Door ajar light on dash blinking - TCCoA Forums
post #1 of 5 (permalink) Old 01-17-2017, 01:42 AM Thread Starter
On my 95 T-Bird LX the door ajar light keeps blinking while driving. There is no issue with the console light. For some reasons its in increments of 5. Blink 5 times, stops for a minute then starts again. I soaked the door strikers and latches with WD-40 but to no avail. I recently had a new drivers door window motor installed so I had the glass guy lube the inside of the door. I'm thinking of loosening the latches and cleaning them with WD or electronic cleaner. Any suggestions? Thanks
MRF 95 LX is offline
post #2 of 5 (permalink) Old 01-17-2017, 06:20 AM
Banned
There is a plastic nub the door pushes in for the light to shut off,atleast was on my 97..
Mine would stay lit also..i just glued was washer in wherthehe door stuck the nob to give it extra surface area then it depressed the nob enough to turn the light off.
94badbird is offline
post #3 of 5 (permalink) Old 01-17-2017, 08:14 AM
T6Rocket's Avatar
I bought a new sensor to fix that on my old 95. It is located so far back in the door cavity that you cant even see it, have to go by feel, and with two fingers. Needless to say, they never made it in the car.
Mine only had the light on the warning system near the console illuminated. A perfectly square piece of electrical tape solved that.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #4 of 5 (permalink) Old 01-17-2017, 09:55 AM
Kenz's Avatar
From what I read here the switch is inside the door latch. Mine was doing the same thing, they get gummed up over time. I sprayed some PB blaster into the latch and opened and closed the doors a few times. Has been working fine for over a year now.
I probably should have used Silicon spray now that I think of it, they are probably plastic so IDK if PB blaster will eat away at them or not.
96 Cougar Sport - T45 Swapped
Kenz is offline
post #5 of 5 (permalink) Old 01-17-2017, 11:31 AM
Natesriv's Avatar
probably lithium grease? spray with electronic parts cleaner first?
Natesriv is offline
