Speed tips. - TCCoA Forums
 17Likes
post #1 of 32 (permalink) Old 11-13-2016, 12:28 AM Thread Starter
Speed tips.
Hello all, I'm kind of new and wanted to test the waters to see if I could get some advice. I have a 95 Bird and want her to be fast. Any suggestions on an EFI 351W or 302, and does anyone know if a Mustang differential would fit my car? I'm sure these questions have been asked before but I cannot find them. Also I would love to see what other people are doing with their Bird or Cougar so please share some pictures. Thanks in advance.
thunderhorse95 is offline
post #2 of 32 (permalink) Old 11-13-2016, 08:54 AM
How much money do you have to spend?
post #3 of 32 (permalink) Old 11-13-2016, 09:03 AM
bowez's Avatar
Mustang diff will fit if you either get a IRS Cobra, go to a soild axle or if your just talking about just the carrier?
351W you will need an aftermarket hood. With you having a 95 stay with a 4.6 or go to a 5.0 and not a 302.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #4 of 32 (permalink) Old 11-13-2016, 09:52 AM
Depending on your resources both choices may be slow or slower, or at the very best as fast as a stock 4.6. I assume you may be looking for junkyard options based on sourcing the differential from a Mustang, and while there are potent enough 5.0s there, like 96 Explorers, few but the ones that came in 91-93 Thunderbirds are drop-in ready due to motor mounts, belt drives/accessories and intake configurations. In terms of 5.8s in the same junkyard scenario, they're dogs, most choices aren't even roller blocks. If your goal is a buildup they've all got potential, but the playing field between the 5.0 and 4.6 is pretty level these days, with the 5.0's only real advantage being the option to stroke it(naturally aspirated 4.6s don't respond well to that) but at this point we're talking thousands and thousands of dollars in parts and machining labor, at that point if you want fast, get a complete PI 4.6 engine from a junkyard(common as dirt, can be had as cheap as $350) and put the remaining change into a supercharger for it.
Plenty of pictures to be found on the forum in the videos/images section, as well as the gallery and garage sections. Far be it for me to whore my car, but that's a lot less effort on my part
Woodman likes this.
post #5 of 32 (permalink) Old 11-13-2016, 06:43 PM
Woodman's Avatar
First things first, replace worn out suspension parts/bushings/bearings. Then upgrade to a one piece aluminum drive shaft so you don't get the death wobble. Better brakes, the Mustang GT PBR calipers or Cobra calipers/rotors bolt right up to 93+ spindles. You need to redrill the rotors for our bolt pattern, which is MUCH easier and cheaper than swapping the rear hubs. 17" wheels have much better selection of high performance tires.
Having the platform up to snuff before upgrading the motor is VERY important, otherwise you'll go careening into something hard and stationary at high speed.
The 5.0 really isn't that great. It's not a bad motor, and the bored/stroked ones cost as much to build up as a good modular, and you can get a factory stock aluminum modular out of explorers/mountaineers for cheap and build up a powerful motor.
Woodman is offline
post #6 of 32 (permalink) Old 11-13-2016, 07:25 PM Thread Starter
Well I got more responses than expected. My plan is to drive it stock and stock pile parts. Build a monster engine and rear end with either 3.73's or 4.10's. The more money I spend the longer it will take but I'm in no hurry. I have brothers with legitimate sports cars and want to beat them with a sleeper. I would like to get a bare block or short block and build it up from there, I just can't decide which direction to go. As far as the rear end goes I would like posi-lockers as well as the before mentioned gears.
post #7 of 32 (permalink) Old 11-13-2016, 08:20 PM
See my signature for suggestions ....
post #8 of 32 (permalink) Old 11-13-2016, 08:57 PM
Thunderstruck95's Avatar
The biggest single improvement will be gears. I ran 3:73s in my Bird for a long time and they were great, but over 93 mph, my driveshaft would send a distinct vibration through the floor.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #9 of 32 (permalink) Old 11-13-2016, 10:32 PM
MerkCougar's Avatar
In my opinion, which is by no means anywhere near even the most novice of experts. Weight removal will be your best gain dollar for dollar. Considering you can nearly do it all yourself, which equals no payment to a shop or friend. Then there is the world of aftermarket parts and modifications which once again will require payment to your desired course of action, but also including but not limited too is the fact that depending how extensive the mod or mods may be, they could require a bit more maintenance and attention one may not suspect. This is just a couple reason's weight removal in my head, would be the first place to start when ones self is struck with the need for speed.
If I personally didn't prefer a semi luxury, no road noise and complete interior and sealed inside cabin, then I would opt to remove all the uber excess material ford so hastily applied dang near everywhere in This car.
