mark vIII air bag troubleshooting - TCCoA Forums
post #1 of 8 (permalink) Old 12-08-2016, 07:10 AM Thread Starter
coggonobrien's Avatar
So I'm having typical wierd issues and wanted to see folks opinion. The rear bags always hold air, the fronts can hold all night and when I start the car it lets down and may not fill right away. If I move the car or bounce it while the compressor is running they will come back up. I've seen the front way overfill before. What are your thoughts?
coggonobrien is offline
post #2 of 8 (permalink) Old 12-08-2016, 07:24 AM Thread Starter
also will thunderbird front struts bolt in place on the mark vIII? I plan to put tokico blues on the tbird so I'm tempted to pull the old assemblies off the tbird and put them on the mark vIII
post #3 of 8 (permalink) Old 12-08-2016, 09:12 AM
Thunderstruck95's Avatar
The Thunderbird struts will bolt on, but you will want to put coils in the back of the Mark VIII at the same time. As for putting coils in the rear, you will need a special plate that will locate the spring. Birds and Cougars have a cone up top that locates the spring, and Lincolns do not have that. If you look at the pictures of the conversion kits, you will notice a plate with bent edges and a pin that fits into a hole in your car. That plate is required and keeps the spring where it needs to be.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #4 of 8 (permalink) Old 12-08-2016, 09:32 AM Thread Starter
any reason I can't put the front struts in and just disable the front fill?
post #5 of 8 (permalink) Old 12-08-2016, 09:46 AM
That might get weird... you would need to keep the level sensors installed in the front... and you will need to cap the two air lines going to the front struts. They are kind of a bastard line size, and I think you might have a hard time keeping them caped and sealed...
1995 T-Bird.
post #6 of 8 (permalink) Old 12-08-2016, 11:09 AM Thread Starter
do the rears lower at speed automatically or just the front?
post #7 of 8 (permalink) Old 12-08-2016, 12:25 PM
I believe that they lower at all four corners.
1995 T-Bird.
post #8 of 8 (permalink) Old 12-08-2016, 12:45 PM Thread Starter
ok, i'm trying to just get by with doing as little as possible. The car is just a short term daily driver until I get ambitous and part it out.
