A/C help - TCCoA Forums
post #1 of 6 (permalink) Old 07-31-2016, 02:51 AM Thread Starter
A/C help
I was looking for some help with my '97 Tbird, the cold air will only blow from the heater or defrost, no longer from the dash vents. Thanks in advance for the help.
1997thunderbird is offline
post #2 of 6 (permalink) Old 07-31-2016, 12:54 PM
Check the yellow vacuum line under the dash.
post #3 of 6 (permalink) Old 07-31-2016, 08:10 PM Thread Starter
Thanks, yes I did that and the lines are connected. I also checked the lines under the hood to where they split before going into the firewall, all vacuum seems to be good to that point.
post #4 of 6 (permalink) Old 08-01-2016, 02:46 AM
Blend door actuator?
post #5 of 6 (permalink) Old 08-06-2016, 02:31 PM Thread Starter
found part
Yes I was thinking the same thing. While poking my head under the dash, I noticed this part laying on some wires, can anyone tell me if this could be part of the air conditioning issue?
If you look at the lower picture, left side, it broke off something at that location.
post #6 of 6 (permalink) Old 08-15-2016, 03:10 PM
is it only blowing from the top of the dash at the windshield? emergency defrost mode only? can that temp control unit (EATC) run a self diagnosis check?
1) '94 Mark VIII 91k, on air, Red garnett glaze, black interior total swap; hub swapped with Cobra front calipers 18" 5 spokes, jmod with cooler, Bilsteins, tbird solid rear sway bar, aftermarket audio system with 212 sub, tint
2)'98 Mark VIII LSC 124k, on air, medium charcoal green; ivory/mocha interior; jmod with cooler, tint, Bilsteins, tbird solid rear sway bar
ddnsherrill is offline
