Oil Pressure - TCCoA Forums
post #1 of 9 (permalink) Old 05-28-2011, 12:53 PM Thread Starter
mcmoore0693's Avatar
Oil Pressure
So I am currently using Valvoline Conventional 5w-20 oil in my 96 4.6L Thunderbird's engine. Ford, the owner's manual, and different owners I have spoken to all say use either 5w-20 or 5w-30 weight oil. I decided to use the 20 weight to maybe free up some horsepower but now my oil pressure is low. Not dangerously low as to cause problems, but just below the "n" on "norm" on the reading in the gauge cluster. Is this from the oil or from another issue? Thank you.
1996 "Talladega" T-Bird - Full PI Swap with custom Comp Cams, dyno tuned, SCP CAI, Underdrive Pulleys, Professional Products 75mm Throttle Body and Intake Plenum, 3.73 gears, JBA Shorties, Screamin' Demon Coil Packs, Livewires, 2.5" Mandrel Bent True Dual Exhaust, O/R X, electric exhaust cutouts, built 4R70W with Shift Kit, Cobra R Hood, Custom Spoiler.
mcmoore0693 is offline
post #2 of 9 (permalink) Old 05-28-2011, 01:54 PM
BlueEyes's Avatar
My Chiltons says 10w30 or 5w30. The stock gauge isn't very accurate and varies car to car. I'm sure someone who knows oil better can give you some tips though.
-Kelly
Fuelly
BlueEyes is offline
post #3 of 9 (permalink) Old 05-28-2011, 02:58 PM
Unless you've modded the oil pressure system, it's irrevelent - it's a switch and a resistor, and the gauge will vary depending on several factors (including how many bean burritos you had for lunch, it seems ... )
The big secret is to put an accurate oil pressure gauge on it, and see if it's dropping too low at idle when warm.
RalphP is offline
post #4 of 9 (permalink) Old 05-28-2011, 03:07 PM
Yup if you're noticing the gauge reading differently it's either placebo effect from knowing you went to a different oil and are now paying closer attention, or you or whoever changed the oil bumped or soaked the connector on the sender with oil. Any varation between the center(between O and R) and nothing is circuit/connection related, the sender is nothing more than a pressure driven on/off switch.
post #5 of 9 (permalink) Old 05-29-2011, 02:25 PM Thread Starter
Thanks for the answers. I do tend to spill the oil out of the filter everytime I change it but if you've ever changed it on this car you know what I mean. Lol
post #6 of 9 (permalink) Old 05-30-2011, 02:40 PM
Sometimes my fake OP gauge will read a little low if I have a lot of electrical accessories running. So that might get someone thinking it's reading different.
John Fritz is offline
post #7 of 9 (permalink) Old 05-30-2011, 02:44 PM
96PRLBRD's Avatar
If you want to free up a few HP, just switch to a quality full synthetic and stick with what's required, 5W30. Change the oil weight at your own risk.
--> My most recent pics <--
96PRLBRD is offline
post #8 of 9 (permalink) Old 06-01-2011, 07:17 AM Thread Starter
Well we ran a cycle of synthetic 5w-30 through it and that's when I first noticed it dropped. I thought that might be it so i went back to conventional but it still runs a little low (or so it says). Sometimes it will jump up to the middle of "NORM" and then even run a little high. Then it will drop back to right on the "N." Go figure. It runs fine and isn't overheating or doing anything weird so I guess it's just a misreading.
post #9 of 9 (permalink) Old 06-01-2011, 08:07 AM
Roadrunnner's Avatar
Search for the tech article showing how to convert it.
Will
Roadrunnner is offline
