Correct Jack Points - TCCoA Forums
 7Likes
  • 1 Post By XR7-4.6
  • 1 Post By bowez
  • 1 Post By XR7-4.6
  • 1 Post By V22
  • 1 Post By Grog6
  • 2 Post By xquzzme
post #1 of 28 (permalink) Old 11-20-2016, 12:33 PM Thread Starter
V22
V22's Avatar
Correct Jack Points
Hello all,
I've been reading a few old threads about jacking up the car properly, but I'm still having some trouble.
Just bought a new floor jack. It's actually a low profile trolley jack, but it has a good lift height and it's pretty well built.
My issue is that it doesn't reach the k member by just a few inches. It can reach the rear lift point fine because the rear bumper clears the jack handle, but the front bumper is just too long. This jack was mostly for another car, but I've been trying to make it work by jacking up one side at time and setting it on jack stands, which works fine. I'd rather not buy another jack just for that.
Is it okay that I've been using this (they were already bent when I bought the car):
Or should I just get a pinch weld adapter? Yes, I'm aware that if a piece of metal is badly bent, then it probably can't handle the weight, but I had some work to do and I used a block of wood.
Anything else on the front end that I can use for jacking that's closer to the front?
1996 Mercury Cougar XR7 4.6L , Vermillion
If you see a shiny red car swerving around potholes and parking 10000 miles from all the other plebeians in parking lots, then it's probably me.
V22 is offline
post #2 of 28 (permalink) Old 11-20-2016, 12:45 PM
Tbird Bob's Avatar
Originally Posted by V22 View Post
Hello all,
My issue is that it doesn't reach the k member by just a few inches. It can reach the rear lift point fine because the rear bumper clears the jack handle, but the front bumper is just too long. This jack was mostly for another car, but I've been trying to make it work by jacking up one side at time and setting it on jack stands, which works fine. I'd rather not buy another jack just for reason.
According to the factory service manual, in the front, the K member is the only lift point. I place of a pinch weld adapter, you can use a hockey puck.
Tbird Bob is offline
post #3 of 28 (permalink) Old 11-20-2016, 01:04 PM
I just reach the front jack point from the sides.. if you need to lift both sides you should be using jack stands anyway.
moonshiner180 is offline
post #4 of 28 (permalink) Old 11-20-2016, 01:25 PM
That poor torque box. If you're going to do that jack under section of it that goes over the frame rail, that's where all the metal comes together so it's very strong, whereas the torque box is completely hollow.
Me personally I use a small second jack (like a factory scissor one)under the strut rod mount just to get the front end high enough for my big jack to operate under the center of the K member.
CDsDontBurn likes this.
post #5 of 28 (permalink) Old 11-20-2016, 02:04 PM
Rayo's Avatar
X2
It would be nice if they made an aluminum jack that you could slide under the center of the K-Member..
That way you wouldn't have to use 2 different jacks..
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 28 (permalink) Old 11-21-2016, 04:37 PM Thread Starter
V22
V22's Avatar
Thanks for the replies.
I think I'm just gonna use the frame rail that's just ahead of the torque box, where I put the jack stands. Or I might just get a pinch weld adapter.
So that torque box, it's normally straight, right?
V22 is offline
post #7 of 28 (permalink) Old 11-21-2016, 05:08 PM
Originally Posted by Rayo View Post
X2
Yeah well It would have been nice if Ford didn't make the front overhang 3 feet long too
Yes it's supposed to be a perfect box shape(as the name implies), all that lies below is the firewall, which slopes back just as it does on the other side of the frame rail where the exhaust passes under, so there's a long drop if the steel were to give way. As is it's probably fine if the steel and welds haven't sheared, but I definitely wouldn't jack under there again.
I'm not the biggest fan of jacking the pinch welds either, but still better.
post #8 of 28 (permalink) Old 11-21-2016, 06:10 PM
From the side, I jack using the thicker metal where the transmission mount bolts in; it's never bent or caused a problem.
I did have one Jackass put a jackstand on my fuel lines, tho.
If nothings in the trunk, it will lift front and back on that side, so I place both jackstands, and move to the other side.
It's a problem on the tbird, 'cause my freaking jack won't fit under the car.
post #9 of 28 (permalink) Old 11-21-2016, 06:14 PM
Woodman's Avatar
I have a low profile, high lift jack from Harbor Freight. I jack it from the middle of the frame rail, it jacks the entire side up, I place jack stands on the front and rear of the rail, and move to the other side. If I don't need one end up, I don't put a stand under that end.
Woodman is offline
post #10 of 28 (permalink) Old 11-21-2016, 06:28 PM
Originally Posted by Woodman View Post
... If I don't need one end up, I don't put a stand under that end.
Be careful doing that; you can put a bunch of effort on a bolt, and have the whole car move suddenly, lifting the odd wheel.
If one of the stands shifts, it could be bad.
It makes me a lot happier to do all 4, then it won't move.
post #11 of 28 (permalink) Old 11-21-2016, 09:29 PM
gordonm1's Avatar
I think I was "cleared" by the forum to jack up the rear from the differential mounting bracket and never jack on the differential.
