Broken sensor - TCCoA Forums
post #1 of 9 (permalink) Old 03-30-2016, 10:51 AM Thread Starter
Matt_aka_Dale's Avatar
Broken sensor
Since this sensor looks broken, I'd like to replace it. However I'm not sure what it is or where it goes.
Matt_aka_Dale is offline
post #2 of 9 (permalink) Old 03-30-2016, 02:36 PM
Woodman's Avatar
Is that in the trunk? What does the harness it's plugged into go to?
Woodman is offline
post #3 of 9 (permalink) Old 03-30-2016, 02:59 PM Thread Starter
It's in the engine bay and it's off of the harness that goes to the brake reservoir
post #4 of 9 (permalink) Old 03-30-2016, 07:51 PM
Is this on the Teves II system? A year/engine would help, as would a photo showing the master cylinder.
post #5 of 9 (permalink) Old 03-31-2016, 08:34 AM Thread Starter
1989/3.8l
post #6 of 9 (permalink) Old 03-31-2016, 03:50 PM Thread Starter
You can see that the sensor in question is in the same harness as the brake fluid level sensor and the master cylinder ground.
post #7 of 9 (permalink) Old 03-31-2016, 04:29 PM
Rayo's Avatar
I'm surprised your Brake Fluid Reservoir isn't empty right now, or is it??
Anyways, that piece hanging off of that connector is part of your Brake Fluid Reservoir..
I have it circled in this pic:
1991 Ford Thunderbird Sport
Rayo is offline
post #8 of 9 (permalink) Old 03-31-2016, 04:46 PM Thread Starter
Um...well that explains where it goes! And surprisingly enough it is still full of fluid. Thank you for the help
post #9 of 9 (permalink) Old 03-31-2016, 06:20 PM
I broke that piece off Platoribs' black SC when I was doing the manual pedal conversion, just getting the wiring out of the way for the hole saw, it's very brittle. Luckily that car is getting converted to conventional, I recommend the same.
