Horn not working - TCCoA Forums
 3Likes
  • 1 Post By Trunk Monkey
  • 1 Post By XR7-4.6
  • 1 Post By Rodeo Joe
post #1 of 9 (permalink) Old 07-24-2016, 10:57 AM Thread Starter
Horn not working
So my horn is not working. Fuse is good, relay is fine and is clicking when 12 volts applied. The relay is getting 12 volts and is hot all the time. I had to replace the clock spring since I accidentally turned the steering wheel over too many times. Derp.
I don't have the PCM, cruise control did a coyote swap. Not sure if it is linked together.
Any ideas?
post #2 of 9 (permalink) Old 07-24-2016, 11:52 AM Thread Starter
Ok I fixed it. I plugged the cruise control servo back in. I guess they are connected. I'll have to figure out which wires I can tap into each other to make the loop back to the steering wheel.
post #3 of 9 (permalink) Old 07-24-2016, 12:11 PM Thread Starter
So here is the wiring diagram of the horn / cruise. What wires would I tap together to bypass the cruise servo?
post #4 of 9 (permalink) Old 07-24-2016, 12:47 PM Thread Starter
haha never mind I guess I don't need help. If you ever want to bypass your cruise control and you need your horn, you have to tap the Black (Ground), Light Blue/Black (Control Switch Imput) and the Dark Green/Orange (Control Switch Return) all together.
post #5 of 9 (permalink) Old 07-24-2016, 02:25 PM
Epic thread of the day! LOL
Pose a question then fix it yourself. There's nothing like talking yourself through a problem.
Anyway, glad you got it working. Congrats on troubleshooting it yourself.
OxmanWI likes this.
post #6 of 9 (permalink) Old 07-24-2016, 02:33 PM Thread Starter
Thanks the wiring diagram book has come in handy
post #7 of 9 (permalink) Old 07-24-2016, 02:40 PM
Nice! I was halfway through writing a response as I ran into frustrating computer issues. Glad you got it, the way the EVTM lays out the circuit is confusing, i went through the same frustration with my 96-97 servo conversion
OxmanWI likes this.
post #8 of 9 (permalink) Old 07-24-2016, 02:44 PM
X2!
Time for a cold one Josh!
OxmanWI likes this.
post #9 of 9 (permalink) Old 07-24-2016, 04:18 PM Thread Starter
Cold beer of the day, Liquid Aloha - Longboard by Kona Brewery
