Frustrating fuel filter issues - TCCoA Forums
 3Likes
  • 1 Post By Thunderstruck95
  • 1 Post By T6Rocket
  • 1 Post By r429460
post #1 of 22 (permalink) Old 06-27-2016, 04:20 PM Thread Starter
KULLER94's Avatar
Removing this damn fuel filter is starting to become a very frustrating process for me. I bought the 8 dollar fuel line release kit at oreilly in an attempt to release the front line from the fuel filter, but it seems when I push the release tool up in to the line, the thing still wont pull off. Dont know what it is im missing here.
KULLER94 is offline
post #2 of 22 (permalink) Old 06-27-2016, 05:44 PM
rbrown's Avatar
I haven't worked on a fuel filter in a long time but I thought both ends had the little white clips. Or is it one white clip and a spring lock on the other side?
Anyway, on spring locks, once you push the tool in to release the spring, pull it back out then try to pull the filter off. Sometimes the tool will hold the filter on.
91 Festiva 1.3L baby 5 speed
10 Flex Brick Twin Turbos
*Rodney*
rbrown is offline
post #3 of 22 (permalink) Old 06-27-2016, 08:54 PM
Try twisting/rotating the filter back and forth in relation to the line as you pull.
post #4 of 22 (permalink) Old 06-27-2016, 09:20 PM
ikutoisahobo's Avatar
Fuel filter was super easy for me, take the filter out of the bracket and then pull the black and white clips out, I managed to break one but that doesn't matter since most fuel filters will come with the clips. Use the quick-disconnect tool and push it inside the line to release the spring and pull the filter away from the line. Sometimes the spring won't go in from corrosion or whatever so push the tool in further.
ikutoisahobo is offline
post #5 of 22 (permalink) Old 06-27-2016, 11:11 PM
Thunderstruck95's Avatar
If you are using a metal disconnect tool- I have never had good luck with those. I use a set that is plastic that I think I got from Car Quest. They are all white on a black rack. They are a little thinner then the metal tools and a bit plyable, which help message the spring open.
mcm51 likes this.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #6 of 22 (permalink) Old 06-28-2016, 07:32 AM
sik97bird's Avatar
Have you tried pushing the line in towards the filter assembly with the clip tool pushing against it. Usually how mine comes apart.
sik97bird is offline
post #7 of 22 (permalink) Old 06-28-2016, 08:35 AM Thread Starter
KULLER94's Avatar
It seems the issue is that the tool isnt thick enough to fully lift the tabs over the ridge on the fuel filter. Will have to rig something together.
KULLER94 is offline
post #8 of 22 (permalink) Old 06-28-2016, 08:54 AM
T6Rocket's Avatar
It helps to have a good fitting tool. IIRC, I got my latest one at Advance, which worked great.
They are all made a little different. A good fitting one will take it right off, but a different brand of the same tool won't touch it. It's a crapshoot. Don't force it, or it will bend the tabs, making all future removals next to impossible, right tool or not.
Al
mcm51 likes this.
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #9 of 22 (permalink) Old 06-28-2016, 11:11 AM
r429460's Avatar
I agree with the metal X tool, throw it out and buy the plastic set.
Also whats wrong with the fuel filter?
mcm51 likes this.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #10 of 22 (permalink) Old 06-28-2016, 02:44 PM
T6Rocket's Avatar
It's all in the diameter - if it's a touch too small, it won't expand the clips enough. I have a metal one.
Al
Previous Fords:
T6Rocket is offline
post #11 of 22 (permalink) Old 06-28-2016, 03:22 PM Thread Starter
KULLER94's Avatar
Just hasn't been changed in 60k so I figured it was time.
KULLER94 is offline
post #12 of 22 (permalink) Old 07-01-2016, 07:56 PM
I just had the same issue with mine. The front braided end won't come free. I am using the plastic removal tool too. Maybe my tool is worn out. I will try a new disconnect tool. Thanks guys!
JPJP is offline
post #13 of 22 (permalink) Old 07-01-2016, 08:30 PM
The big issue is usually the o-rings being melted to the fittings.
post #14 of 22 (permalink) Old 07-01-2016, 08:33 PM
I think I just yanked too hard and messed up the spring before I realized it required a "tool". I guess I could always cut off the braided section and replace it with rubber high pressure fuel line hose.
Of course add a pair of hose clamp clamps. One to go on the filter and the other where I splice into the line.
JPJP is offline
post #15 of 22 (permalink) Old 07-01-2016, 08:37 PM
I had to make my own tool for my 97 Cougar. I took a Techron fuel additive bottle and used the neck of it, slit it and made it into a wedge with a spot that allowed me to get it in place and slide into the spring lock and release it.
I can't find a picture of it, but I have all manner of spring lock tools and none of them worked. The cage style (not enough room to get it on there), the plastic ones (not strong enough to press in place without deforming), scissor type (not built with close enough tolerances didn't close to a round shape), the aluminum single size each one tool, don't remember why it didn't work.
Bangster is offline
post #16 of 22 (permalink) Old 07-02-2016, 04:32 AM
ogbird95's Avatar
I did mine a few weeks ago. I used the harbor freight metal set. I had to pull the filter away from the braided hose put the tool onto the filter, and with two flathead screwdrivers between the filter and the tool pry on either side. With a few grunts and curses I got it out. ( to my amazement)
ogbird95 is offline
post #17 of 22 (permalink) Old 07-02-2016, 09:16 AM
Are these the ones? 4 Piece Fuel and Auto Trans Line Disconnect Tool Set
These look better made than the ones I have, but I question the 4, but on'y having 3 sizes, and the part that slips in looks too big to fit.
I don't remember what my 97 Mark VIII has (the filter requires the wheel and fender liner to be removed) but it didn't cause me any issues.
Bangster is offline
post #18 of 22 (permalink) Old 07-02-2016, 12:42 PM
ogbird95's Avatar
Yep that's the set I used. I would agree that it would have helped it was a bit thinner, if you can find a set that works better let us know.
ogbird95 is offline
post #19 of 22 (permalink) Old 07-02-2016, 12:46 PM
OK, I replaced the braided section of line (and fitting) with rubber fuel line. Good to go and if I ever replace the filter again it will be a breeze!
JPJP is offline
post #20 of 22 (permalink) Old 07-02-2016, 10:01 PM Thread Starter
KULLER94's Avatar
be sure to check that line every 5k miles or so, it may be rated for fuel but that hose still rots rather quickly out in the weather.
KULLER94 is offline
post #21 of 22 (permalink) Old 07-03-2016, 08:06 PM
Makes sense, thanks!
JPJP is offline
post #22 of 22 (permalink) Old 07-05-2016, 07:37 AM
T6Rocket's Avatar
Al
Previous Fords:
T6Rocket is offline
