Hard to start - TCCoA Forums
post #1 of 8 (permalink) Old 08-28-2011, 02:46 PM Thread Starter
Vettecor's Avatar
Hard to start
I have a 1991 T-bird 6 cylinder. Its does not want to start and this happens when cold or warmed up. Once it starts it runs great. However, I decided to do the following:
1. replaced spark plugs with Motorcraft copper plugs.
2. replaced cap and rotor.
3. replaced spark plug wires.
4. replaced battery
The car cranks fine but it takes 3, 4, or 5 times cranking before it starts.
Again, once it starts the car runs great.
Any idea what the problem could be? I am a novice when it comes to car repairs and hopefully it will be something I can do.
Thanks in advance.
Larry
Vettecor is offline
post #2 of 8 (permalink) Old 08-28-2011, 03:20 PM
Other maintenance I don't see
1) Clean MAF
2) New air filter
3) Check IAC, replace if necessary
4) Since it's a 1991, it's not as easy as a 96/97 (or 94/95 V6), but a log of what the ECM is doing while you start would be nice, I'm sure.
RalphP is online now
post #3 of 8 (permalink) Old 08-28-2011, 03:56 PM
wrc11's Avatar
check your crankshaft position sensor, see if the wires are correctly plugged and clean the connector sometimes they get loose
Alfonso De Anda
wrc11 is offline
post #4 of 8 (permalink) Old 08-28-2011, 04:29 PM
The non-EDIS 3.8s don't have a crank sensor.
As to the OP's problem... have you verified spark while cranking? And have you checked fuel pressure at the fuel rail?
post #5 of 8 (permalink) Old 08-28-2011, 04:49 PM
wrc11's Avatar
oo my bad i dont know much about v6 birds sorry
Alfonso De Anda
wrc11 is offline
post #6 of 8 (permalink) Old 08-28-2011, 04:56 PM
pettyfog's Avatar
Pull the vac line into the Fuel PRessure Regulator and check for fuel. Common fail.
Cycle pump with key on several times. Symptoms better, or worse?
Floor gas pedal while cranking. Symptoms better, or worse?
pettyfog is offline
post #7 of 8 (permalink) Old 08-28-2011, 07:01 PM Thread Starter
Vettecor's Avatar
Thanks guys for all the great responses. I hope to work on the car next weekend and hopefully the car won't breakdown before that.
Larry
Vettecor is offline
post #8 of 8 (permalink) Old 08-28-2011, 07:49 PM
Roadrunnner's Avatar
Dont forget the fuel filter
Will
Roadrunnner is offline
