Oil and filter change - TCCoA Forums
post #1 of 7 (permalink) Old 02-23-2016, 03:23 PM Thread Starter
Just had an oil and filter change on my '96 XR7 3.8 V6.
The Mechanic filled the crankcase with 5W-20 oil, and an Autocraft oil filter. Did he use the correct grade of oil? Is The filter of good quality?
laminarflow is offline
post #2 of 7 (permalink) Old 02-23-2016, 04:07 PM
For the oil - what does the owner's manual say? My copy of the service manual specifies 5W30 for normal usage; 10W30 if the coldest will stay above 0F. So I'd swap to 5W30 next oil change. The brand is somewhat important also - for that, I'd scan through BobIsTheOilGuy.COM and see what he recommends that's local to you (I have been using Motorcraft 10W40 in my 1991, which is a recommended weight for it ... but am now using Valvoline High Mileage 10W40 due to the increasing price and difficulty getting Motorcraft SynthBlend 10W40 around here.)
Autocraft - I stick with Motorcraft myself, although I've just swapped to a FL-300 from the FL1A that my 1991 5.0HO specifies (the FL-300 is 1" shorter, but also fits the Dakota, so since I get a quantity discount ... )
Fuelly
RalphP is offline
post #3 of 7 (permalink) Old 02-24-2016, 12:08 AM
TBird94's Avatar
For what it's worth, I use 10W30 for my 4.6 V8.
Filter? Does the 3.8 V6 need a filter with an anti-drainback valve?
My 4.6 needs an anti-drainback valve, to prevent "dry start" knock. My shop uses "Brand-X" filters that cause a knock on start up. You would think they should know better. They probably do, but they save many thousands of $$$ by using aftermarket parts.
I do my own oil changes and use a Motorcraft FL820S filter. I think the equivalent for your 3.6 is the FL400S(?)
A Motorcraft oil filter costs about $2-3 more than aftermarket filters. Why would I try to save $2-3??
TBird94 is offline
post #4 of 7 (permalink) Old 02-24-2016, 02:37 AM
It may not NEED one, but it sure should HAVE one.
It's got cam bearings, they're just in the block, not above the head.
Fuelly
RalphP is offline
post #5 of 7 (permalink) Old 02-24-2016, 08:34 PM
If that's the case, you're overpaying. Check out Amazon.
post #6 of 7 (permalink) Old 02-24-2016, 11:22 PM
TBird94's Avatar
Yes, Amazon has good prices, and free shipping for "prime" members.
I said about $2-3 more for a Motorcraft filter, but that was just an estimate. Any time a price is mentioned, someone will say they got a better deal.
TBird94 is offline
post #7 of 7 (permalink) Old 02-26-2016, 08:32 PM
tbirdtess's Avatar
filter
$3 is nothing. Price an engine.
I run RACING filters. Motorcraft racing is good.
I also run 20w50. BUT that is for racing!
5w30 should be correct.
what's the milage?
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
