Rear shock tower brace? - TCCoA Forums
 1Likes
  • 1 Post By S4gunn
post #1 of 13 (permalink) Old 09-14-2017, 02:32 PM Thread Starter
69ford99's Avatar
Does anyone know if a rear shock tower brace for a sn95 or new edge mustang would fit our cars without too much trouble?
'94 bird- 20% tint,mark 8 driveshaft,clear corners, aftermarket rear spoiler, jmod, 3.73 gears, gutted interior.
69ford99 is offline
post #2 of 13 (permalink) Old 09-14-2017, 03:40 PM
Thunderstruck95's Avatar
Your probably going to be better off making one. Someone had one for sale here recently and posted several good pictures. It looked like a little angle iron for the ends, a cross tube, and drilling 4 or 8 holes through the wheel wells for the bolts would be all you need. It should make for a comfortable afternoon project- providing you have access to a welder.
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #3 of 13 (permalink) Old 09-14-2017, 04:50 PM
Racecougar used to make them; I have his rear braces in all the cars now.
But it's been awhile since I've seen any braces being made by anyone.
I lucked out and got one set of the subframe connectors and all, a set of IRS bracing someone made, and one FSTB that I bent hitting a curb. It was from JL, and it's so strong, I can't bend it back.
At this point, if I needed a rear STB, I'd tig a couple of brackets to a piece of 80/20; it would be Much lighter. ~$50 plus tig costs.
Maybe someone will need some Christmas money this year.
I'd buy a couple of sets of everything Except the RSTB, if the right people made them.
post #4 of 13 (permalink) Old 09-14-2017, 04:56 PM
CougarXR/7 over at SCCoA is making some now, here's a link to the thread.
post #5 of 13 (permalink) Old 09-14-2017, 05:07 PM
Joe, who used to make braces with JL?
I wonder if anyone got his designs...
post #6 of 13 (permalink) Old 09-14-2017, 07:47 PM
Kris would probably know better than me. I thought he did most of the work himself and he had someone helping him with the welding.
post #7 of 13 (permalink) Old 09-15-2017, 08:22 AM
T6Rocket's Avatar
Does installing the front and rear bars by themselves make a nice difference on these cars? I know most people do multiple suspension mods at the same time.
I installed F&R bars on my old 90 Eagle Talon TSI AWD, and just the front bar made the steering much more responsive and crisp. The rear bar helped eliminate wheel hop, and so did an aftermarket rear sway bar.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #8 of 13 (permalink) Old 09-15-2017, 10:29 AM
No.
post #9 of 13 (permalink) Old 09-15-2017, 03:40 PM
S4gunn's Avatar
Al
Every car has different handling capabilities and will respond to different suspension mods differently. What amounts to best practices for a front engined, AWD vehicle with IIRC a center viscous diff may not necessarily apply to a front engined, RWD boat ahem "personal luxury vehicle."
With a car this old, the best thing you can do for your handling is a) replace the front & rear struts with new ones even if they are OE grand and b) go through and replace all of the 20yrold shocks/struts + bushings. Even OE shocks that can be had for $20-30/ea will likely feel a lot better than the worn out ones on your car now.
Replacing Struts is an easy fix with just hand tools and if you do the labor yourself, you will get more bang/buck than spending $120+ on a bracket of metal that purports to solve a minor problem. You can also while you are at it decide if you want lowering springs or not.
If you are really seeing an issue with wheel hop, there are other fixes which just cost time and a welder. I found these by searching for "wheel hop" on google with "site:tccoa.com"
http://forums.tccoa.com/44-suspensio...-do-about.html
http://www.tccoa.com/articles/mn12how-to/irs/irs.html
RalphP likes this.
http://goo.gl/csaet4
S4gunn is offline
post #10 of 13 (permalink) Old 09-18-2017, 10:57 PM Thread Starter
69ford99's Avatar
Cant I just get some 1/4" thick flat metal bar from home depot and some bolts, it would be way cheaper.
69ford99 is offline
post #11 of 13 (permalink) Old 09-19-2017, 12:15 AM
It would be about as effective, knock yourself out
post #12 of 13 (permalink) Old 09-19-2017, 11:49 AM
S4gunn's Avatar
If you want to make the 1/4" bar thicker to reduce flex, just buy 2x the length of 1/2" flat metal bar and duct tape them together. Just remember to use a high quality duct tape like Gorilla Tape.. and I'm sure it will work fabulously.
-g
S4gunn is offline
post #13 of 13 (permalink) Old 09-19-2017, 01:52 PM
T6Rocket's Avatar
Gorilla Tape rocks!
Actually, that's the only thing they make that is good, all their glues are bullshit. I could glue more with maple syrup.
Al
Previous Fords:
T6Rocket is offline
