underdrive pulley question - TCCoA Forums
post #1 of 27 (permalink) Old 08-24-2011, 03:22 PM Thread Starter
I just order a pair of steeda udp but when they arrive they don't say steeda anywhere on the pulleys. Its not a piggy back system and it came with steeda instructions and came with a sticker saying that this is sfi 18.1 certify. But i just want to make sure. Any thoughts?
1997 Thunderbird 4.6L
New paint on tops, Magnaflow high flow cat system and custom 2 - 2 1/2 Exhaust ,J-Mod and P.I. head and intake swap(performed by RobertP @ www.RobsTireAndAuto.com ) Steeda Underdrive Pulleys, Mark VIII TC, AEM dry flow air filter, Blacked out tail lights and custom painted headlights (performed by my wife) tuned by DON at http://www.lasotaracing.com/
waiting to hear theses kooks
http://www.cardomain.com/ride/391835...rd-lx-coupe-2d
swampt420 is offline
post #2 of 27 (permalink) Old 08-24-2011, 11:04 PM
Do you have any pics of them?
Do they look like the picture of the pulleys straight off the steeda website:
http://www.steeda.com/store/steeda-u...d-mustang.html
~Rick
TCCoA Sig
post #3 of 27 (permalink) Old 08-25-2011, 09:37 AM Thread Starter
No it doesn't look like that and yes i do have pictures i will post. The part number is hb1476-n and i have found a couple sites talking about them with mustangs and maurders. I just want to make sure that this will work on our 4.6L's before i install. Please help.
post #4 of 27 (permalink) Old 08-25-2011, 09:44 AM Thread Starter
This is the exact pulley.
http://www.modularfords.com/forums/f...6-04-a-110760/
post #5 of 27 (permalink) Old 08-25-2011, 10:39 AM
Banned
91bluecoupe's Avatar
You need the 3 pc set or atleast the 2 pc set to be worth it.
91bluecoupe is offline
post #6 of 27 (permalink) Old 08-25-2011, 11:46 AM Thread Starter
I do. I have the alt, crank and water pulley.
post #7 of 27 (permalink) Old 08-25-2011, 12:03 PM
Banned
Oh ok then you should be good to go. Just make sure the water pump pulley is for your shorter shaft. I use to have the Steeda pulleys on my car. Now I am running BBK. See my pics.
post #8 of 27 (permalink) Old 08-25-2011, 12:35 PM Thread Starter
Yep the water pump looks just like that. And by the way, what a beautiful car.
thanks for the help.
post #9 of 27 (permalink) Old 08-25-2011, 01:13 PM
Thunderbirds have the long shaft/nose. Isn't he putting these on his 1997 Thunderbird?
~Rick
TCCoA Sig
post #10 of 27 (permalink) Old 08-25-2011, 02:07 PM Thread Starter
Yes the pulleys r going on a 97 bird. The pulley package is for a 96- early 2001 mustang
post #11 of 27 (permalink) Old 08-25-2011, 04:49 PM
CometGSR's Avatar
Those look exactly like mine, except for the Steeda branding on the part itself.
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #12 of 27 (permalink) Old 08-25-2011, 06:23 PM Thread Starter
Thanks for the info
post #13 of 27 (permalink) Old 08-26-2011, 09:19 AM
Banned
Thanks swampt420.
post #14 of 27 (permalink) Old 08-27-2011, 08:03 AM Thread Starter
Guys i got another question. How do you get the dang crank pulley off!!!!!!!!!!!!!!!!! I can't seem to even budge it.
post #15 of 27 (permalink) Old 08-27-2011, 11:41 AM
Banned
The easiest way is to use a breaker bar and pull your fuel pump fuse.
Put the breaker against the ground and then bump the starter that will break it fast.
I do it every time that way.
Then you have to use a harmonic balancer puller to pull the crank off and be sure when you put the crank pulley back on to use some black rtv on the key way or you will get a small oil leak there.
post #16 of 27 (permalink) Old 08-27-2011, 01:11 PM Thread Starter
That sounds brilliant! Thanks again I'll let you know how it goes.
post #17 of 27 (permalink) Old 08-27-2011, 05:46 PM Thread Starter
What did u guys tq ur crank shaft to.
post #18 of 27 (permalink) Old 08-27-2011, 06:48 PM
Banned
As close as you can get to 70 ft/lbs it will be hard to hold the motor from turn also.
The good thing is the engine turns in the direction that will keep the bolt from backing out.
post #19 of 27 (permalink) Old 08-28-2011, 07:43 AM Thread Starter
i got the pulleys on except for the alt putting that on to day. Putting the breaker bar against the ground is a genius idea, bolt came right off very easy.
91bluecoupe if u weren't so far away id give you a big o hug. Thanks for all the help
post #20 of 27 (permalink) Old 08-28-2011, 09:22 AM
Listen, and I am speaking from experience...
When you put that crank pulley on, and you torque it. After it's tight, leave the socket on and tap it with a hammer, then re-torque, tap it, re-torque, continue this until it doesn't re-torque anymore (fully tight and seated).
I didn't do this the first time and my trigger wheel shattered after running the car about a week. What a PITA to change that. So make sure to seat that crank pulley the FIRST time.
~Rick
TCCoA Sig
post #21 of 27 (permalink) Old 08-28-2011, 10:26 AM Thread Starter
Will do, but i have already driven to work.Can i do this when i get back home.
post #22 of 27 (permalink) Old 08-28-2011, 11:16 AM
Banned
Yeah a few have had that problem but most get it torqued the first time. You can retorque any time.
I have had pulleys on my Mustang and my my Tbird and never had any problems.
post #23 of 27 (permalink) Old 08-28-2011, 11:51 AM
Boost!!!
modularbird's Avatar
don't mean to hijack but, i got a couple questions. i have some i need to install... about how long do they take to switch out? do they help any? most people say the 4.6 doesn't gain that much from u/d pulleys, but they help with gas mileage a little... are they worth the hassle?
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #24 of 27 (permalink) Old 08-28-2011, 11:53 AM
r429460's Avatar
U/D pullies not worth the cost.
Unless you buy them for really, really, cheap.
r429460 is offline
post #25 of 27 (permalink) Old 08-28-2011, 12:04 PM
Banned
There has been hundreds of debates about are they worth it. This is how i feel about them anything you can add even only 5-10 hp is worth it plus a small boost in mpg.
Only take like 30 minutes for most to install.
post #26 of 27 (permalink) Old 08-28-2011, 12:06 PM Thread Starter
I found mine on ebay for $129 and i can a difference in pick u, not a crazy amount but u can fell it. There not hard to install at all.
post #27 of 27 (permalink) Old 08-28-2011, 12:08 PM
Banned
I got mine for $50 on Cl.
