engine noise - TCCoA Forums
post #1 of 7 (permalink) Old 04-30-2018, 04:42 PM Thread Starter
gordonm1's Avatar
engine noise
I noticed a rapid clicking/ticking noise and it sounds like it is coming from the alternator. Does that make any sense or a pulley? Smog pump is bypassed. Smaller belt was used during bypass and it was pretty tight.
I don't recall ever replacing the alternator. Ticks are more rapid than a former exhaust leak.
gordonm1 is offline
post #2 of 7 (permalink) Old 04-30-2018, 05:08 PM
Remove the serpentine belt and see if the noise goes away, that will help narrow down where it may be coming from.
post #3 of 7 (permalink) Old 04-30-2018, 05:21 PM
dDUBb's Avatar
Tick is proportionate to engine RPM ? Like Matt says, take off the belt, and spin the pulleys by hand to see if you can "feel" any worn bearings. Also might try a stethoscope / long screwdriver with your ear to the handle ...
dDUBb is offline
post #4 of 7 (permalink) Old 05-02-2018, 07:21 PM Thread Starter
gordonm1's Avatar
Removed the belt and noise is gone. Removed the alternator and did not notice a problem with the bearings or other pulleys. Priced a new alternator and ordered brushes to try first. Alternator tested good at parts store.
gordonm1 is offline
post #5 of 7 (permalink) Old 05-08-2018, 08:48 PM Thread Starter
gordonm1's Avatar
Alternator back in with just brushes replaced and no noise. Old brushes were worn but I did not see breakage or cracks.
I had bypassed the smog pump with a shorter belt but I couldn't remember the routing so I used an original belt and included the smog pump which I guess will freewheel. I started to remove the pump but when it was ready to come out I could not see a way it would fit though the available room so I need the belt routing and easiest stuff to remove for smog pump removal. To me it looked like the alternator bracket and the belt tensioner. My shorter belt was about 93 inches.
I am kind of lucky I did not remove the pump because I ended up using the original belt.
The issue is temporarily resolved, for about ten bucks and a gallon of sweat.
gordonm1 is offline
post #6 of 7 (permalink) Old 05-08-2018, 10:55 PM
S4gunn's Avatar
http://forums.tccoa.com/8-engine-5-0...placement.html
http://goo.gl/csaet4
S4gunn is offline
post #7 of 7 (permalink) Old 05-15-2018, 12:58 PM Thread Starter
gordonm1's Avatar
Thank you S4gunn for the mustang routing link.
When I got the stock belt on, I realized I may have missed a way to try the shorter bypass belt. I will run stock for a few miles to see if the alternator noise stays gone since I have it this way already. Then go back and try the bypass again.
This may have been the thread where I got Rayo's routing diagram but alas, his photos seem to victims of Photobucket like mine.
gordonm1 is offline
