Help..shifter won't mover - TCCoA Forums
 2Likes
  • 2 Post By theterminator93
post #1 of 6 (permalink) Old 02-24-2018, 02:14 PM Thread Starter
Banned
My shifter button doesn't seem to disengage when I got my brakes and it's stuck in park..
Wtf!!!!!
94badbird is offline
post #2 of 6 (permalink) Old 02-24-2018, 03:02 PM
MaddMartigan's Avatar
Dude, your traffic alone keeps the site alive. I guess keep it up.
My guess would be the neutral safety switch/brake pedal switch (whatever it is in your year/model). When you press the brake it releases a mechanism that allows you to shift out of park.
1992 Ford Thunderbird SC
-10.5:1 Compression Ratio
Trick Flow Stage 1 cam
Trick Flow Street Heat Intake
Mac 1 5/8 long tube headers
FRPP 42# injectors
3.27 gears
Custom aluminum driveshaft
M5R2
Burned Chip for SN95 T4M0 ECM
OMGHI2U
MaddMartigan is offline
post #3 of 6 (permalink) Old 02-24-2018, 04:05 PM
Wile E. Coyote Jr.'s Avatar
My safety switch is tied in with the ignition. I forgot this twice when the engine was out of the car.
First: Stacie, 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Second: Ellie, 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Third: 1997 Dodge Ram 1500, thirsty daily.
Fourth: 1990 Tbird SC, GT40 5.0 mated to m5r2, BBK long tubes, motor out the hood, drift car.
Wile E. Coyote Jr. is online now
post #4 of 6 (permalink) Old 02-24-2018, 04:28 PM Thread Starter
Banned
I will check that..i can apply a decent amount of force and get it, e wry other gear if fine but it's coming out of park that is hard..
Is it a coincidence it happened rite after I got a car wash and a heavy underbody rinse?
Lol.sorry yo flood you guy, I been pushing hard to have the car perfect for while my wife uses it.
post #5 of 6 (permalink) Old 02-24-2018, 04:32 PM
Dunno if the gen 2 FN10 is like the gen1 or the MN12, but there's a cable that runs between the steering column and the shifter on the latter. There's a solenoid in the steering column that pulls the cable back which disengages a plastic tab which prevents you from moving the shifter out of park unless your foot is on the brake and the igntion is unlocked.
The cable gets sticky and the solenoid fails, so you can diagnose the root cause.... or just disconnect the cable from the tab under the shifter. Pull the top of the shifter trim off and you'll see it towards the front on the passenger side. Just pop it out and you'll be able to shift from park whenever you want...
Grog6 and RalphP like this.
post #6 of 6 (permalink) Old 02-24-2018, 07:42 PM Thread Starter
Banned
Wow..mark8 had a fuse, I seen my brake lights were out so went to fix that too and reading the manual I saw a brake safety switch fuse, replaced it and I now got home and brakes lights are working..musta hit hit something in my trunk after the car wash as I was repositioning the cat litter and bricks..
I 1st tried lubing up the cable and button lol.
I double checked all the working just to be safe and it's ok.
Weird..everything else I read was hinting at neutral safety switch too.
