How to test fan motor before installing? - TCCoA Forums
post #1 of 8 (permalink) Old 02-05-2016, 10:17 PM Thread Starter
TBird94's Avatar
I have a new fan assembly. Before installing, I would like to test the motor.
Any suggestions?
TBird94 is offline
post #2 of 8 (permalink) Old 02-06-2016, 01:02 PM
It goes straight to the battery; look at the wires; they are Low speed, high speed, and ground.
The ground should be easy to pick out, and there's a wiring diagram here if you look for it.
Hold tight, and don't lose any fingers, lol.
post #3 of 8 (permalink) Old 02-08-2016, 07:53 AM
T6Rocket's Avatar
It's new, my suggestion is to put it in! We're not talking about a really hard job here.
The fan is not meant to run w/o being mounted, too dangerous.
EDIT: install tip, you can swap out the fan w/o removing the upper rad hose/coolant. IIRC, I removed one coil pack to squeeze the thing out of there.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #4 of 8 (permalink) Old 02-08-2016, 04:22 PM
Al
Agreed.
I've been working on a driver for a Mark 8 fan, that's been lots of fun.
I have it bolted to a desk; it draws over 70A at startup, if you don't use a PWM driver.
post #5 of 8 (permalink) Old 02-08-2016, 08:30 PM
V8ThunderCat's Avatar
Al
+1
When scouring a junkyard for a fan, I had unplugged the old fan and plugged the other in with it just resting on top of the radiator. Needless to say when I turned the key to check the fan it promptly kicked itself around and could have damaged something or someone had they been in the right or wrong spot. At least I knew it worked but had someone been trying to hold it down I'd figure someone would have had some torn up fingers.
Yours is new so just install it already. I too managed to install one without removing the rad hose but I usually go ahead and get it out of the way because it's sooo much easier if you do.
-Randy-
V8ThunderCat is offline
post #6 of 8 (permalink) Old 02-09-2016, 07:47 AM
T6Rocket's Avatar
Assuming the new part is just a motor, you may have to make a trip or two to the hardware store for bolts and nuts. They have to be just the right length, with lock washers, etc.
Obviously, you have to grind away the factory rivets from the old fan shroud. You would think a job like this would not require a die grinder!
Al
Previous Fords:
post #7 of 8 (permalink) Old 02-23-2016, 10:40 PM Thread Starter
TBird94's Avatar
The new fan assembly didn't have an indicator for the ground, so I went by the wire colors on the existing connector.
Top wire/pin: black = ground (of course)
Middle wire/pin: blue = low speed
Bottom wire/pin: black w/orange stripe = high speed
After testing the both assemblies and removing the old, I could see the old unit had a marker for the ground. The old unit worked. It was just VERY noisy, intermittently. The new fan runs quietly. Not whisper quiet, but much better.
Last summer, my shop direct-wired the fan. So, the noise was not a fan speed issue, probably just a bearing going bad?
TBird94 is offline
post #8 of 8 (permalink) Old 02-23-2016, 10:51 PM Thread Starter
TBird94's Avatar
Al
I replaced the entire assembly. It was only a few dollars more than just a motor. I couldn't find a Ford part, so I went with NAPA. It looks like they used cheap hardware that will rust in less than a year. I may replace it with stainless.
TBird94 is offline
