Worth getting or not? - TCCoA Forums
 2Likes
  • 2 Post By Trunk Monkey
post #1 of 13 (permalink) Old 03-31-2018, 09:03 AM Thread Starter
Banned
Lol, so another trade in the works..
I been talking to the guy and the heads are complete and including mach1 cams..
They are stage 2 fully ported and complete heads with mach1 cams and have an print cut into the head? Is that for clearance with boost or to lower compression ?
He doesn't have the spec sheet but what I'm wondering is with them being ported as they are for boost supposedly, would I loose compression and in return power running them n/a ???
I love the idea of them exp with the mach1 cams and is a perfect excuse for a topend rebuild.i know I said I'm done trying to go faster but if I can trade what I got for this set up and have it actually be beneficial for me I wanna..plus then obv the motor gets to get new timing chains ect...
Could you guys offer any input ?
File Type: jpg 00h0h_C5a0AgFYeM_600x450_1522504939697.jpg (17.6 KB, 88 views)
File Type: jpg 00y0y_hW2YpVh2wux_600x450_1522504946932.jpg (27.6 KB, 88 views)
94badbird is offline
post #2 of 13 (permalink) Old 03-31-2018, 09:24 AM
Woodman's Avatar
Mach 1 cams (C head cams) in a B head? Is that a thing?
Woodman is offline
post #3 of 13 (permalink) Old 03-31-2018, 12:34 PM Thread Starter
Banned
Idk either..i will start researching though.if not atleast I can use the cams I have and just get rid of the mach1 cams..
Although if doing all this I would just start part gathering and plan on having the engine done over next winter . I seen after market intake cams for 250-400$ range which isn't bad, if I'm doing all this works and the heads are ported as much as they are I might just need them..
So this is what I'm go ding is this true??
The c heads cams will actually cause me to loose hp because even the stock 98 m8 cams have 184 degrees of duration and 96-98 have 204 degrees (which I have) and 03 04 mach1 are also 184 degrees. Does this sound correct.
Are the mach1 cams only good for the tumbleport or boosted aplications ?
post #4 of 13 (permalink) Old 03-31-2018, 04:16 PM
So, what do have that you are you trading for these?
post #5 of 13 (permalink) Old 03-31-2018, 06:26 PM Thread Starter
Banned
My sct...
And I read that people use the 96-98 cams in the later 4v for a little hp..
So I just have to research more..
And if I read it correctly, the mach1 intake cams are almost similar to m8 cams,that doesn't seem rite.?
Also once I get them I think I might get cobra manifold then and run a full catless exhaust..
Lol,mods I like what you've 😉
post #6 of 13 (permalink) Old 03-31-2018, 06:56 PM
I'm not helping.
Last edited by XR7-4.6; 03-31-2018 at 07:01 PM. Reason: even that was too helpful.
post #7 of 13 (permalink) Old 03-31-2018, 09:21 PM
Wile E. Coyote Jr.'s Avatar
Mach 1 cams in B ports dont do anything to help. I asked that question on SVTperformance when I was learning more about 4 valves.
The only swap kinda like this that I heard works is taking some 96-98 B port Cobra intake cams and swapping them into C port Mach 1s, makes and extra 15whp with no torque loss iirc.
Given the cobras are rated 15hp more than your Mark, and only the intake cams and intake are different between the two, Id look around for an intake and the intake cams from a 96-98 cobra.
Plus B ports are already large enough, their problem is velocity. Making them bigger by porting them will only hurt. The valve bowls are what needs help, so unless he had those worked on, nothing in the deal would be worth it for you.
First: Stacie, 1996 Tbird LX, mild build NPI engine, PI cams and intake, Long tube headers, Jmod.
Second: Ellie, 1989 Tbird SC, r̶e̶s̶t̶o̶r̶i̶n̶g̶ ̶t̶o̶ ̶b̶e̶ ̶n̶e̶w̶ ̶d̶a̶i̶l̶y̶. off the deep end
Third: 1997 Dodge Ram 1500, thirsty daily.
Fourth: 1990 Tbird SC, GT40 5.0 mated to m5r2, BBK long tubes, motor out the hood, drift car.
Wile E. Coyote Jr. is offline
post #8 of 13 (permalink) Old 03-31-2018, 09:32 PM Thread Starter
Banned
Exact info I need..i want to know what to look for..
I mean imo it's worth it just to trade to have..its always been my dream to go boosted this would help it along..
And I do know someone with a boosted 4v and he's a good buddy and I know he would love these..
I been researching on these all day any chance I had to sit down...been non stop for days now and Easter tomorrow then a nice night of walking dead with the family and more reading on these ect..i plan in checking them out this weekend..
And xr7-4.6 , your the 4v know how guy here..and I have also come to find 96 98 cams are the ideal ones to have so that's pretty cool.
post #9 of 13 (permalink) Old 04-01-2018, 08:17 AM
T6Rocket's Avatar
I wouldn't do it. If only for the fact that if he's willing to trade ported heads and cams for a dinky SCT, I would highly suspect that there is something wrong with them.
When heads are ported, there is always a risk of hitting the coolant passage. I have seen it first hand more times than I ever wanted to.
Al
97 T-Bird LX 4.6 - 80k miles
Previous Fords:
T6Rocket is offline
post #10 of 13 (permalink) Old 04-01-2018, 07:46 PM
S4gunn's Avatar
Al
THIS. Something doesn't make sense.
What is the value of modular heads? I imagine a good deal more. What is the cost of shipping a set of modular heads+cams? How much is the shipping cost as a percentage of the SCT's value?
While Al suspects you are going to get junk heads -- I'm guessing the most reasonable explanation (unless this is coming from a friend in a F2F transaction and he's doing you a solid favor) -- is that you will mail the SCT and never hear from the guy again.
-g
http://goo.gl/csaet4
S4gunn is offline
post #11 of 13 (permalink) Old 04-03-2018, 05:55 PM Thread Starter
Banned
Al
-g
If I decide on them i will be going in person to check them out..
And I'm kinda leaning against them..if built for boost I'm sure it will dog down a n/a and I'm working another deal for cobra cams,intake and intake tube..
Would any of you guys need or want these ported heads and cams?? I can make it happen if it's worth our while..
post #12 of 13 (permalink) Old 04-04-2018, 08:19 AM
Rodeo Joe and Boston-Bull like this.
post #13 of 13 (permalink) Old 04-04-2018, 11:53 PM Thread Starter
Banned
Well I past and got fenders and a bunch of other random stuff and $.. also guy had like 10 mark 8s and a bunch of stang and birds ..so if I ever need a part or work done I now have the guy..