With my Vogtland springs I have to drive the front up ramps to get the jack under it. The ramps often slide out to the front which makes using them as the only lift difficult. I go up the ramps just enough to get the jack under the car and then set brake, block rear wheels and get to jacking. It's not the safest process but jacking from the side really loads up the unibody frame.
gordonm1 is offline
post #12 of 28 (permalink) Old 11-22-2016, 10:52 AM
Woodman's Avatar
It all depends on what I'm doing. If I just need the front end up in the air, I apply the parking brake, chock the wheels, and jack up the front end, put the stands under the front and leave enough on the jack to act as a safety. Rear end stays all the way down. Same if I have to just jack up the rear.
90% of the time though, I'm moving around enough under there where it's more convenient to have all four corners in the air.
Woodman is offline
post #13 of 28 (permalink) Old 11-22-2016, 10:54 AM
Woodman's Avatar
One of these is well worth the $100.
3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump®
It's lower than 3" when fully recessed, and gets the car nearly a foot in the air. Best investment I've made as far as jacks go. I'm on 1.5" Eibachs and I have plenty of room to roll this under the car.
Woodman is offline
post #14 of 28 (permalink) Old 11-22-2016, 11:04 AM
That's not what you described in the previous post, jacking the whole side up from the frame rail and sometimes using a single stand.
post #15 of 28 (permalink) Old 11-22-2016, 01:58 PM
Woodman's Avatar
Yeah, I realized I didn't word it well.
What I was trying to say is, if I only need one end up, I support that side (with two stands) and let the other side down. Usually front or rear, but on occasion left or right. So I'll put the jack in the middle of the car, raise that side, support what needs supported, then repeat the process on the other side.
Woodman is offline
post #16 of 28 (permalink) Old 11-22-2016, 04:10 PM
bowez's Avatar
Have the same jack, had to have it for the SC.
Woodman likes this.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #17 of 28 (permalink) Old 11-22-2016, 04:25 PM
So in other words, both? lol
There's no nautical like standards for cars but to me sides = doors/fenders/quarters, while ends containing bumpers and lights = front or rear ends. It's confusing as hell calling the front or rear end a front side or back side. I never jack the car from the sides to the point both wheels are off the ground, the steeper angle for the jackstands just seems too scary precarious compared to going from the ends
post #18 of 28 (permalink) Old 11-22-2016, 04:42 PM
I agree, Matt; but sometimes I need my stands all the way up, and that really only works from the sides, in a multi-step process.
Dangerous, yes.
I use 6 stands when I do that, so nothing can move far.
That's the only way the transmission comes out...
post #19 of 28 (permalink) Old 11-22-2016, 06:37 PM
I have no problem getting max height out of my stands going end to end. I start on the front under the K member, set the stands a few notches up under the strut rod mounts and set the car down on them. Then I move to the back, jack under the diff mount, lift the rear to roughly level to that of the front and set the stands under the front IRS brackets. Then move back to the front and raise it up and max the stands there, and again to the rear. There's never been a scenario where I've found raising the sides desirable.
Grog6 likes this.
post #20 of 28 (permalink) Old 11-23-2016, 07:57 AM
T6Rocket's Avatar
I jack up just the side for rotating tires. But you don't have to get it far off the ground for that.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #21 of 28 (permalink) Old 11-23-2016, 08:34 PM Thread Starter
V22
V22's Avatar
Actually, on second thought, I'm just gonna use an inflatable mattress as a jack and 2 bean cans for jack stands. I'll make sure to lift from the bumper, it's a well known factory lift point that all the techs use. Sound good?
Woodman likes this.
V22 is offline
post #22 of 28 (permalink) Old 11-23-2016, 10:24 PM
I recommend a wicker basket
post #23 of 28 (permalink) Old 11-23-2016, 11:40 PM
Thunderstruck95's Avatar
Actually, on second thought, I'm just gonna use an inflatable mattress as a jack...
That's been done-
https://youtu.be/OsnwVCOiIp4
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #24 of 28 (permalink) Old 11-24-2016, 09:32 AM
I remember someone local in to 70's picking up a Smoky and the Bandit style Firebird with a front bumper jack.
It tore off even with the radiator, lol.
Apparently those 6.6l engines were heavy...
Woodman likes this.
post #25 of 28 (permalink) Old 11-24-2016, 01:15 PM Thread Starter
V22
V22's Avatar
Where can I buy one? Heck, it's looks so solid I don't even need the bean cans!
JK, the floor pan is actually better. I need some drainage holes anyways.
V22 is offline
post #26 of 28 (permalink) Old 12-06-2016, 05:20 AM
Scyal8tr's Avatar
I screwed 2 10x6 together staggered and drive up on the wood. That gets the car 4inches higher to get the jack under .
Going up The ramps half way sounds like a accident waiting to happen
Hope this helps..
That's been done-
I seen a air bag jack that gets filled with the exhaust pipe work in the desert...Just like the vid
Scyal8tr is offline
post #27 of 28 (permalink) Old 12-06-2016, 06:47 PM
Jack points = red. Jackstands = yellow.
post #28 of 28 (permalink) Old 12-27-2016, 09:44 PM
If your ramps want to slide out trying to drive on, set them on a couple old strips of carpet with about 6" of the carpet our past the bottom of the ramp. The weight of the tires on the carpet keep the ramps from sliding.
Woodman and Tbird Bob like this.
xquzzme is offline
