanks.
paintme205 is offline
post #2 of 10 (permalink) Old 05-10-2011, 04:47 PM
i have to laugh at myself...I had to do this the other day in my Buick, and I litterlay had to turn the key back and forth about 300 times to empty the tank!!!
I just did not have timne to research how to do it.
sorry, really no help.
post #3 of 10 (permalink) Old 05-10-2011, 04:51 PM
If the car is running, just hook a fitting on the fuel line schrader valve plumbed to a fuel jug and run the car until it stops.
69 F100 LWB w/460 Engine
post #4 of 10 (permalink) Old 05-10-2011, 05:59 PM
Just pull the relay and jump power directly to the pump
ThePrimerSuspect is offline
post #5 of 10 (permalink) Old 05-10-2011, 10:25 PM
Can't just pull a relay, the fuel pump is controlled by the IRCM.
post #6 of 10 (permalink) Old 05-11-2011, 11:56 AM Thread Starter
paintme205's Avatar
Well looks like we have a winner. I am ordering an on/off valve and some NPT fittings to connect to the schrader valve and will have a hose running to a jug. I should be able to get 90-95 percent of the fuel out.
The good part is all I do is open the valve while the car is running and wait. Close the valve and disconnect one hose and keep trucking. I will take a pic when I finish in the next two weeks.
post #7 of 10 (permalink) Old 05-11-2011, 12:36 PM
I used this:
http://www.extair.com/image/airchuck...air-chucks.jpg
AC2210 to a 3/8 fuel line to a gas can.
You don't really need a valve as you can simply turn off the engine to stop the pump. Just be advised, that it will pump slowly. Just keep an eye on the gas can and let it run until the engine quits.
Has worked for me on numerous occasions.
But it is pretty hard on the pump and I would recommend replacing the pump while you have the tank out unless it's fairly new.
post #8 of 10 (permalink) Old 05-11-2011, 01:03 PM
Why not just use a siphon hose? or take a look and see if the tank has a drain...
PaulS1950 is offline
post #9 of 10 (permalink) Old 05-11-2011, 02:40 PM Thread Starter
paintme205's Avatar
A siphon hose has always been slow for me. I'm hoping to drain 2-3 gallons in less than ten minutes. Basically the time it takes my car to cool down on a dyno.
post #10 of 10 (permalink) Old 05-11-2011, 04:21 PM
anti-siphon plate in the main fuel fill.
Also, these tanks do not have a drain.
