installing an a/c compressor and refilling system - TCCoA Forums
post #1 of 3 (permalink) Old 07-17-2011, 11:44 PM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
the 93 came without a compressor. i have a delete pulley in its place.
can i just install a compressor and have the a/c system evacuated and filled by a shop, or will i need to replace other system components?
am i ok to use r134 since the a/c system has been open for so long?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 3 (permalink) Old 07-18-2011, 12:32 AM
Compressor, accumulator, and orifice tube (which is in the liquid line) should be replaced.
You should also have everything else flushed to make sure there's no crap in there to kill the compressor as soon as it starts running.
Finally, depending on your humidity, you may need to have the vacuum pump running when you connect the accumulator up or within minutes afterwards (I had mine connected to the high side, and fired it up while connecting to the low side hose, which comes on the accumulator for the 5.0HO.)
RalphP is offline
post #3 of 3 (permalink) Old 07-18-2011, 12:39 AM
pettyfog's Avatar
^^^ Ralph means the minute the system is closed, start vacuum. Unless you have nitrogen handy. Actually the best way to finish a flush is with nitrogen.
You were okay to use 134 anyway. Conversion's a snap especially replacing the compressor, because you ALWAYS replace the accumulator at the same time.
That isnt your problem. Thing is you dont know if the compressor was working okay when the delete was installed/ or clutch failed, it may have failed previously. So you might just have to replace the condenser coil.
Because the system was exposed to air {thus water vapor}, over time the oil in the system will have absorbed water and formed a sludge in worse case. Where you cant see it. You need a complete and thorough Flush of the condenser evaporator and lines. Probably should replace the orifice tube.
Folks.. this is why when the clutch / bearing fails you run to the junkyard and get a good used compressor, not a delete. and hook it up even if you have no intention of using that compressor. Works much better to keep the system sealed than plugs.
Here's the basics.. self-promoting but true.
http://www.autoacsystems.com/_faqs/3tiplist.html
pettyfog is offline
