Transmission Crossmember bushings - TCCoA Forums
post #1 of 4 (permalink) Old 04-24-2018, 10:44 PM Thread Starter
V22
V22's Avatar
Hello all,
While changing my transmission fluid I discovered the main mount for the transmission is shot. However, there are also two bushings on the left and right end of the crossmember. I have been unable to find any part numbers or info on these bushings. The only place I've seen them was at SCP:
Anybody know if there is a universal bushing that would replace these? Energy suspension makes several that look similar to the above picture, but I'm not quite sure they will fit.
Thanks!
1996 Mercury Cougar XR7 4.6L , Vermillion
If you see a shiny red car swerving around potholes and parking 10000 miles from all the other plebeians in parking lots, then it's probably me.
V22 is offline
post #2 of 4 (permalink) Old 04-27-2018, 08:27 PM Thread Starter
V22
V22's Avatar
I'm wondering, maybe the crossmember is sold with the bushings as one item. Guess I'll just measure the old one and look up one that matches.
V22 is offline
post #3 of 4 (permalink) Old 04-27-2018, 09:19 PM
Thunderstruck95's Avatar
What’s wrong with buying the ones from SCP?
1995 T-Bird.
PI 4.6. Bullitt intake. Stage 2 MHS cams. Kooks Headers. 4,200 ATF Speed converter. BCA Transmission. 4:10s. Tune by Supercoupes Unlimited. 245 RWHP.
3,700 lbs at half tank. Goal- 3,400 lbs
Best of 13.85 at 96 mph. Goal- 11's NA
1997 Lincoln Mark VIII FX2 Sand Dune Machine- R.I.P.
Thunderstruck95 is offline
post #4 of 4 (permalink) Old 04-27-2018, 11:06 PM Thread Starter
V22
V22's Avatar
They're just a bit too expensive for me right now. Don't get me wrong, I'm not ragging on SCP or anything, but I'm pretty sure the bushing is an energy suspension one, which is significantly cheaper.
V22 is offline
