Key Fob no longer works - TCCoA Forums
post #1 of 13 (permalink) Old 11-08-2017, 07:01 PM Thread Starter
Send a message via Skype™ to WarBird1201
The other day I took my key fob apart to paint the case. I put it back together and it no longer worked.(bettery is in right way). Know I can no longer disable the security system to start the car. Is there a fix to this.
Also is this the factory fob?
File Type: jpg 1510189248517112128846_1510189268659.jpg (3.93 MB, 3 views)
WarBird1201 is offline
post #2 of 13 (permalink) Old 11-09-2017, 08:46 AM
T6Rocket's Avatar
I personally have never seen one for a 1994-97 MN-12 that looked like that. They have 4 buttons.
I don't know of anyone that painted a fob before. Well, I do now!
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is online now
post #3 of 13 (permalink) Old 11-09-2017, 10:26 AM Thread Starter
So I might have an aftermarket security then. Is a flashing red light on the left side of the steering wheel (on the dash next to the light controls) factory?
Ill try to get a picture of that soon.
post #4 of 13 (permalink) Old 11-09-2017, 11:10 AM
No, the factory alarm light is in the cluster.
This is like my cluster.
See it to the left, by the battery?
An led anywhere is too early for these cars; I'm pretty sure these are lamps everywhere.
IIRC, blue leds were ~$10 each in 1996.
post #5 of 13 (permalink) Old 11-09-2017, 11:36 AM
Natesriv's Avatar
might take it apart again, ensure you didn't pull a solder joint out. The battery holder ring could have popped out.
God created Arakis to train the faithful... One cannot go against the word of God.........
Natesriv is offline
post #6 of 13 (permalink) Old 11-09-2017, 11:56 AM Thread Starter
This is the light. It pushes in like a button to.
post #7 of 13 (permalink) Old 11-09-2017, 04:21 PM
Kenz's Avatar
If it is an aftermarket system its likely it needs to have the remote re programed to the system. Every time the battery is taken out some of them need to have this done.
96 Cougar Sport - T45 Swapped
Kenz is offline
post #8 of 13 (permalink) Old 11-09-2017, 07:40 PM Thread Starter
So what would be the best way to check for an aftermarket system?
post #9 of 13 (permalink) Old 11-09-2017, 07:57 PM
Woodman's Avatar
Well, every indication says you have one, so there you go.
The simplest thing would be to trace the wires back from the LED to whatever unit is under the dash.
In the meantime, take your remote apart and find out what came apart when you took it apart. If that's the only remote you have, look around for another once you find out what kind of alarm you have.
Woodman is offline
post #10 of 13 (permalink) Old 11-10-2017, 04:50 AM
Is the battery for the fob good?
post #11 of 13 (permalink) Old 11-10-2017, 08:52 AM Thread Starter
Ok. The fob battery is good since we just put a new one in. I trace the wires and probably just remove the system since its caused more trouble than good.
post #12 of 13 (permalink) Old 11-10-2017, 09:06 AM
Before you remove everything, make sure the car still starts.
My crappy aftermarket alarm had a relay for the starter I had to wire around.
I just had to splice the wires back together where the idiots had hacked them off.
post #13 of 13 (permalink) Old 11-10-2017, 01:15 PM Thread Starter
The car wont start because the alarm keeps going off. I've also disconnected the battery and as soon as I reconnect it the alarm is back on. The light on the inside also runs into a wiring harness along with other interior stuff.
