Look at this POS silencer - TCCoA Forums
post #1 of 13 (permalink) Old 07-29-2011, 12:40 AM Thread Starter
Moderator & Teksid Whore
guitar maestro's Avatar
2004 F150 2V 4.6L
I can't yank it off because unlike MN12s which still retain their stock CAI, I would lose it and start taking in hot engine bay air. Guess I need to do something about this, lol.
guitar maestro is offline
post #2 of 13 (permalink) Old 07-29-2011, 01:09 AM
They call that the Gotts Mod on many f150 forums, it's on my to do list. It's also controversial and some idiots claim dispite it being before the maf that it causes a lean condition.
Basically the solution to the fill in the blank that you've left is to go to lowes or home depot and buy some PVC pipe and a rubber coupler to complete the delete.
post #3 of 13 (permalink) Old 07-29-2011, 02:42 AM Thread Starter
Actually I was thinking about getting a cobra air box that way the snorkel will make a 90 turn into a spot where it can grab air from the front.
post #4 of 13 (permalink) Old 07-29-2011, 11:45 AM
There's also this silencer.
post #5 of 13 (permalink) Old 07-29-2011, 01:11 PM Thread Starter
That won't be too much of a restriction, since it's the same size as the throttle body. That peewee sized silencer on the air box is another story though.
post #6 of 13 (permalink) Old 07-29-2011, 08:46 PM
driller's Avatar
I put this on my '06 Harley F150...
driller is offline
post #7 of 13 (permalink) Old 08-03-2011, 07:10 AM
High-Mileage 4.6L Thrasher
Johnny Langton's Avatar
Originally Posted by guitar maestro View Post
2004 F150 2V 4.6L
Oscar, cut it off right where it meets the inner fender. I did that on my old '98 F150, and it gained about 1/4" in ID over the stock piece. The "silencer" portion is where it's necked down after it goes through the inner fender. Or you can remove that entire "silencer" section and just replace it with a short piece of flexible air ducting hose. That's what I did on the old Navigator.
JL
Fuelly
Johnny Langton is offline
post #8 of 13 (permalink) Old 11-09-2011, 09:29 PM
96PRLBRD's Avatar
You need a Gotts Mod @ http://www.fordf150.net/articles/idx...ification.html
--> My most recent pics <--
96PRLBRD is offline
post #9 of 13 (permalink) Old 11-10-2011, 08:55 PM
Krazybird13's Avatar
Anything has got to be better than that silencer. Im not real familiar with those trucks, is there a way to run it closer to the front without having a ton of intake tubes?
97 Thunderbird LX 4.6 SOHC V8- March Underdrive Pulley Set...
Krazybird13 is offline
post #10 of 13 (permalink) Old 11-11-2011, 07:31 AM Thread Starter
Moderator &amp;amp; Teksid Whore
http://www.fordf150.net/howto/airboxmod.php
I did that mod to the airbox. The hot air should reduce pumping losses in normal city driving. Not really worried about the hp right now.
post #11 of 13 (permalink) Old 11-11-2011, 08:01 AM
i put the k&n kit on mine....it sucks engine bay air, but I'm not worried, as I don't sit idleing all the time.
post #12 of 13 (permalink) Old 11-11-2011, 01:00 PM
The one on my ranger I just removed and swelled a piece of exhaust tubing to fit. That one won't be so easy.
post #13 of 13 (permalink) Old 11-11-2011, 04:39 PM
The one on my Ranger is no bigger around than a 12 oz can. That is leaving the air box !
