Sunroof motors - same for all MN12? - TCCoA Forums
post #1 of 3 (permalink) Old 03-26-2016, 01:09 PM Thread Starter
S4gunn's Avatar
All:
I have a sunroof motor from a 93 tbird. This is the assembly that bolts to the underside of the roof underneath the headliner behind the sunroof and actuates it.
Q: Is it the same for all 89-97 tbirds/cougars?
-g
http://goo.gl/csaet4
S4gunn is offline
post #2 of 3 (permalink) Old 03-26-2016, 01:33 PM
97s aren't made by Webasto so 89-96
post #3 of 3 (permalink) Old 03-28-2016, 06:39 PM
Rayo's Avatar
They used a few different Sunroof Motors in the 1989-1997 MN12..
I'll try to break it down for you..
1989-1993 MN12, and the 1993 Lincoln Mark VIII all use the same Sunroof Motor Assembly..
1994-1996 MN12, and the 1994-1996 Lincoln Mark VIII all use the same Sunroof Motor Assembly..
The actual Motor itself is the same between 89-96..The assembly the motor attaches to is what changed throughout the years..
1997 MN12 use a completely different Motor and Assembly..
1991 Ford Thunderbird Sport
Rayo is offline
