Axle shaft seal? - TCCoA Forums
post #1 of 7 (permalink) Old 09-20-2017, 01:50 PM Thread Starter
69ford99's Avatar
Axle shaft seal?
Im getting 3.73 gears put in, does the axle shaft seal get replaced when doing a ring and pinion swap or do I have to buy those separate?
'94 bird- 20% tint,mark 8 driveshaft,clear corners, aftermarket rear spoiler, jmod, 3.73 gears, gutted interior.
69ford99 is offline
post #2 of 7 (permalink) Old 09-20-2017, 02:34 PM
Wouldn't be a bad idea. Check with the shop that's doing it, they might tell you it needs them anyway.
post #3 of 7 (permalink) Old 09-20-2017, 04:30 PM Thread Starter
69ford99's Avatar
Oreilly lists like 5 different axle seals and napa lists one. Not sure which one is the right one.
69ford99 is offline
post #4 of 7 (permalink) Old 09-20-2017, 05:20 PM
ikutoisahobo's Avatar
There is maybe a different seal for the 7.5 and 8.8 IRS? Not sure the 8.8 IRS is what is used for the V8 and SC models.
ikutoisahobo is offline
post #5 of 7 (permalink) Old 09-20-2017, 05:26 PM
They're all the same. Still available from Ford (E9SZ-4B416-A) $10.68 at Tasca.
post #6 of 7 (permalink) Old 09-20-2017, 05:32 PM
Oh okay, in that case RockAuto has Timken ones as well which are probably just as good as the originals if not the same as the original seals.
post #7 of 7 (permalink) Old 09-30-2017, 07:07 PM
gordonm1's Avatar
I've removed axles on my '91 chevy truck and my '92 tbird and every time I didn't replace the axle seals they leaked. that is three times with new seals two without. i'd say do it.
one time was putting a used 3.73 differential in replacement of my 3.08 differential and autozone gave me seals for a smaller differential. I still need to fix this.
the last time was on the chevy and seals were not all that old but they leaked onto my brakes. luckily they are semi-metallic pads and cleaned up good. I think organic would have been ruined.
gordonm1 is offline
