A couple problems :( - TCCoA Forums
post #1 of 24 (permalink) Old 06-16-2011, 10:17 PM Thread Starter
python1208's Avatar
Ok so ive been kinda frustrated with my bird lately... I have a 97lx and yesterday my trun signals wouldnt work and today they did but now my signals and washer sprayer quit working and i have no idea what to do.
And the other thing is my climate control sysetm is not blowing at all, not on any setting ive read that some times if you jiggle the wires near the blower motor it helps but I got nothing.
Lastly my drivers door sags really bad to the point where it wont even close what would be the best route to go about fixing that...
Sorry for my angry rant I appreciate any advice
Thanks!!
python1208 is offline
post #2 of 24 (permalink) Old 06-16-2011, 10:35 PM
Earl's Avatar
Well, with the turn signals and the washer sprayer, I would suggest either dis-assembling and cleaning all the contacts on the multi function switch, or, the better option, IMO would be to just replace the multi function swithc with a new unit. It is not that difficult. there are plenty of posts here with info and photos.
The cl imate control could be a number of issues, first off, do you have manual or semi auto climate control? (do you have a digital display on the climate control head unit, or do you have three knobs?)
As for the sagging door, I too have the same problem. You could buy a hinge pin rebuild kit from somebody like supercoupeperformance or you could buy a new hinge from Ford. I am still on the fence about what to do, but my door is harder to deal with every day, so I will probably just get a whole new hinge.
These really are great cars, they are extremely reliable, tough as nails, just all around wonderful, don't get too mad at it, remember, they are old now, and they all need work.
Earl is offline
post #3 of 24 (permalink) Old 06-16-2011, 11:37 PM
ice217's Avatar
^^ what he said.
MMMMMMMMMMMMM..........MMM..........MMMMMMMMMMMMM
.......MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM........
MMMMM........................................
THUNDERBIRD: because everyone else drives a mustang.
ice217 is offline
post #4 of 24 (permalink) Old 06-17-2011, 01:05 AM Thread Starter
python1208's Avatar
Thanks for the info I really appreciate it. I love this car just little stupid things ya know? Anyways it's the semi auto climate control
post #5 of 24 (permalink) Old 06-17-2011, 12:03 PM
ice217's Avatar
Here is a very helpful link to fixing your saggy door.
This uses only the new bushings (not a whole new hinge)
The bushing can be found at a local parts store that sells the HELP! brand. there are a few threads here that give exact part numbers on these parts. I believe they are the same repair kit for a F150.
Anyways here the step by step video. hope it helps
http://www.youtube.com/watch?v=SVVozUkfDO4
ice217 is offline
post #6 of 24 (permalink) Old 06-17-2011, 07:28 PM
Raoul Duke
cougarcragar's Avatar
You're experiencing problems we all have; that's the good news. If you're good with tools, you can fix all of it for minimal investment.
I had intermittent problems with my multi-function switch in 2004, so I took it apart, cleaned the contacts and added dielectric grease. It's been flawless for seven years and 60k miles. Give it a shot!
I rebuilt my door hinges last month. It was tricky with the floor jack under the door, but I had my brother hold the door while I performed the work. I had to enlarge the holes to accept the new brass bushings (Dremel with stone tip), but it worked out really well. My door is like brand new again. I did not need to replace my hinges, so the entire job was done in one afternoon.
These really are great cars.
1996 Mercury Cougar XR7
cougarcragar is offline
post #7 of 24 (permalink) Old 06-17-2011, 09:59 PM
CrystalPistol's Avatar
Door Hinges ... look at this thread. http://forums.tccoa.com/showthread.php?t=125934
I made a wooden cradle like one I saw in a thread here that it has ends that are cut to support the door bottom, lip, and start up outside a hair. I jack the car up with door open and set cradle on blocks to support door and then just barely lower car to take weight off hinge, AND NO MORE. Has a long flat piece to nestle up under door.
No need for new hinges 90% of the time.
