Heater Core Replacement - TCCoA Forums
 5Likes
  • 1 Post By RalphP
  • 1 Post By RalphP
  • 1 Post By ttbird
  • 1 Post By Tbird Bob
  • 1 Post By Grog6
post #1 of 15 (permalink) Old 01-18-2016, 04:07 PM Thread Starter
bowez's Avatar
Getting coolant smell in the car with heat on and a oily film on the windshield, I assume its the Heater Core right?
Has anyone replaced it without removing the dash?
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #2 of 15 (permalink) Old 01-18-2016, 05:49 PM
Tbird Bob's Avatar
It cannot be removed any other way. The dash stays in, but it needs to be lifted in place.
Tbird Bob is offline
post #3 of 15 (permalink) Old 01-18-2016, 07:33 PM
steamer471's Avatar
Also lower the steering column and remove the center console.
1997 Mark 8 LSC
Former owner:
1996 Thunderbird lx 4.6
1994 Thunderbird lx 4.6
steamer471 is offline
post #4 of 15 (permalink) Old 02-24-2016, 12:15 AM
TBird94's Avatar
If my heater core goes bad, I will probably bypass it, and live without heat.
Replacing it looks like a gruesome job.
TBird94 is offline
post #5 of 15 (permalink) Old 02-24-2016, 02:38 AM
It's not too bad, just time consuming.
I also swapped the dash, and since I have a 1991 XR7, I had to swap the wiring harnesses also.
By myself, it took about a day of work all told.
CDsDontBurn likes this.
Fuelly
RalphP is offline
post #6 of 15 (permalink) Old 02-28-2016, 02:30 AM
V8ThunderCat's Avatar
The hardest part is finding a second pair of hands when it's time to move the dash.
-Randy-
V8ThunderCat is offline
post #7 of 15 (permalink) Old 02-28-2016, 01:27 PM
Tbird Bob's Avatar
When my heater core was replaced, the dash was cleverly lifted by putting a board underneath it with bottle jacks on both sides. Then it was carefully raised enough to gain access to the core.
post #8 of 15 (permalink) Old 02-28-2016, 04:22 PM
You guys use helpers?
I pulled my 1991 Cougar's dash by myself. And put the new one in by myself.
Fuelly
RalphP is offline
post #9 of 15 (permalink) Old 02-28-2016, 08:52 PM
ttbird's Avatar
Just got mine back together a week ago, was down almost 3 weeks.Bought a core at Napa what a POS,took it back and had a radiator shop took a week to build me a good one.Now the original radiator developed a leak and power steering just started leaking.250k miles I guess its time.Had the wife help me pull the dash and steering column .
Tbird Bob likes this.
92 Thunderbird Sport 04 Mach1 05 Mustang 77 F-250 460 Tow Pu 69 Mustang Fb wifes Drag car 64 Comet afx clone my Drag car
ttbird is offline
post #10 of 15 (permalink) Old 02-28-2016, 11:32 PM
Tbird Bob's Avatar
To prevent electrolysis in your cooling system, run a ground wire from one of the heater core nipples to an appropriate location.
post #11 of 15 (permalink) Old 03-20-2016, 07:42 PM Thread Starter
bowez's Avatar
Getting ready to finally do this, where's the best place to get Aluminum wire? Odd for me to go looking for Aluminum over Copper but in this cause I see the need. Also anyone see a problem soldering the wire to the core as opposed to using a hose clamp, I have Ag ,Pb and Pb free ?
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #12 of 15 (permalink) Old 03-20-2016, 07:54 PM
Solder, brazed, or welded; it should all be the same for corrosion resistance, as a ~zero resistance connection.
(Unless someone sux at making them, lol.)
I'd solder it; and if it's soldered, copper or aluminum won't matter. I'd wash off the flux, after, tho.
I'd use lead solder, it's more durable near a battery; silver is great, it makes it stick really well, but high silver causes issues in weather.
As long as everything is connected together, it won't corrode.
post #13 of 15 (permalink) Old 03-25-2016, 05:51 PM Thread Starter
bowez's Avatar
That was no fun at all
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #14 of 15 (permalink) Old 03-25-2016, 09:42 PM
CDsDontBurn's Avatar
Got it taken care of then?
CDsDontBurn is offline
post #15 of 15 (permalink) Old 03-26-2016, 07:37 AM Thread Starter
bowez's Avatar
Still have to finish up, all the aftermarket wiring caused a delay.
93 SC Tbird
93 5.0 Tbird
bowez is offline
