Really weird electrical problem - TCCoA Forums
 1Likes
  • 1 Post By RalphP
post #1 of 22 (permalink) Old 08-01-2017, 01:15 PM Thread Starter
30thAnniversaryCat's Avatar
Car started fine this AM and when I went to lunch. On drive to lunch, tach started cutting out intermittently, A/C cut in and out and fan ran really slow regardless of fan speed setting when it did cut on, and red electrical warning light came on. Power windows also barely go up or down. Engine barely turned over when I started it after lunch, and now tach is dead and A/C runs really slow only if I rev up engine speed. HELP, please! (It's WAY too hot here in Texas for this to happen)
30thAnniversaryCat is offline
post #2 of 22 (permalink) Old 08-01-2017, 03:25 PM
Dead alternator, and the battery is now dead.
I did this last month, lol.
post #3 of 22 (permalink) Old 08-01-2017, 03:39 PM Thread Starter
Did you replace battery first and then alternator?
post #4 of 22 (permalink) Old 08-01-2017, 03:44 PM
Thunderstruck95's Avatar
You can probably trickle charge the battery back to life.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #5 of 22 (permalink) Old 08-01-2017, 07:39 PM
I meant dead as in "Out of juice"; but if you leave it that way for a couple of days it will be bad too.
Charge tha battery, and see if it runs fine.
post #6 of 22 (permalink) Old 08-01-2017, 08:24 PM
Yup, alternator.
If it was the battery the doors would lock/unlock while you were engaging the starting circuit. At least that's how it is with a 95.
Jim3inVirginia is offline
post #7 of 22 (permalink) Old 08-01-2017, 09:40 PM Thread Starter
Originally Posted by Jim3inVirginia View Post
Yup, alternator.
Nothing happens when I turn the key. I put in a new bajttery and (so far) all is well. I guess if it's the alternator the battery won't last long, right? I plan to test the alternator at Advance Auto. The red battery light is still lit even with new battery.
post #8 of 22 (permalink) Old 08-02-2017, 12:19 AM
Take a Volt Ohm Meter and read the alternator output. If it's wasted you'll have nothing there.
scottjohnston is offline
post #9 of 22 (permalink) Old 08-02-2017, 06:13 AM
Natesriv's Avatar
What about the old "unplug the positive terminal when it's running, if it dies, it's the alternator or charging system" trick?
Natesriv is offline
post #10 of 22 (permalink) Old 08-02-2017, 11:23 AM
That's a good way to fry today's alternators ... and ECUs!
Don't.
What you do is load test the alternator while watching the resultant wave form; or take it to a trusted shop that'll do that for you.
Grog6 likes this.
Fuelly
RalphP is offline
post #11 of 22 (permalink) Old 08-02-2017, 11:58 AM
Natesriv's Avatar
AHH I'd forgotten most auto parts stores will check your charging system for free...
Yeah do that instead!
Natesriv is offline
post #12 of 22 (permalink) Old 08-02-2017, 12:30 PM
Well, I DID specify "trusted shop"; for me, that lets out most auto parts stores.
Fuelly
RalphP is offline
post #13 of 22 (permalink) Old 08-02-2017, 03:37 PM
ikutoisahobo's Avatar
Sounds like a bad or weakening alternator. Usually if you can get the car running, the alternator can keep everything going if the battery is not holding a charge. Now if the battery is ultra-fxxxxd that could cause issues.
But since you say the battery change resolved it, well then it could have just been the battery. But I still feel like that alternator is dying.
ikutoisahobo is offline
post #14 of 22 (permalink) Old 08-02-2017, 05:43 PM
Alternators are expensive; you can probably rebuild it, as long as the diode pack is good.
If you go out and feel of the alternator a few hours after driving it, and it's not warm, the diode pack is probably good.
Measure the voltage with a voltmeter, then start the car.
Depending on temperature, it will go up from whatever the battery was, to between 13.8 to 14.8V.
If it doesn't do that, it's bad.
I've used these rebuild kits before; which kit depends on your alternator.
I have a V8 with a 130A alt, and used this kit:
https://www.amazon.com/Victory-Lap-F.../dp/B000CFKSBO
I've used their starter rebuild kits too, with good results.
ymmv.
post #15 of 22 (permalink) Old 08-03-2017, 01:47 PM
Thanks for the tip on the alternator repair kit. When I first changed my alternator back in Jan 2012, I held on to the original thinking I should try to rebuild it and keep it on the shelf.
When the replacement alternator failed last year, I brought it to the local test-it-for-free shop, they confirmed that it wasn't generating up to standards. Had already checked rockauto price of $100 and didn't need it that day, so I declined their offer of a rebuilt for $160 plus core deposit and ordered from rockauto.
post #16 of 22 (permalink) Old 08-04-2017, 11:18 AM Thread Starter
ymmv.
How difficult is the rebuild? Any special tools needed?
post #17 of 22 (permalink) Old 08-04-2017, 11:37 AM Thread Starter
The battery was no good so its replaced under warranty. Advance Auto checked the alternator with the new battery in place and said its dead (no output at all) Anyone have experience with new (not reman) Pep Boys alternators? Are they OK or garbage?
post #18 of 22 (permalink) Old 08-04-2017, 01:00 PM
Natesriv's Avatar
If done right a rebuilt alternator is just as good as new...new brushes, new bearings, etc... I think they can bench test one prior to you ever putting in on the car...
Natesriv is offline
post #19 of 22 (permalink) Old 08-04-2017, 07:37 PM
Depending on what's bad:
A soldering iron
A bearing puller
A T20 torx driver
8mm or 5/16" wrench
220 grit sandpaper
Chrome Engine paint (recommended, when the case is empty; you can paint the coils, they won't mind as long as you let it dry overnight.)
A 2004 crown vic one-way pulley. (easier on the intake)
And a rebuild kit to match the problem.
post #20 of 22 (permalink) Old 08-04-2017, 09:16 PM Thread Starter
A soldering iron
A bearing puller
A T20 torx driver
8mm or 5/16" wrench
220 grit sandpaper
post #21 of 22 (permalink) Old 08-05-2017, 09:59 PM Thread Starter
Update
New battery and alternator fixed everything. I think all the electrical weirdness was due to a dead alternator and the murdered battery that was all that was running the car and just couldn't keep up.
Thanks for all your help!
post #22 of 22 (permalink) Old 08-06-2017, 05:36 PM
Great!