MerkCougar is offline
post #10 of 32 (permalink) Old 11-13-2016, 11:38 PM
Honestly unless you're willing to sit on milk crates, "free" weight removal is really a lose lose scenario. The front seats and dash assembly are the only substantially heavy parts of the interior(probably a bit under 300lbs combined), while the rest of the interior including the rear seat is maybe another 100?(frankly that guesstimate seems high) That and the sound deadener isn't near as heavy as most think it is, we're talking barely 40lbs from firewall to trunkfloor, and takes about 40 hours of work to remove the damn stuff(exaggeration, but only slightly!). Simply put, this is just a heavy platform, the so called uber excess material Ford so hastily applied dang near everywhere in these cars is the SLA front end, independent rear suspension, and midsize(bordering full size by 90s standards) dimensions. You won't find any less uber excess material on a 95 Mustang, it's platform is simply more rudimentary and compact, all else is basically equal.
None of this will net you much E/T either. No offense to _95badbird but as I recall his car was barely breaking 13s after extreme(sub 3000lb) weight removal, a 351 under the hood and slicks on the back. Quite a bit faster than stock for sure, and certainly a fun build to watch, but a well setup full weight PI swapped Tbird with gears and a converter can do that. Less weight has undeniable benefits but even the late great Colin Chapman gave the Esprit a nice interior, the key is starting small and light to begin with. You'd be better off use the extra weight and gravity to your advantage, picking your races against lighter cars on downhill roads
Woodman likes this.
post #11 of 32 (permalink) Old 11-14-2016, 10:20 AM
What kind of " legitimate sports cars" are you trying to out run? Find out what those cars run in the quarter mile, then you will have a target for what you will have to do to your car. Then you can make a plan to achieve the speed that you want.
When it comes to weight removal, the drag racer rule of thumb is you gain .1 seconds in the quarter for every 100 pounds you remove from the car. So if you removed 300 pounds, your car would be about 3 tenths of a second quicker. This basic math also works for horse power- you will gain about a tenth of a second for every 10 hp you gain. These are just basic estimates, but they give you an idea for planning modifications to achieve a goal speed.
My stock 95 Thunderbird ran in the 16.4/16.2 second range. Then I added Kooks headers, a full catless exhaust with 2 1/2" pipes merging to 3" and back to 2 1/2" with mufflers, a cone air filter, a shift kit, a traction lock with 3:73 gears, and a good dyno tune and I was able to get a best of 14.72 in the quarter mile.
This was a fair time for a Thunderbird, but still pretty slow compared to other cars that are on the street today. You will need to make a plan and be realistic for the results that you want out of your car.
1995 T-Bird.
post #12 of 32 (permalink) Old 11-14-2016, 01:41 PM
S4gunn's Avatar
If all you want to do is break into the 14s, a 2012 Toyota Camry V6 will do the quarter mile in 14.2sec @ 100.6 mph
https://goo.gl/upCoIz
2012 Toyota Camry First Test - Motor Trend
It's the march of technology.
CDsDontBurn likes this.
http://goo.gl/csaet4
S4gunn is offline
post #13 of 32 (permalink) Old 11-14-2016, 02:12 PM
March of blandness too.
PI swap, tune and gears will get you there too, for a lot less than the ~$14k the V6 Camrys go for.
Woodman and CDsDontBurn like this.
post #14 of 32 (permalink) Old 11-14-2016, 04:12 PM
In the 70's/80's we called them "Japanese Shitboxes".
Square edges, and cracker box sized.
They just came back like a bad Godzilla movie, lol.
post #15 of 32 (permalink) Old 11-14-2016, 04:15 PM
I wonder how fast a tbird could go without disintegrating?
I saw this Mythbusters last night with a rocket sled and a cubic shitload of rockets... I think they hit 500mph, lol.
post #16 of 32 (permalink) Old 11-14-2016, 04:42 PM
Top speed is on the other end of the spectrum... any idea how the aero of our cars compares to modern blandness mobiles? Or to the yet to be determined "legitimate sports cars"?
1995 T-Bird.
post #17 of 32 (permalink) Old 11-14-2016, 06:32 PM
S4gunn's Avatar
I'm betting he wants to outrun a Mustang and Camero (yes, that's how i dun spelt it).
Vs a mustang, you just need to learn how to modulate your right foot when accelerating
Vs a Camaro ZL1 (650HP from the factory for $61k), good luck.
I don't really like this car considering how far Chevy pushed the bar with this car, i'm curious how much more impressive the 2018 Corvette ZR1 will stack up. sigh. Just in time for my "midlife crisis"
-g
S4gunn is offline
post #18 of 32 (permalink) Old 11-14-2016, 07:14 PM
Tbird Bob's Avatar
According to the list, 10th gen. birds are near the lowest in drag coefficient.
