CEL Issue Resolved - Multiple O2 Sensor Related - TCCoA Forums
post #1 of 11 (permalink) Old 04-14-2018, 04:43 PM Thread Starter
aircraftbuilder's Avatar
Just another data point for the forum and other fellow newbies. I had a SEL and was given codes for both banks, both O2 sensor heaters something or other. Anyway, replaced the PCM based on forum research. Needless to say, nor more SEL! Oh yeah. Now I can go for PA inspection.
Next mission, replace the leaking radiator. While I’m at it, going to do t-stat and water pump. Bring on some warm weather.
If anyone wants the codes that were pulled, I can post. Just don’t have the paper close at the moment.
'97 Thunderbird 4.6L Sport
Pacific Green Metallic
aircraftbuilder is offline
post #2 of 11 (permalink) Old 04-14-2018, 05:58 PM Thread Starter
Well, that success was short lived. That yellow mutha is back on mocking me. Guess I’ll shoot the codes and if it’s a new thing or the old. I think that this is going to be a contest between the two of us. Argh.
post #3 of 11 (permalink) Old 04-14-2018, 05:59 PM
I'm more interested in which EEC failed; what was the 4-digit code on it?
post #4 of 11 (permalink) Old 04-14-2018, 07:26 PM
Banned
Were the 02 sensors ever replaced or not ?
94badbird is offline
post #5 of 11 (permalink) Old 04-16-2018, 10:57 AM Thread Starter
Not likely. I haven't replaced them as of yet. Mileage is just over 83k.
EEC-V ML.2-334 7F02 FTE1
F7SF-12A650-AB
Is that the information that you were looking for?
There seems to have been multiple solutions to addressing this issue. The most common cure seemed to be the PCM. That's the direction I went. Other "fixes" were fuel filter and others that I don't recall offhand.
My thinking is to pull the codes again to see if anything new is being thrown. Then, I'm not sure. I do have a weeping radiator, so that needs to be changed. I have that in the garage along with a water pump and t-stat. Was going to do it this weekend, but the weather is not cooperating.
Any other suggestions on a strategy would be welcome!
post #6 of 11 (permalink) Old 04-16-2018, 01:24 PM
If it is throwing codes for O2 sensor heater circuits, that is pretty much always either the O2 sensors themselves, or wiring that fell down and melted on the exhaust. I have never seen O2 sensor heater codes codes caused by a failed PCM on any car, let alone a Tbird. Pretty much the only PCM failure that our cars are at all prone to is the 94 4.6 cars hanging an injector open. Get the car up in the air and inspect the O2 sensors and the wiring going to them. If the sensors haven't been changed recently, replace them. Even apart from the heater codes, they do lose effectiveness over time and will not respond as quickly as they did when new.
post #7 of 11 (permalink) Old 04-16-2018, 03:10 PM
According to my list FTE1 is the one that fails in the 97 cars; mine quit shifting correctly, and replacing it fixed it.
Must have been a bad batch.
I always keep this in the back of my head now...
post #8 of 11 (permalink) Old 04-19-2018, 06:27 PM
I too had the O2 sensor heater circuits fail because of the PCM. It was an LJC1 that failed.
https://www.ford-trucks.com/forums/1...uit-codes.html
Johnny Langton participated in that thread. May he rest in peace.
I'm pretty sure I replaced it with another LJC1, and it's been running every since. That was 9 years ago.
As of 3/2019:
'96 T-bird 4.6L Sport (gone a while back)
'97 Cougar 4.6L 30th Anniversary (still have)
'01 F250SD V10 4x4 (recently sold)
'18 Taurus SHO w/PP
krewat is offline
post #9 of 11 (permalink) Old 04-19-2018, 06:30 PM
Hah! My own thread here from 2009: http://forums.tccoa.com/7-engine-4-6...same-time.html
As of 3/2019:
'18 Taurus SHO w/PP
krewat is offline
post #10 of 11 (permalink) Old 04-22-2018, 02:40 PM
I also have a failing LJC1, not for o2's but for intermittent loss of spark during cranking. I wouldn't mind getting my hands on a good LJC1 pcm eventually.
post #11 of 11 (permalink) Old 05-01-2018, 11:14 AM Thread Starter
Well, the plot thickens....... The couple that I bought the car from live in my neighborhood. After buying Marguerite (I named her that after watching a Trailer Park Boys segment and her having a leaking radiator), I helped them out on a couple of around the house things to thank them for selling me the car. Anyhow, since the husband couldn't drive anymore, but still loved the car, he would run it once a week. Apparently, one day he felt like more than just letting it idle and warm-up and popped it into gear with some throttle and put it partway through the garage wall into their living room! There is nothing bent or really messed up, but I know why I put a new radiator in this weekend!
Unfortunately, that little mutha of a yellow light is still taunting me. I am glad that she came clean on the oops through the garage as that may help identify what is causing the light to continue to ruin my days.
Since I had the radiator out, I would up putting in a new water pump and thermostat..... because if I hadn't, sure enough something would've gone haywire and I would be doing it sooner or later anyway.