CrystalPistol is offline
post #8 of 24 (permalink) Old 06-18-2011, 12:33 AM Thread Starter
python1208's Avatar
Thanks for all the suggestions guys, before I take the multi-function switch apart should I check a relay somewhere or something? We have rain coming for the next 5 days and I wont be able to drive unless I fix that :/
post #9 of 24 (permalink) Old 06-18-2011, 07:34 AM
Raoul Duke
I don't know where the relay is, but you may be able to get them working (temporarily) by running the hazard switch up and down about 20 times. It's part of the same switch and can sometimes restore continuity when wiggled or worked up and down. Using that switch, which is rarely used anyway, can clean the corrosion from the copper terminals and get other things working.
It's not a fix, though, and it may not even work in your case.
post #10 of 24 (permalink) Old 06-18-2011, 10:28 AM
BlueEyes's Avatar
The relays should be right around the steering column area, to the left of the column. take the 3 bolts out of the panel that covers the area under the column and pull it down to pop it out. Some times the relays come loose, check the wires.
-Kelly
Fuelly
BlueEyes is offline
post #11 of 24 (permalink) Old 06-18-2011, 12:59 PM
96PRLBRD's Avatar
For turn signal switch help see http://www.mn12tech.com/turn-signal-...eplacement.php
--> My most recent pics <--
96PRLBRD is offline
post #12 of 24 (permalink) Old 06-19-2011, 03:31 AM Thread Starter
python1208's Avatar
Any ideas on the climate control?
post #13 of 24 (permalink) Old 06-19-2011, 08:44 AM
J. Arkayman's Avatar
That's a great video. Wish I had seen it before I did mine.
It will probably take anyone that hasn't done them a bit longer than 30 min. to do one though.
J. Arkayman is offline
post #14 of 24 (permalink) Old 06-19-2011, 08:47 AM
If you know how to use a multimeter, I would imagine you could get in there and start tracking what's working and where. If not, find someone that does.
Disclaimer: As with any advice I give, if anyone has a better idea, please feel free to offer better advice.
post #15 of 24 (permalink) Old 06-19-2011, 05:21 PM Thread Starter
python1208's Avatar
I think i found why the wipers weren't working its hard to see but the yellow wire wasnt in the harness
Except now everything is everywhere and i don't remember how it went :/
post #16 of 24 (permalink) Old 06-19-2011, 05:53 PM
Search, there are pics here somewhere.
Grog6 is online now
post #17 of 24 (permalink) Old 06-19-2011, 06:10 PM
rmfk13's Avatar
Are the 97 multifunction switches the same as a 95's if so I've got one if you need one, not too far away either
Rob
rmfk13 is offline
post #18 of 24 (permalink) Old 06-19-2011, 07:54 PM Thread Starter
python1208's Avatar
UPDATE... I fixed the wire and cleaned all of the contacts but the wipers and sprayers still arent working.
Can you post a picture of the front and back of it I bet it would work If so your a life saver!
post #19 of 24 (permalink) Old 06-19-2011, 07:57 PM Thread Starter
python1208's Avatar
It will fit I just looked it up!
post #20 of 24 (permalink) Old 06-21-2011, 02:31 PM Thread Starter
python1208's Avatar
UPDATE...
Wiper problem fixed! Now on to the blower motor. I checked the wires going into the blower motor with a multimeter and it gets no power on any setting. its the auto climate control system which means there is no resistor just a switch right?
post #21 of 24 (permalink) Old 06-21-2011, 02:58 PM
BlueEyes's Avatar
I think a switch and the control module. The control module is right in front of the fan, if you're not getting power out of the module wiggle/clean out the connector. I have the schematic but no scanner here.
-Kelly
Fuelly
BlueEyes is offline
post #22 of 24 (permalink) Old 06-21-2011, 03:30 PM Thread Starter
python1208's Avatar
I have the hanes manual and it only has the wiring diagram for the manual climate control :/
post #23 of 24 (permalink) Old 06-21-2011, 03:33 PM Thread Starter
python1208's Avatar
I thought i read somewhere that there is a 30A inline fuse near the blower motor can anyone confirm this?
post #24 of 24 (permalink) Old 06-21-2011, 04:03 PM
BlueEyes's Avatar
I have a 94 service manual but the wiring should be the same. If someone else doesn't post it up I can take pictures of the pages and email them to you. I have the EVTM too so I'll check. Matt probably has it handy or knows what you need to know.
I hope it's not the module, they're a little spendy.
if you want me to email you the pages just PM me your email.
-Kelly
Fuelly
BlueEyes is offline