Vehicle Coefficient of Drag List
https://duckduckgo.com/?q=drag+coeff...derbird&t=ffab
Tbird Bob is offline
post #19 of 32 (permalink) Old 11-14-2016, 07:29 PM
Vs a Mustang, you just need to learn how to modulate your right foot when accelerating
I don't really like this car considering how far Chevy pushed the bar with this car, I'm curious how much more impressive the 2018 Corvette ZR1 will stack up. sigh. Just in time for my "midlife crisis"
-g
Yea, you're probably right .... or any other car that wants to race for that matter .... there might even be a specific car that he has his eye on beating.
Wow. Great video. The one that took out the new White F150 happened very near me. I recognize the video from when it was originally posted.
Couple of thoughts ...
  • You're going to need a lot of money. I've always said your car can be as fast as your pockets are deep. Most clearly shown by the $61k price tag on the ZL1 above for example.
  • Having a fast car means nothing if you don't know how to drive it. Also, clearly shown in the video.
  • Having a powerful car means nothing if you can't safely put that power to the ground with good road conditions, good tires and a solid suspension.
post #20 of 32 (permalink) Old 11-14-2016, 10:42 PM
Yeah... because 'Murica never put out anything like that!
Bad Godzilla = bad King Kong
post #21 of 32 (permalink) Old 11-15-2016, 04:33 PM
The really funny part is that the pictured cars are Corporate America's Reaction to the small Datsun and Toyotas that were selling like crazy.
You could not hardly Give Away a full size Caddy in 1974; Gas rationing put an end to Huge Detroit cars. (First gas I bought was $0.54/gal+$2 for Yamalube-R 2-stroke oil, lol.)
The 8.8 gears and diffs in the Fairmont will swap parts with ours, lol.
Those were Police cars around here in the 70's.
Wasn't trying to be insulting the Japanese line of old cars; that's just what everyone* called them then.
As it turns out, that era was pretty much the death knell for Detroit; if you look at it from now...
*Everyone with a gas guzzler, lol.
post #22 of 32 (permalink) Old 11-15-2016, 07:48 PM
It gave Detroit the incentive to get off of their fat, lazy, sorry asses and begin their journey towards building the better - not great but better - cars that they produce today.
post #23 of 32 (permalink) Old 11-15-2016, 09:29 PM
I wonder when thunderhorse95 is going to come back and reclaim this thread...
1995 T-Bird.
post #24 of 32 (permalink) Old 11-16-2016, 12:23 AM
By continuing to sit on their fat lazy asses, simply rebadging their Euro market cars for the fat lazy North American market
I thought he was just now, then I realized wrong thunder_______95
post #25 of 32 (permalink) Old 11-16-2016, 07:19 AM
r429460's Avatar
The jap cars are shit boxes, look what they make now, all copies of American and European designs.
Quickest N/A Modular MN12.
01/31/18 PBIR
THE danner EATER
r429460 is offline
post #26 of 32 (permalink) Old 11-16-2016, 03:02 PM
The Cougar was a copy of Jaguar in the 60s, the Tbird a copy of European sports cars of the 50s, the MN12 is a copy of a BMW, half of Ford's product line in the 90s/00s were based on Mazdas, and most of them now are castoffs from Volvo and Ford Europe with the exception of the Tonka toy looking brodozer pickups. That's not even to mention GM with Toyota/Isuzu/Opel or Chrysler with Simca/Mitsubishi/Fiat. American cars haven't been influential on a global scale since the mid-60s, in styling or technology. There's copying going on but I suspect it's the other way around.
post #27 of 32 (permalink) Old 11-16-2016, 03:56 PM
Our cars were the peak moment; they realized "Crap, we can't make cars that last 200k miles before problems; our volume and parts sales will tank!!!".
My co-workers are openly jealous of my cars' reliability, even tho most won't ride with me, lol.
They don't realize I do pre-emptive maintenance; the only thing I regularly break are transmissions.
I keep spares, lol.
post #28 of 32 (permalink) Old 11-16-2016, 09:05 PM
bowez's Avatar
I keep spares, lol.
You could have them ride with me
Grog6 likes this.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #29 of 32 (permalink) Old 11-23-2016, 10:07 PM Thread Starter
Let me ask this, if I get a 302 block will 351W heads and maybe cam fit on it?
post #30 of 32 (permalink) Old 11-23-2016, 10:19 PM
You'd be better off doing the opposite, 351 heads aren't anything special, and I'm pretty sure actually that they're worse than stock E7 heads(correct me if I'm wrong 5.0 fans), but doing the opposite with a 351 block and 5.0 GT40s... find a lightning intake and you got yourself a decent motor. Of course that's after you redo the internals, magnaflux/machine the heads, and upgrade everything for a couple grand, which then would make aftermarket heads seem like a drop in the bucket.
