Speedometer/odometer question - TCCoA Forums
post #1 of 6 (permalink) Old 01-24-2016, 10:42 AM Thread Starter
Send a message via AIM to LoadedButane Send a message via Yahoo to LoadedButane
My speedometer was on the fritz by not reading anything below 30mph. It did this for a couple months before eventually dying completely. The odometer doesn't work either. I replaced the odometer gears a couple years ago so I am looking at the VSS. Is this the issue? I cant pull codes cause alll I get is an error message,
Geoff
1995 Mercury Cougar
~Mark VIII Trans with jmod + converter, 255lph fuel pump
~heads, cams, and intake in the distant future or when I break something
LoadedButane is offline
post #2 of 6 (permalink) Old 02-02-2016, 04:39 PM Thread Starter
VSS was switched with another with no change. I took apart the speedometer and everything looked kosher. Im broke as a joke so any recommendations will have to be done cheaply
Geoff
1995 Mercury Cougar
post #3 of 6 (permalink) Old 02-03-2016, 08:13 AM
jco1385's Avatar
Maybe the speedo unit died. Check the wiring for the VSS for cracking or bare wire.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #4 of 6 (permalink) Old 02-09-2016, 07:01 PM
Can you datalog a 95?
Vss is one of the things I can see in my 96-97 cars.
post #5 of 6 (permalink) Old 02-09-2016, 09:11 PM
The 4.6 yes, the 3.8 no.
(4.6 is OBDII, 3.8 isn't.)
Fuelly
RalphP is offline
post #6 of 6 (permalink) Old 02-13-2016, 03:29 PM Thread Starter
Put on a new VSS and took apart the cluster again and got it working.
Geoff
1995 Mercury Cougar
