Door pins going - TCCoA Forums
 2Likes
  • 1 Post By Rodeo Joe
  • 1 Post By CrystalPistol
post #1 of 20 (permalink) Old 08-17-2016, 08:33 PM Thread Starter
Door pins going
My drivers side door is sagging again. I replaced the hobg pins twice already. This last time the brass bushings fit in very loose. They have already warn out. Is there a hing pin kit out there with a larger OD bushing? I think the holes in the hinges are worn larger. Is there an option other than replacing the hinges?
Kidd-7 is offline
post #2 of 20 (permalink) Old 08-17-2016, 09:42 PM
Woodman's Avatar
You could weld in some filler in the widening holes, then drill it to spec.
Woodman is offline
post #3 of 20 (permalink) Old 08-18-2016, 07:22 AM
T6Rocket's Avatar
I had one of the holes partially filled, then ground that part back out with a dremel until the bushing fit in.
I don't see how you could re-drill that, unless you really clamp it down in a drill press. The drill bit will jump into the center of whatever hole is left. I would not fill the whole thing, just the egged out part. Even the small amount of welding I had done made those rubber bushings hard as a rock.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #4 of 20 (permalink) Old 08-18-2016, 05:47 PM
Could just replace the hinges.
post #5 of 20 (permalink) Old 08-19-2016, 07:26 AM
T6Rocket's Avatar
Replace them with what? Junkyard hinges?
Al
Previous Fords:
post #6 of 20 (permalink) Old 08-19-2016, 07:51 AM Thread Starter
Al
That's my thing too... These cars are like 20 years old, if my hinges are this worn, there's not a good chance I'll find some junk yard ones that are not worn.
I like the welding idea, I don't have a welder nor the welding skills.
Kidd-7 is offline
post #7 of 20 (permalink) Old 08-19-2016, 08:09 AM
T6Rocket's Avatar
There has got to be a welding shop near you, look in the yellow pages. Not sure where in NC you are, but Sapp's welding in Garner did mine. It is near Raleigh.
Al
Previous Fords:
post #8 of 20 (permalink) Old 08-19-2016, 08:10 AM
Rayo's Avatar
That's what I was thinking too..
Hell, you could even use some hinges out of the junkyard..
It's not like you wouldn't be able to tell, if they were bad..
Most of the time, when the hinges are shot you can't even close the door without lifting up on it as you close it..
1991 Ford Thunderbird Sport
Rayo is offline
post #9 of 20 (permalink) Old 08-19-2016, 08:26 AM
T6Rocket's Avatar
Judging by how mine was, I get the impression only the bottom one eggs out, from the weight of the door. Just as well as the top one seems like a disaster to R&R. I imagine the bottom one is no prize either.
Al
Previous Fords:
post #10 of 20 (permalink) Old 08-19-2016, 08:58 AM Thread Starter
Al
I'm in Fuquay now, so Garner is right up the road. I'll check them out. Thanks.
Kidd-7 is offline
post #11 of 20 (permalink) Old 08-19-2016, 02:44 PM
Al
Negative!
Search is your friend!
Lower hinge
Upper hinge
CDsDontBurn likes this.
post #12 of 20 (permalink) Old 08-19-2016, 06:12 PM
Mr.Thunderbird's Avatar
How long did your replacement pins last? Mine are getting to the point of needing to be replaced, but for the 1st so maybe no wobbled out hole to deal with this time.
Mr.Thunderbird
Mr.Thunderbird is offline
post #13 of 20 (permalink) Old 08-19-2016, 10:05 PM
The Dorman kit has bigger OD bushings than factory, which is why you have to drill the hinges out with a 15/32" drill bit. (Note the size - almost none of the how-to's tell you that!)
But they're Dorman, so ...
Fuelly
RalphP is offline
post #14 of 20 (permalink) Old 08-20-2016, 11:01 AM
JoeyICU's Avatar
I am glad someone asked about this topic. Both my doors sag, not bad, but they have to be closed with some force and that will damage other things soon enough also. Replacement hinges look expensive.
JoeyICU is offline
post #15 of 20 (permalink) Old 08-20-2016, 12:20 PM
CrystalPistol's Avatar
Lots of past threads .... but here's one that helped me most a few years ago. I did not make my cradle the same, mine is shorter so I can use a small floor jack under it to adjust my "support" to remove weight while R&Ring hinge pins.
http://forums.tccoa.com/15-exterior/...do-i-need.html
http://forums.tccoa.com/6-general-te...inge-pins.html
CrystalPistol is offline
post #16 of 20 (permalink) Old 08-21-2016, 01:47 PM
T6Rocket's Avatar
If they sag at all, replace the pins with the Dorman kit. It is possible for the metal around the door striker to crack, that would not be good.
I would not buy new hinges. I am sure the bottom one is no prize, but you have to remove the dash to replace the upper one! Then there is the adjustment aspect of the job.
Al
Previous Fords:
post #17 of 20 (permalink) Old 08-21-2016, 04:04 PM
I just did my driver's side hinges (repin and rebush); I'll probably need to replace the lower hinge anyway, I waited too long and the hole's oblong now.
Fuelly
RalphP is offline
post #18 of 20 (permalink) Old 08-22-2016, 08:47 AM
T6Rocket's Avatar
Mine was oblong too, that's where the welding comes in. Grinding the weld back out with a Dremel is tedious. Can't fit any bits from a die grinder down in there.
Al
Previous Fords:
post #19 of 20 (permalink) Old 12-01-2016, 09:53 PM Thread Starter
Sorry for the delay, your question got lost in the shuffle. The first replacement lasted a few years, but this last time only lasted a few months.
Kidd-7 is offline
post #20 of 20 (permalink) Old 12-02-2016, 08:46 AM
Tbird Bob's Avatar
How about using Steel Putty? I haven't used it for your application, but everything I've done with it was entirely satisfactory. Steel putty - Manufacturers of Steel putty # Steel putty Suppliers # Steel putty Distributors & Exporters, Monarch Industrial Products, India, Tamil Nadu, Theni
Tbird Bob is offline
