?'s about K-member - TCCoA Forums
post #1 of 5 (permalink) Old 12-30-2015, 04:55 PM Thread Starter
steamer471's Avatar
?'s about K-member
I rebuilt the front end on my mark (everything except the rack) and I have still have a popping noise (front left) and a wiggle in my steering at 55 mph. The rack has a rebuilt sticker on it and I think it's a cardone. Also the motor seems to shift to much under a load (drivers side motor mount). Was thinking about dropping the k-member to do all this at once. I've read the posts on here and think I can handle it just wanted a little advice.
How heavy is this thing? can two floor jacks handle it? One? Thought of doing the oil pan gasket while I was down there (no leaks just preventative maintenance ) what else should I consider while I'm at it?
Also saw in one post where it's recommended on the Mark viii that I remove the oil dipstick before I drop it. Any help appreciated.
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #2 of 5 (permalink) Old 12-30-2015, 05:56 PM
V8ThunderCat's Avatar
I'm curious about this too due to some work I need to do but I do know that one thing that should be or could be swapped whenever the engine or K-member is moved is the front sway bar.
-Randy-
V8ThunderCat is offline
post #3 of 5 (permalink) Old 12-30-2015, 06:20 PM
Moderator & Teksid Whore
guitar maestro's Avatar
I listed all the weights in a thread in this very forum. Do an advanced search and you should find it.
guitar maestro is offline
post #4 of 5 (permalink) Old 12-30-2015, 09:49 PM
MaddMartigan's Avatar
First things first; you need an engine support or cherry picker to support the engine when you remove the K member.
So, it's a total of 8 bolts in size E18 (inverse torx) to detach it from the frame rails. I had to remove the front shocks/springs and the upper control arms (I was replacing them anyway) to get it disconnected. I used a 3 ton floor jack to lower it and I am able to pick it up and carry it with the LCAs and spindles still attached. I'm a bigger guy so your mileage may vary.
It turns out that its pretty easy. If you're considering a new sway bar then this is the time to do it as well. If you are ever considering doing something different with your oil pan then modifying the K member is needed usually too.
I have a thread about the work I started this fall. I plan to start putting things back together tomorrow.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #5 of 5 (permalink) Old 12-31-2015, 05:23 AM Thread Starter
steamer471's Avatar
Yeah I read your post and I didn't think about the sway bars will do that while I'm in there. I also did an advanced search and found the weight isn't as much of an issue as I thought it would be. thanks for the help and good luck on your install.
1997 Mark 8 LSC
Former owner:
