Headlight issue. - TCCoA Forums
post #1 of 4 (permalink) Old 06-22-2011, 09:04 PM Thread Starter
Headlight issue.
My highbeam light on the dash is stuck on when I turn on the auto-lights or the switch. I'm not to sure where to start mostly because the lights don't come on. Just the headlights the corner and tails lights are on. I wanted to know if someone knew what causes the indicator light on the dash to stay stuck on. Odlly enough thought when I have the lights off and the press the high beam switch in the lights don't come on either, but the indicator light does come on. I wonder if it's a relay or a fuse. I check the lights and they looked good. Any ideas would be great help. Thanks
bigj8705 is offline
post #2 of 4 (permalink) Old 06-22-2011, 11:38 PM
renello79's Avatar
I would look at the multifunction switch first. More than likely that is your problem and it's easy to change. After you check your fuses and relays
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
post #3 of 4 (permalink) Old 06-23-2011, 05:25 PM Thread Starter
Where is this really at ? as well as does the RCM control the headlights?
bigj8705 is offline
post #4 of 4 (permalink) Old 06-23-2011, 05:50 PM
SuperThunderbirdLX's Avatar
REPLACING
http://www.mn12tech.com/turn-signal-...eplacement.php
Courtesy of Swanny here on the forums.
REPAIRING
http://forums.tccoa.com/showthread.php?t=109143
Courtesy of MikeRWK also on the forums.
-Daniel
SuperThunderbirdLX is offline
